Introduction.
In this article, a design for a driver for a commercial Ultrafire DV-S9 diving light LED flashlight will be presented. Many clones of this flashlight can be found online at very affordable prices. It is a widely used flashlight in spearfishing. More detailed in: https://luicer.github.io/led%20flashlight/Flashlight-Driver-Lineal-eng/
Driver specifications.
The driver design has the following characteristics:
- Linear type regulator.
- Adjustable current up to 3A.
- Input voltage from 3V to 4.2V.
- Standby current of 4mA.
The block diagram of the proposed design is as follows:
Schematics.
The schematic used to implement the design is the following:
PCB
A two-sided PCB has been designed to fit into the commercial flashlight casing and be easily replaceable. Considerations have been made for the permissible track currents and EMI control rules to ensure reliable current measurement with a small current measuring resistor.
The assembled PCB looks as follows:
BOM.
The bill of required materials is as follows; includes the LCSC component codes.
Measurement of efficiency and operating voltage.
In order to obtain the driver efficiency, measurements have been taken by varying the input voltage between 2.9 V and 4.2 V, measuring both the input voltage and current, as well as the output voltage and current.
The current as a function of input voltage:
The efficiency as a function of input voltage:
We can see that the flashlight is usable from 3 V with an intensity of 1 A and an efficiency of 98% up to 4.2 V with a minimum efficiency of 70%.
Design files and License.
All the documentation for the design, including the KiCad PCB project, manufacturing documents, schematic, and bill of materials, can be found in the following GitHub repository:
https://github.com/luicer/Linear-Flashlight-DV-S9-Driver
This design is open source hardware under the permissive CERN OHL-p V2 license.
Luicer's Lab
Gangwa Labs
About the chapter "Measurement of efficiency and operating voltage", how did you collect the data, manually or did you use some automatization?
