1How to build the targets.
Polygon boxes with 3 or more sides.
- Create a first boxes with five sides, a inside diameter of 8 cm with notch assembly.
- Export it on fusion 360 in a DXF format.
- Start a new sketch.
- Use the tool circle to do two circles (one circle on each pentagon), one circle with a diameter of 2 cm and another one of 4 cm.
- Check the size of sides to be sure that size didn't change during the exportation.
- Save it on your computer in a DXF format and next export it.
- Import it on inksape and check the size one more time to be sure.
- if the size are good use laser cutter to cut it four times in wooden plank of 3 or 4 mm thick.
- Go again on makercase create another box with five side but with an inside diameter of 10 cm and do the same operation that youb did before but cut it once.
- Once you cut all your shape with the laser cutter glue three sides with the two pentagon.
- Pierce one of the sides you didn't glue on each targets.
- Glue a led in each hole.
- Do the Arduino's set-up and then place the the two other side on the top to close the targets
2How to build the gun.
- Search on internet a 3D gun model.
- Once you found it on a website import it on fusion 360.
-Separate it a first time to have two parts one is the left side of the gun and one is the right side of the gun.
- Separate the barrel to the shift of the gun.
- Dig in every parts to juste have structure.
- Export it on Cura.
- Use 3D printer to print it.
- Do the Arduino's set-up.
- Put together each part of the gun and screw the structure together.
