v4 Parts + PCB Assembly
a day ago • 1 commentUpdate 3/11/2025:
Shift Register and H-Bridge ICs arrived, and PCBs arrived. Soldered SMD components on using microscope and fine soldering tip.
Next Steps:
Write Arduino code to control shift register and send input signals to H-Bridge ICs.
PCB v4 Schematic & Design
12/18/2024 at 03:27 • 0 commentsUpdate 12/17/2024:
Researched different ICs for controlling a full 6-dot braille cell.
TLC6C5912-Q1 12-bit shift register, to control all 12 outputs associated with the full cell. Two outputs are required for each dot to drive current in both directions.
DRV8212DRLR H-bridge motor driver IC, to take digital signal from shift register and enable current flow in a specified direction.
Completed PCB v4 design:
3D render:
KiCad design:
Completed PCB v4 Schematic:
(coils not shown)
PCB Arrival, Completed First Prototype + Successful Initial Testing
11/14/2024 at 06:17 • 0 commentsUpdate 11/13/2024:
PCB Arrival
PCBs arrived from JLCPCB (pictured below)
Completion of First Prototype
Soldered pin headers, bolted 3D-printed assembly to PCB
Successful Testing
See video
Printed first prototype parts, Designed first prototype PCB
11/04/2024 at 21:18 • 0 commentsUpdate 11/04/2024
First prototype PCB design consists of two coil setups, one of which is a single layer, the other being a two layer version, connected in series. Each coil is 6mm in diameter with a 0.15mm trace width/clearance, and approximately 9 turns per layer.
PCB design:
CAD model:
M2 bolts will be used to align and fasten the outer 'chamber' part over the center of the coil.
The two parts were printed on the Creality Halot Lite SLA 3D-printer using clear ABS-like resin.
Printed parts (microSD for scale):
