Update 3/11/2025:
Shift Register and H-Bridge ICs arrived, and PCBs arrived. Soldered SMD components on using microscope and fine soldering tip.
Next Steps:
Write Arduino code to control shift register and send input signals to H-Bridge ICs.
A project log for Refreshable Braille Display
Refreshable Braille Display powered by PCB electromagnets
Man, this is magnificent work! Congrats! How did you came up with the specs for the pcb coils? Was it trial and error, or you calculated it?
