1Equipments
You will need : an Arduino card, a breadboard, hall effect sensors (x3), magnets (x2), lasers modules (x2), light sensors (x2), a safety vest and a good amount of cables.
2Connecting the hall effect sensors
Connect the hall effect sensors to the Arduino card and the breadboard, then put the sensors into small boxes (that may be 3D printed or made out of wood), then attach them to the vest. Put one box on each shoulder and one on the belly.
3Setting up the laser
Connect the laser modules and light sensors to the Arduino card. Put said lasers and sensors into wooden boxes as they are very fragile (one in each), and dispose them on the ground to form an arena (as depicted in the "arena" file).
4Setting up the Arduino card
Put the Arduino card in a box that you will attach to the back of the safety vest. Make sure your cables are long enough.
5Have fun!
Once everything is set up, put the vest on a mannequin (or someone) and hit on the front boxes to attack in game. Put you feet in front of the lasers to move right or left.
