1To make the box controller
Take the wood plate of 3mm thickness and laser cut it (we put the image in the file)
Take also the acrylic sheet and laser cut it (we put the image in the file)
2Make the stamper
3D Print all the pieces ( in the files )
put two spring inside the stamper.
Puts all the pieces together.
put a button (connected to the GND and a pin)
3Make the pen
Take a basic pen
put a round piece of metal on the tip of the pen connected to a pin
put a button in the pen (connected to the GND and a pin)
4For neopixels
weld all the nine neopixels together ( one cable is connected to 5V one in the GND and one in a pin)
The code is in the project files
5For the metal plates to sign on
take a metal piece of 3mm thickness preferably
Or take a more thiner piece of metal
Cut it in 9 squares of 5*5cm
and glued this in the holes of the acrylic sheet
All those metal pieces are connected each one in a pin of the arduino
6Make the game
It's in the files
7arduino code
In the files
Nasser
