Servo motor board design considerations
A project log for Renovation of the E004 audio tape recorder
A low-cost, high-quality tape recorder with a cross-board architecture.
h2wh2w 08/02/2024 at 10:580 Comments
A board from another developer uses a three-pin connector. This is a very simple and inexpensive solution. The pin-out of the connector is shown below.
  1. GND - the ground for power and signal
  2. +24V - the power for the servomotor
  3. DIR - the direction signal: 0 - rotate CW, 1 - rotate CCW
The motor stops by itself when the marker reaches the optical sensor.
The disadvantages of this are:
Solution 1 - With RS485
For more complete control you can use RS485 interface. Then there will be a pinout.
  1. GND - power ground
  2. +24V - power
  3. A - RS485
  4. B - RS485
However, this will require a microcontroller and interface converter to be installed on the board. This makes the construction more expensive.
Solution 2 - With I2C
It will be a little cheaper if you use I2C interface.
  2. +24V - power
  3. GND - signal ground
  4. SCL - I2C
  5. SDA - I2C
Solution 2 - Passive
In this case only the motor driver is installed on the board. Then the pinout will be as follows.
  2. +24V - power
  4. M1 - motor in1
  5. M2 - motor in2
  6. S1 - sensor 1
  7. S2 - sensor 2
Conclusion
Tough choice considering the connectors and wires cost their money too. However, the RS485 option looks like the most noise-protected and therefore reliable option.
