the-circuit-graver-ii v42.f3zFusion360 model of the mechanical bits, so you can see all of my CAD crimes. Some minor hardware (like bolts and nuts) is missing, and the assembly isn't joined, just aligned.f3z - 13.49 MB - 11/02/2024 at 13:15 |
LICENSE.txtOpen-source license for the mechanical parts of the project! CC-BY-SA 4.0: https://creativecommons.org/licenses/by-sa/4.0/deed.enplain - 19.71 kB - 11/02/2024 at 13:14 |
circuit-graver-3dp.zipPrint with PLA, 15% infill, 5 perimeters, flexures flat to bed, with supports. Fits are tight so prepare for some sanding!x-zip-compressed - 1.08 MB - 10/31/2024 at 00:31 |
circuit-graver-cut.zipCut this file out of 1/4" (6.35 mm) aluminum plate, and tap the requisite holes with M3/M4 taps. See the CAD model.x-zip-compressed - 1.53 kB - 10/31/2024 at 00:33 |
zakqwy
