2026 Updates
3 hours ago • 0 comments- Option to turn screen oriëntation in 4 directions from command line and interpeter command
- Change brightness (0-100%) from command line and interpeter
- Updates in the example projects to show the new options
- Several stability improvements
2025 Updates
01/23/2025 at 15:59 • 0 commentsSome updates are currently available:
- Integration with json. You can now add and extract a layout in json format from the SD card.
- Menu over a virtal serial com port with USB-C cable where you can load and activate multiple layouts (images + json), clear the memory, request device info, set the clock and perform a secure firmware update.
- Integration with mcuboot to upload a signed and encrypted image.
- Setup of 2 demo applications (fogger and home automation) that are available on a SD card. They show the possibilities to interact with digital IO and an external Python script over the command interface.
- Devices can now be ordered on Robotshop and Tindie.
- Update of documentation and datasheet.
History
10/08/2024 at 14:43 • 0 comments28/08/2025: Integration of user defined fonts.
Sam Lefebvre
