January 9th
01/09/2024 at 14:29 • 0 commentsWe set up our project and tried our code for the Arduino card. In the past week, we also made wooden boxes for our laser modules out of planks we salvaged. Unfortunately, the code was wrong and made our computer crash, basically making the Arduino card unusable. On the bright side, we could complete the hardware part of the project and successfully made one vest work.
January 5th
01/07/2024 at 16:11 • 0 commentsAfter a week, we went back to school to get our boxes, since they take a long time to print. They were as we had imagined, except for one detail : the 3D printer had a large margin of error : we had not paid attention to this detail...
This clearly shows the limits of 3D printing : printing even a small box takes a considerable amount of time.
Using the laser cutter could have been another solution, however, the boxes wouldn't have been as resistant since the thickness of the wood is very thin.
The advantage of using the 3D printer was the possibility of adding layers to make it thicker.
The boxes are therefore not very thick, but strong enough to handle repeated punches. -
December 29th
01/07/2024 at 16:04 • 0 commentsWe went back to school during holidays to print our boxes. After carefully rechecking the dimensions, and changing the thickness of the boxes, we launched 3D printing. We had smaller and larger boxes.
Printing a small box took at least 4 hours (because we added layers of thickness)
Printing a large box took at least 8 hours.
The lids of the small and large boxes took 30 minutes and 1 hour respectively.
Of course, these values are approximate... -
December 11th - December 18th
01/07/2024 at 15:16 • 0 commentsWe thought about how we were going to model our boxes.
We thought about several possibilities, and the one we chose was 3D modeling. We used a software named OneShape. We had to learn how to use this software, which was, at the beginning, really difficult. After a lots of tests and many hours, we managed to model our boxes, paying attention to the dimensions and thickness. Since we have to hit the boxes, we had to add layers of thickness to make them more resistant. Now we just have to print them by using a 3D printer at the LAB.
5 december 2023
12/12/2023 at 13:55 • 0 commentsOn 5 December, we carried out a number of tasks. Firstly, we made cardboard prototypes of the boxes that will contain the sensors. These boxes will be sewn onto the bullet-proof vest. We took the necessary measurements to ensure that the boxes would fit the vest and the size of the sensors perfectly. The boxes at the front of the vest will be 4.2 cm wide and 6 cm long. They will be 2cm high and 0.5cm thick.
Similarly, the box containing the arduino board, located at the back of the jacket, will be 3 cm high and 0.5 cm thick. The length will be 12cm and the width 8.5cm.
We've chosen to include a hole on each box so that the wires can come out and link the boxes together.
Finally, we made a prototype of the box.We also ordered the last sensors we needed, such as the lasers.
Prototyping
11/28/2023 at 16:36 • 0 comments24/10/23 – Creation of the prototype of the suit for the upper part of the body (see "Prototype_upper_circuit_back" and "Prototype_upper_circuit_front") out of cardboard. We defined the positions of the Arduino card and the sensors. The prototype is satisfying, but only tailored to one of our team members. We need to have unisized suits (possibly buying an already existing one and fixate the card and sensors on it). We also need to make a prototype with the card and sensors on it.
21/11/23 - Creation of a more complete prototype of the suit for the upper part of the body (see "Ctrl+Fight! prototype back" and "Ctrl+Fight! prototype front"). We connected the hall effect sensors with the Arduino card and to the computer. The system is working, the hall effect sensors seem like a better option than the ILS modules. The gloves will need to be equipped with magnets to make it work. However, the cables were too short and barely holding, we need a sheathing for them. The cable connecting the card to the computer might also be too short, it doesn’t allow much movement. We need to make a prototype for the boxes that will contain the sensors.
We also started looking for a way to track the players position on the ground to make movements inputs in the game. Laser emitters and receivers seem like a good way to do that.
28/11/23 - Creation of a prototype for the arena in which the players will fight (see "Arena" and "Diagram_of_the_arena") and for the boxes that will contain the sensors (see "sensor_box"). The arena was made to scale, but still seems rather small (1,2 x 1 m) and doesn’t allow much movement. The lasers are placed on the lateral sides of the arena, two lasers for each player that will make them go right or left in game. For the suit, we started looking for second-hand offers online and have found some not too expensive.
