Rev2 Final Calibration
04/14/2024 at 03:52 • 0 commentsI have completed the final calibration for the second revision. The data is as follows:
Voltage: Meter, Fluke 101 -60.28, -60.4 -54.70, -54.81 -49.86, -49.90 -44.88, -44.97 -39.86, -39.93 -34.93, -35.00 -29.89, -29.94 -24.90, -24.94 -19.92, -19.95 -14.94, -14.96 -9.956, -9.97 -4.972, -4.978 -0.987, -0.989 0.001, 0.000 0.989, 0.989 4.975, 4.984 9.960, 9.97 14.94, 14.97 19.92, 19.96 24.90, 24.95 29.89, 29.95 34.81, 34.87 40.00, 40.08 44.80, 44.88 49.90, 50.03 54.97, 55.11 61.04, 61.1 Resistance: Meter, Range, Fluke 101 29.57, 1, 31.7, 98.33, 1, 103.3 332.3, 1, 332.8 1081, 1, 1044 10730, 2, 10520 21930, 2, 21410 100500, 2, 97300 339800, 2, 315200 530000, 2, 484000 Capacitance: Meter, Range, Fluke 101 50.88n, 2, 49.2n 96.73n, 2, 96.6n 1.006u, 2, 1.009u 10.03u, 1, 9.92u 45.57u, 1, 47.32u
This works out to 0.3% relative accuracy for voltage, 10% for resistance, and 5% for capacitance.
Rev2 PCB Assembly and Bring Up
03/22/2024 at 06:34 • 0 comments -
Rev1 Enclosure
03/20/2024 at 03:57 • 0 commentsI have mounted the first revision into an aluminum sheet metal enclosure with some holes cut in it. The first revision has been repurposed into just a voltmeter because there are some problems with the switching circuit.
Rev1 Voltage Test
03/14/2024 at 03:44 • 0 commentsI did another test with the rev1 prototype, this time only measuring voltage, and bringing it all the way to the maximum voltage of 60V. Again I am doing calibration and comparison to my Fluke 101 Multimeter. This has a problem as the Fluke 101 does not have more digits than this multimeter, however, I am ignoring this for now. I was able to stay under 1% error for all measurements, and I think this could be improved with a better calibration procedure. Here are the results:
Voltage(V), Error(%) 0.989, 0.0 4.982, 0.71 9.97, 0.76 14.96, 0.81 19.95, 0.86 24.94, 0.85 29.94, 0.88 34.99, 0.86 40.03, 0.83 44.9, 0.81 49.89, 0.85 54.84, 0.9 59.8, 0.71
Rev1 Display Bodge
03/13/2024 at 00:45 • 0 comments -
Rev1 Preliminary Accuracy and Precision Test
03/10/2024 at 05:41 • 0 commentsAs the title says, this is a preliminary test of the first version of the multimeter. Before the test, I basically calibrated it using my Fluke 101 as a reference. The results of the test are as follows:
2.5V Error: 0.569, Coeff of Var: 0.0102 5V Error: 0.2342, Coeff of Var: 0.001 7.5V Error: 0.2404, Coeff of Var: 0.0019 10V Error: 0.0671, Coeff of Var: 0.0006 10ohm Error: 48.5352, Coeff of Var: 0.0 100ohm Error: 8.2285, Coeff of Var: 0.0 1000ohm Error: 0.0443, Coeff of Var: 0.0 10000ohm Error: 1.9391, Coeff of Var: 0.0 40000ohm Error: 5.2247, Coeff of Var: 0.1246
As can be observed, the error is fairly low for all the tested voltages. For resistance, the error is higher especially at the low and high ends. It basically isn't accurate at all at 10 ohms. I also did a test of capacitance and for 100nF it measured 579nF, so basically order of magnitude. For 10uF it measured 11.78uF, so close. I may be able to make capacitance better (for 100nF) by increasing the sample rate.
