This project focuses on creating a low-cost, refreshable Braille display cell that is smaller and more affordable than current designs. My design features PCB coils for easier manufacturability and a lower profile. The physical braille cell is SLA printed using ABS-like resin. I aim to reduce power draw and overheating by increasing the resistance of the coils and implementing a bistable mechanism to reduce the time during which the coil is on.
Unfortunately, I ran into some hiccups with the v4 PCB, and since it mostly involves small SMD components, debugging it proved difficult. Instead, I pivoted to testing some basic shift register logic with a more well document shift register, the 74HC595, with the Arduino Nano. Below is a video of 3x2 braille cell-style array of LEDs flashing through the braille alphabet while being controlled by the shift register.
The Arduino code can be found in braille_flash.ino in the GitHub.
Next Steps:
I will try to control an H-bridge IC with the shift register and hopefully be able to control current flow through the coils. Once that works, I will begin designing the v5 PCB implementing these new shift register/h-bridge ICs.
Researched different ICs for controlling a full 6-dot braille cell.
TLC6C5912-Q1 12-bit shift register, to control all 12 outputs associated with the full cell. Two outputs are required for each dot to drive current in both directions.
DRV8212DRLR H-bridge motor driver IC, to take digital signal from shift register and enable current flow in a specified direction.
First prototype PCB design consists of two coil setups, one of which is a single layer, the other being a two layer version, connected in series. Each coil is 6mm in diameter with a 0.15mm trace width/clearance, and approximately 9 turns per layer.
PCB design:
CAD model:
M2 bolts will be used to align and fasten the outer 'chamber' part over the center of the coil.
The two parts were printed on the Creality Halot Lite SLA 3D-printer using clear ABS-like resin.
