The game can be found here : https://nasser404.itch.io/signing-race
This project is a video game with a custom controller made for it
acrylic_sheet.svgsvg+xml - 4.13 kB - 01/04/2024 at 21:07 |
wood_box.svgsvg+xml - 6.09 kB - 01/04/2024 at 21:07 |
stamp_body.stlStandard Tesselated Geometry - 264.24 kB - 01/04/2024 at 21:01 |
stamp_shell.stlStandard Tesselated Geometry - 216.49 kB - 01/04/2024 at 21:01 |
stamp_support.stlStandard Tesselated Geometry - 63.85 kB - 01/04/2024 at 21:01 |
We changed our minds about the box. Instead, we used 3mm-thick wood and laser-cut it.
For the plates, we cut the brass plates to 5cm by 5cm. On the box we cut an acrylic plate and made 9 holes for the plates.
We placed in the box 9 neopixels to make the controller more satisfying.
we weld all the brass plate in a pin of the arduino and we weld all the neopixels together to connect this in one pin of the arduino.
We also made the pen. In the pen we just put a round metal piece to make the contact of this piece of metal and the brass plate to makee the sign.
In this pen we have also a button that permit to change the color of the pen.
And finally, the stamper.
We just 3D printed the stamper and when we actionned the stamper, this will touch a button and it will pass all the bad CV.
We tried to create a prototype of the controller, showing the basic functionality, and had it interact with our game via an arduino.
We then made a list of materials and parts to buy for the final rendering.
We also made a 3D model of the first part of the controller to better understand what will go where.
We futher discusses design and materials to use
We also started planning our project
Take the wood plate of 3mm thickness and laser cut it (we put the image in the file)
Take also the acrylic sheet and laser cut it (we put the image in the file)
3D Print all the pieces ( in the files )
put two spring inside the stamper.
Puts all the pieces together.
put a button (connected to the GND and a pin)
Take a basic pen
put a round piece of metal on the tip of the pen connected to a pin
put a button in the pen (connected to the GND and a pin)
henrebotha
