1Step 1
Arduino sketch:
#include <Servo.h>
Servo myservoLeft,myservoRight, myservoCenter,myservoWeight; // create servo object to control a servo
int servoRead(int servoNumber) {
int servoCurrent;
if (servoNumber== 3) { servoCurrent = myservoLeft.read(); }
if (servoNumber== 4) { servoCurrent = myservoCenter.read(); }
if (servoNumber== 5) { servoCurrent = myservoRight.read(); }
return servoCurrent;
void servoWrite(int servoNumber, int offset) {
if (servoNumber==3) { myservoLeft.write(offset); }
if (servoNumber==4) { myservoCenter.write(offset); }
if (servoNumber==5) { myservoRight.write(offset); }
void myServo(int newAngle,int angleInc,int incDelay,int servoNum) {
int curAngle;
if (servoNum== 1) { curAngle = myservoLeft.read(); }
if (servoNum== 2) { curAngle = myservoCenter.read(); }
if (servoNum== 3) { curAngle = myservoRight.read(); }
if (servoNum== 4) { curAngle = myservoWeight.read(); }
if (curAngle < newAngle) {
for(int angle=curAngle;angle < newAngle;angle += angleInc) {
if (servoNum == 1) myservoLeft.write(angle);
if (servoNum == 2) myservoCenter.write(angle);
if (servoNum == 3) myservoRight.write(angle);
if (servoNum == 4) myservoWeight.write(angle);
delay(incDelay); }
else if (curAngle > newAngle) {
for(int angle=curAngle;angle > newAngle;angle -= angleInc) {
delay(incDelay); }
void interpolate3Servos( int servo3,int servo3Position,
int servo4,int servo4Position,
int servo5,int servo5Position,
int numberSteps,int timeDelay){
int servo3Current,servo4Current,servo5Current;
servo3Current = servoRead(servo3);
servo4Current = servoRead(servo4);
servo5Current = servoRead(servo5);
Serial.print("Servo3Pos and Current "); Serial.print(servo3Position); Serial.print(" "); Serial.println(servo3Current);
Serial.print("Servo4Pos and Current "); Serial.print(servo4Position); Serial.print(" "); Serial.println(servo4Current);
Serial.print("Servo5Pos and Current "); Serial.print(servo5Position); Serial.print(" "); Serial.println(servo5Current);
Serial.println(" ");
int cOffset = (servo3Position - servo3Current); cOffset = abs(cOffset)/numberSteps;
int dOffset = (servo4Position - servo4Current); dOffset = abs(dOffset)/numberSteps;
int eOffset = (servo5Position - servo5Current); eOffset = abs(eOffset)/numberSteps;
int cOffsetTotal=0,dOffsetTotal=0,eOffsetTotal=0;
cOffsetTotal = servo3Current;
dOffsetTotal = servo4Current;
eOffsetTotal = servo5Current;
for (int x=0; x<numberSteps;x++) {
if (servo3Position > servo3Current) { cOffsetTotal = cOffsetTotal + cOffset; }
else { cOffsetTotal = cOffsetTotal - cOffset; }
if (servo4Position > servo4Current) { dOffsetTotal = dOffsetTotal + dOffset; }
else { dOffsetTotal = dOffsetTotal - dOffset; }
if (servo5Position > servo5Current) { eOffsetTotal = eOffsetTotal + eOffset; }
else { eOffsetTotal = eOffsetTotal - eOffset; }
if (servo3Position != servo3Current) servoWrite(servo3,cOffsetTotal);
if (servo4Position != servo4Current) servoWrite(servo4,dOffsetTotal);
if (servo5Position != servo5Current) servoWrite(servo5,eOffsetTotal);
// Serial.print(" a and b Offset "); Serial.print(aOffsetTotal); Serial.print(" ");Serial.println( bOffsetTotal); delay(10);
delay(timeDelay);
}// end for
// take care of modulo remainders //
if (servo3Position != servo3Current) servoWrite(servo3,servo3Position);
if (servo4Position != servo4Current) servoWrite(servo4,servo4Position);
if (servo5Position != servo5Current) servoWrite(servo5,servo5Position);
void leftArm() {
interpolate3Servos( 3,170,4,140,5,150,20,50); //
delay(500);
interpolate3Servos( 3,90,4,120,5,150,20,50); // shift monkey right
delay(500);
myServo(90,1,1,2); // let go of left hook
delay(500);
interpolate3Servos( 3,40,4,100,5,70,20,50); //
delay(500);
interpolate3Servos( 3,20,4,90,5,20,20,50); //
delay(1000);
interpolate3Servos( 3,20,4,90,5,10,20,50); // extend left arm up
delay(1000);
myServo(120,1,1,2); // grab left hook
delay(1000);
interpolate3Servos( 3,20,4,110,5,70,20,50); // shift monkey left
delay(500);
interpolate3Servos( 3,30,4,90,5,50,20,50); // let loose right arm
delay(500);
interpolate3Servos( 3,30,4,80,5,55,20,50); // let loose right arm
delay(1000);
interpolate3Servos( 3,130,4,85,5,150,10,50); // pull right arm up to left peg
delay(1000);
interpolate3Servos( 3,150,4,160,5,150,20,50); // reach right arm up to right peg
delay(500);
interpolate3Servos( 3,130,4,140,5,140,20,50); // reach right arm up to right peg
delay(500);
interpolate3Servos( 3,120,4,130,5,140,20,50); // reach right arm up to right peg
delay(500);
interpolate3Servos( 3,110,4,110,5,150,20,50); // reach right arm up to right peg
delay(500);
interpolate3Servos( 3,110,4,90,5,150,20,50); // reach right arm up to right peg
// last arm movement
interpolate3Servos( 3,80,4,100,5,70,20,50); // reach right arm up to right peg
delay(500);
interpolate3Servos( 3,70,4,90,5,10,20,50); // reach right arm up to right peg
delay(500);
interpolate3Servos( 3,40,4,140,5,0,20,50); // reach right arm up to right peg
delay(500);
interpolate3Servos( 3,40,4,140,5,100,20,50); // reach right arm up to right peg
delay(500);
delay(15000);
exit(0);
void setup()
Serial.begin(9600);
delay(100);
myservoLeft.attach(3); // attaches the servo on pin 3 to the servo object
myservoLeft.write(90);
myservoCenter.attach(4); // attaches the servo on pin 4 to the servo object
myservoCenter.write(90);
myservoRight.attach(5); // attaches the servo on pin 5 to the servo object
myservoRight.write(90);
delay(1000); // waits for the servo to get there
interpolate3Servos( 3,90,4,90,5,90,10,50); // neutral
delay(500);
void loop() {
leftArm();
// delay(1000);
exit(0); //pause program - hit reset to continue
jimrd
