Project diary
01/09/2024 at 13:19 • 0 commentsFirst lesson of the project :
Today Adrien and I think of a game, found one and split the work to each other.
Second lesson of the project :
We found a name for the game : "Laser tag", Adrien serach and found on internet a gun that he could print with the 3D printer. I started to do the targets but i didn't know how to do so I asked the teacher who tell me step to follow.
Third lesson of the project :
Adrien had problems with the modelisation of the gun in fusion 360. I finished to do the secondary targets.
Fourth lesson of the project :
Adrien finished to work on the gun model. I export the secondary targets on fusion 360 and started to do the principal targets.
Sixth lesson of the project :
Adrien started to search how to do the Arduiino's set-up for the gun and sarted it on a simulator. I finish the principal target and export it on fusion 360, I started to modified them and exportated them in inkscape.
Seventh lesson of the project :
Adrien finished to look for the Arduino's set-up for the gun and started to the script for it. The modification that i had make weren't good so I had to modificate them a second time on fusion 360, after I re-export them on fusion 360.
Eighth lesson of the project :
Adrien finish the script for the gun and start looking at the Arduino's set-up for the targets. We saw that we needed to modifiacate them again so i did it.
Nineth lesson of the project :
Adrien finished to look at the Arduino set-up for the targets and start looking for the script for the targets. I finished to do the modification on fusion 360 and export it on inkscape.
Tenth lesson of the project :
Adrien finished to do the script for the targets and started to print the gun. During the week between the ninth and tenth lesson I started to cut the targets but a problems happened and the size wasn't the one we wanted the teacher said that during the exportation the size probably change so i had to restart and I'm gonna cut it during the holydays.
Eleverth lesson of the project :
We are a few hours before the presentation, Adrien had print the other side of the shift of the gun but he didn't had the time to print the gun I cut the targets with a laser cutters and I glue a part of each targets togethers. Adrien had did the Arduino's set-up on the gun and he is doing it for targets, I drilled an hole in one side of each targets and Adrien is gonna glue led to it to know wich targets we have to aim. And I'm doing all the things we have to do on hackaday.
