I designed the parts with Autodesk Inventor, 3D-printed and re-cast the largest or most complicated parts out of Aluminum 356, and used CNC for the rest. Pistons were machined on a metal lathe and the exosuit was mounted on a tactical plate carrier vest & hips.
The printable STLs are available here and on GitHub. See the assembly instructions if you want to put together one of your own.
My other projects: cyberpunk guitar and drumming robot.
The metal casting process:
Val
mclien
jupdyke
rawe
Kevin Harrington
that is DUCKING AWESOME!!!!
