ESP Everywhere - Kickstarter Make/100 Project
A very meta project designed solely to be a part of the Kickstarter Make/100 project. An ESP8266 is involved too.
When I learned about Kickstarter doing a Make/100 campaign, I thought it was a very cool idea. Its an Kickstarter Special ESP8266 + FTDI Board where I will only make 100 of them. The Kickstarter has launched! Read more below.
When I learned about Kickstarter doing a Make/100 campaign, I thought it was a very cool idea. Not only does it get people making things, but it also introduces those same people into doing a small production run(<100), a way to get their feet wet if you will. I decided to put together a very quick project - has to be started by the end of January! - to be involved with this campaign. Its not overly complicated, some of you will think its pointless, some of you will love it(I do.), but we can all agree influencing people to become makers is a good thing, and I want to be apart of it.
https://www.kickstarter.com/make100
TL;DR its an ESP8266 with a FTDI on board for programming. 5 GPIOs, 1 ADC and it goes on your keychain. I will only be making 100 of them!
  • 1 × ESP8266 - ESP-12E or ESP-12F Wifi Microcontroller
  • 1 × Special Kickstarter PCB Electronic Components / Misc. Electronic Components
  • 1 × Digikey Components(See BOM) http://www.digikey.ca/short/3wv090
View all 6 project logs
alimainabukar1 wrote 02/09/2017 at 15:58 • point
i am Ali from nigeria a final year student  in computer engineering and am new in this website please some one should help me with project here is my email alimainabukar1@gmail.com please help me
K.C. Lee wrote 02/04/2017 at 13:24 • point
Might want to reconsider the ground fill around that antenna.  You have voided the top, but still blocked the antenna on the back side with that ground fill.
I would recommend leaving *both* the top and bottom an entire *strip* (not just a rectangular cutout) cleared of ground fill as they would interfere with the radiation pattern antenna.  That is unless you have done a proper RF antenna simulation...
Sean Hodgins wrote 02/04/2017 at 17:36 • point
Yeah, you're correct, I am planning on removing more ground layer from the upper area of the component side. I will probably leave the copper on the design side for aesthetics purposes.  There wasn't a significant decrease in performance(if any) on the other boards I've made that have similar designs. If you're looking for extreme range, there are plenty of better ESP boards out there! Haha
K.C. Lee wrote 02/04/2017 at 17:47 • point
You have to clear the back side too in the inverted F area. See they voided any ground in the antenna section.  The radiation is 3D with half of it going into the back side.
Having a ground will affect the distribution pattern.
www.ti.com/lit/an/swra161b/swra161b.pdf‎
ksemedical wrote 01/30/2017 at 16:44 • point
sounds great. But I would like to ask about potential backdoors in the design. I know that is not a question that can be answered (or can it, if so, please I, and I think others would like to know).
Not trying to be negative at all, sounds like a cool project, but these days, because of the factors like google and several other 'companies' being born out (and made to be dominant goliath companies which was inextricably linked to both internal funding and utilization of both legal and subterfuge (including mafia) networks and spying on the average individual (for the sake of total state control (orwellian stuff yes) ) .
I very much like Hackaday so far, but I will ask these questions (sorry again, no offense ot the project, probably good work, it did feel a bit canned though.. )
Jarrett wrote 02/03/2017 at 23:48 • point
what
ksemedical wrote 02/04/2017 at 03:01 • point
Craig below addressed some of my questions, forgive the newbie (me) and my somewhat paranoid comment/question. I do think this is a valid question to ask in general, but certainly want to say, the people here do seem above all that. Thanks Craig for explaining for me, I do think the project looks good. The resources here are to notch in skills and supportive, I love it.
Craig Hissett wrote 02/04/2017 at 01:49 • point
There are many, many projects similar to this in this site. All open source, all available for other users to look at, take inspiration from and make their own versions.
Iv'e ordered new of these as they are great. I've got two very similar in design to this from other Hackaday.io users.
This board is as safe as you code it to be. If you do not want back doors, don't leave any :-)
ksemedical wrote 02/04/2017 at 01:59 • point
Thank you, I just had to ask the question, and wanted it to be addressed. More detail (as time proceeds) will be appreciated. I do not mean to instill fear, it is a relevant question, and I do think the folks here are quite solid, please tolerate my concerns, as they are not without reason. Thanks for the feedback, and would like to be more educated in this area.
davedarko wrote 02/04/2017 at 06:45 • point
it's not like a linux based IP camera that runs a telnet console with standard credentials, if you mean that, far from that. If you yourself don't place over-the-air programming in the code, then the only way to make it do something else is physical access for reprogramming the chip. It's like a bigger arduino with a com port that speaks WiFi. If you make it turn on your lights or switch something big like a remote controlled fire place, then it's up to you to ensure safety.
ksemedical wrote 02/04/2017 at 08:06 • point
Gotcha, thanks for that. I think I must have just come from a session on reddit, where it's become a bit of  a snake pit (that's all political infiltration though ;)
But thanks for expanding on it, I am new here and still a bit overwhelmed with all the cool stuff, kinda hard to focus as of yet, a bit like a kid in the candy shop :), Most of the stuff I have only skimmed over, great place.
yasha0x80 wrote 01/26/2017 at 07:51 • point
Love the looks
Sean Hodgins wrote 01/30/2017 at 16:48 • point
Thanks!
