Anwaar Amulet - The story so far
A Platform for Personal Portable PCB tokens
Hi! I started what eventually became this project way back in 2019. It's officially on Crowd Supply, and I was thinking this would be a good place to retroactively log the design evolution of the Amulet.
-edit- we're live! https://www.crowdsupply.com/chipperdoodles-chippydootles/anwaar
I've decided to call any design that falls within certain commonalities part of the Anwaar project. Anwaar is Arabic for 'a collection of lights'. With Anwaar, I hope to get people to design their own personal collection of light they can gift or carry on themselves.
This project will highlight the beginning of the journey and the design evolution of the Amulet family. I might touch on other families here and there but i'll try to stay focused on the amulet.
Getting straight to the core to try to explain it simply, the anwaar amulet is a 2 piece design.
The bottom board (I refer to them as the base board) can be thought of as a hyper specific development board. In this case I ended up using an attiny 1616. On top of that it also includes an energy source (15F Hybrid Capacitor) as well as all the power management for charging and providing a stable VDD rail.
The top board (which i refer to as the face plate) connects to the base board using a 10 pin header/socket and secures with five m.2 screws/standoffs. The face plate is intended to carry artistic designs and circuits, the obvious use being a fun blinkies. Taking it a step further I like to find ways I can integrate the copper of the circuit into the artistic design itself!
  • New Cap who dis?
    Bulbul • 10/02/2025 at 22:35 • 0 comments
    From the previous design there were some takeaways of what to aim for;
     1) Continue with the two piece design
     2) find a reasonable size SMD header
     3) find energy storage that fit
    Knowing this I went back to where a lot of time is spent, digikey's parametric search. As I was browsing the super capacitor category by lowest height with a minimum of 1F capacitance I came across some very interestingly small but with large storage HVC caps. On further investigation it turned out this was because they were hybrid caps! this means they weren't true EDLC supercaps. That being said those their rated was 15F! and a single cell was only  12x12x2.5 tall! I thought to myself surely there must be a catch but I can't not play around with these.
    So with sails unfurled I start designing my next amulet. I tried to find the lowest profile SMD that would be easy to solder and settled on a 6 pin 2.54mm header. Also while working on this version I decided to experiment with overall height I tested out using 0.8mm for both base board and face plate pcb thickness.
    For charging I had to dig into the data sheets and supplemental material. Luckily Vishay had some pretty solid documentation. These type of hybrid caps need a lot more care when it comes to charging. Up until now I've been drawing power straight from USB, depending on temperature these hybrid caps I chose have a max voltage of ~2.8.They state that ideally constant current/constant voltage charging scheme would be used. However a current limited LDO could suffice. I'll come back to charging later, but for simplicity and cost I went the LDO route. There were some draw backs to this, i.e. no way to protect from overcharge and no integrated charge indication (stuff you'd find normally in a battery charger IC). But for now it would suffice.
    The result:
    Some explanation on the pictures. The only surviving one of these I still have! The goopy look was from me experimenting with conformal coating. You can see I even spelled hyat wrong! (حياة) ! I was just getting into learning arabic at the time (still have a long ways to go!). Not pictured are the standoffs which were standard threaded hexagonal standoffs, and the hybrid cap which was harvested and reused on other boards.
    Ok, so the 0.8mm looked awkward with the amount of space between board, and wow we have so much space? Maybe too much space. Was happy that the design worked, but unsatisfied with the height.
    Improvements over second attempt:
    * surface mount headers replace standoff power and hence safety from shorts
    * much more dense and low profile energy storage
  • A bigger cap and a sandwich
    Bulbul • 03/18/2024 at 19:12 • 0 comments
    Project Log #2
    So after the terrible ??? circuit of the first one I switched my focus to finding a better power source. When trying to design something a lot of my time is spent on a component distributor website, looking up parts in the parametric search, filtering and sorting by various criteria. In this case I was looking for the a good tradeoff between physical size and capacitance for EDLC. In the search I found some some short height radial can EDLC caps rated at 1F (and also 1.5F). Once again not wanting to do straight math to find super accurate run times, I decided just to play around with some. The one thing about these caps is that they are THT. This would be difficult to have a nice undisturbed art board if I placed it on the back of the pcb like I did with the smaller SMD EDLC in my first amulet attempt. This gave rise to the sandwich case idea, where one board managed the power and one board had the design, started (eventually evolving into the baseboard /face plate idea). I was excited about the idea because it lent itself to being modular, I could swap front facing designs! Once I thought about that it started being more than a one off gift, it felt like way too cool of an idea to just leave alone and not want to get other people in on.
    So now that we have the sandwich, the next step was the circuit. The caps were rated for 5.5 volts which meant I could charge them easily from USB, the only thing to worry about would be drawing too much power so I just threw a resistor in series to keep the max current set. I played with a couple ideas, in the end decided using a buck-boost would help keep led light consistent. Next was figuring out how to send power and connect the two boards. The easiest solution was to just use the standoffs for power and ground connections. I layed them out in a star shaped pentagram pattern and used the top stand off for power and the other four standoffs for ground.
    Another addition was a buck-boost, since the cap would charge at 5 volts and discharge to based on required voltage and load it was a pretty wide range and the brightness of the leds in any design would vary greatly over it's runtime. Easiest way to do this was to use a buck-boost voltage regulator to output a consistant voltage. Most LEDs can work with a forward voltage of 3 volts so I decided to set it on that. I had to use 0402 to squeeze everything in nicely which wasn't a big worry at the time of design. So depending on leds in the face plate design led runtime was usually 30-50 minutes with charge time being very very fast (yay supercaps!). If i remember correctly there was at least one attempt at this design before this board where I had severely under-speced the inductor, leading to some burn outs. I was still learning! this was my first time using a switching regulator and inductors believe it or not!
    Improvements over first attempt:
    • actually worked!
    • can have modular designs
    • usb charging
    •  runtime increased from seconds to ~30 minutes
    However there was one problem in combination with some other factors that led me to look for other solutions. Thanks to my standoff power carrying design If you set the amulet down on any conductive circuit, it would short! I luckily didn't find this out the hard way and it's something that I had an "oh derp" realization moment. Not satisfied with that I decided to keep plugging away and searching for alternatives. But not before making at least a couple different designs.
  • The first one!
    Bulbul • 02/21/2024 at 17:38 • 0 comments
    Project Log #1
    Little sparks for a gift - sometime in 2019 I think.
    When I moved to colorado about 5 years ago I got a job in PCBA assembly. It sparked a lot of on and off the job learning about circuit boards and their manufacture. In another lifetime I studied the world of print production university and worked a little while in prepress. It didn't take that long for me notice how similar pcb manufacture and print production really were.
    With my brain as it is, the wires started to cross. I knew people would do really cool things with pcb art and silkscreens and leds but my brain was focusing more on the copper. I thought that since etching copper is a very high resolution reproduction process with tight tolerances, what kind of art could I do just in the copper layer? Then another thought came barrelling in, on top of being pretty, the copper on pcbs are meant to carry current... then maybe I can carry current through art on the board, form and function combining in cool symbolic ways. Symbols? my brain starts reeling I love those! Literal power and energy flowing through a symbol? heck that sounds magical. Thus the idea was born, let me take a design and circuit and combine them together.
    This took form in making a little amulet for my partner. I asked what her favorite silly lil demon guy was that had a sigil and used that to pick the base design. Of her responses i picked Bifrons, a silly demon mans that likes to teach art and science and also light candle flames by graves
    The next step was to figure out how to make this into a circuit and I decided to fit some small amber leds on the board, connecting them to the design in a way that would use the art to carry power to the leds.
    The first amulet!
    I'm going to be honest with you, I have no idea what I was trying to do with the circuit powering the leds. I used a jst 2 pin on there so you could... charge it with a lipo.. I guess? I don't think I thought very hard about it but this was very early in my experiments with surface mount circuit board design I was reaching out and grabbing parts that were available, familiar or seemed like I could make them work. I can't remember my train of thought and am too terrified to look at how terrible the circuit is so i'm pretending the digital files are lost to time (as opposed to buried in some archival folders somewhere). I also used a small radial smd 474mF edlc, this hardly provided power for long as I was designing around size vs even beginning to think about the math and the power requirements. I tend to fly by the seat of my pants and a lot of the evolution of the amulet shows that. So my circuit was objectively terrible but the leds did light up even just for a little bit. Most importantly I had ordered the design on oshparks Afterdark boards (clear solder mask on black fr4) and they /looked/ great. It was far from practically usable but I knew I was on to something I wanted to see through, I wanted a nice /functional/ gift for my partner. So the biggest success of this version is that I knew I could make something that looked cool that doubled as a led circuit.
View all 3 project logs
