shaft cover.step
To put on both end of printed base and top shaft (Need 4)
step - 8.16 kB - 12/19/2024 at 19:20
Download
electronic case cover.step
step - 26.75 kB - 12/19/2024 at 19:08
Download
electronic case.step
step - 123.92 kB - 12/19/2024 at 19:08
Download
Arm top grip link.step
for the top actuator (Need 1)
step - 28.63 kB - 12/19/2024 at 18:59
Download
Arm actuator link.step
For the base and middle actuator (Need 2)
step - 12.77 kB - 12/19/2024 at 18:58
Download
Arm grip link.step
(Need 4)
step - 10.96 kB - 12/19/2024 at 18:58
Download
Arm grip.step
(Need 2)
step - 257.31 kB - 12/19/2024 at 18:57
Download
Arm top.step
(Need 1)
step - 62.28 kB - 12/19/2024 at 18:57
Download
Arm middle.step
(Need 2)
step - 32.15 kB - 12/19/2024 at 18:57
Download
Arm base and top shaft.step
(Need 2)
step - 11.07 kB - 12/19/2024 at 18:57
Download
Arm base link.step
(Need 1)
step - 45.42 kB - 12/19/2024 at 18:57
Download
Arm base part R.step.step
(Need 1)
step - 46.19 kB - 12/19/2024 at 18:57
Download
Arm base part L.step
(Need 1)
step - 45.83 kB - 12/19/2024 at 18:57
Download
Motor support.step
Motor support (Need 1)
step - 31.89 kB - 12/19/2024 at 18:46
Download
Motor gear.step
Motor gear (Need 1)
step - 1.10 MB - 12/19/2024 at 18:46
Download
Arm gear.step
Big gear for the hydraulic arm (Need 1)
step - 4.03 MB - 12/19/2024 at 18:46
Download
Wooden base feet middle.step
feet for the wooden base (Need 1)
step - 20.64 kB - 12/19/2024 at 18:36
Download
Wooden base feet corner.step
feet for the wooden base (Need 6)
step - 26.60 kB - 12/19/2024 at 18:36
Download
Wooden Base.dxf
3mm laser cut wooden base of the assembly
AutoCAD DXF - 75.65 kB - 12/19/2024 at 18:35
Download
Hydraulic_arm.ino
Code to upload to your esp32
ino - 9.02 kB - 12/19/2024 at 17:57
Download
CIRCUIT DIAGRAM OF HYDRAULIC ARM
JPEG Image - 610.12 kB - 12/19/2024 at 17:56
Preview
Watertank lasercut.dxf
DXF file to make the watertank with a laser cutting machine
AutoCAD DXF - 108.33 kB - 12/07/2024 at 23:37
Download
Watertank valve support.step
3D PRINT IN PLA
step - 87.41 kB - 12/07/2024 at 23:36
Download
Valve piston gear.step
3D PRINT IN PETG
step - 2.31 MB - 12/07/2024 at 23:35
Download
Valve base.step
3D PRINT IN PETG
step - 1.29 MB - 12/07/2024 at 23:35
Download
Valve servo gear.step
3D PRINT IN PETG
step - 1.04 MB - 12/07/2024 at 23:35
Download
Valve top.step
3D PRINT IN PETG
step - 77.57 kB - 12/07/2024 at 23:35
Download
Valve piston.step
3D PRINT IN PETG
step - 28.06 kB - 12/07/2024 at 23:35
Download
Valve servo support.step
3D PRINT IN PLA
step - 33.31 kB - 12/07/2024 at 23:35
Download
HYDRAULIC DIAGRAM OF HYDRAULIC ARM
Portable Network Graphics (PNG) - 30.74 kB - 12/07/2024 at 19:05
Preview
