Quotes don't work right
10/10/2025 at 04:23 • 0 commentsAny text with quotes shows up incorrectly:
Video Embed Bugs
07/05/2024 at 22:48 • 0 commentsSo there appears to be a nasty video-embed bug, when using the built-in video link share button.
With this bug, the video image embeds itself in random parts of the post, behind other images even - and can move text around too. I'ts pretty nutty.
example of the video embed bug
One workaround I have found is to simply the embed URL and adjust the viewing box to a smaller size. In this case, 720 x 405 seems to work. It also helps to use the HTML markup version of your post (icon <> located in upper right)
work-around for embedded videos.
A note of caution though, don't add video embeds until the very end in your post. It will save you some cleanup work and headaches.
Adding collaborators bug
03/26/2024 at 18:19 • 0 commentsOne of the most challenging current bugs is adding collaborators.
This is supposed to be done by typing "@" followed by a persons username in this box:
However, the drop down menu often only shows one or two names to select. and there is no search function or anything like that. There also seems to be different behaviors for it across browsers.
CriptasticHacker
