Pause for Supercon
09/17/2024 at 13:16 • 0 commentsThis project is pausing through the end of 2025 because I am sending in the Core64+Neon Pixels demo to be displayed:
https://hackaday.com/2024/08/26/supercon-2024-show-off-your-unique-display-tech/
The next phase of the project is to build the big-banging required to drive the Serial Shift Registers. That should relatively straightforward since it's not much different than the code to drive the Neon Pixels.
Neon Pixels under 65uino control!
08/29/2024 at 04:52 • 0 commentsFinally got what is in ROM to show up correctly on the Neon Pixels!!!
Need to troubleshoot why the second push of the same data is shifted right by one pixel. I think the bit twiddles might be off by a bit, or a byte.
Andy Geppert
