v4 Parts + PCB Assembly
A project log for Refreshable Braille Display
Refreshable Braille Display powered by PCB electromagnets
basim-cheema-sabirBasim Cheema-Sabir a day ago1 Comment
Update 3/11/2025:
Shift Register and H-Bridge ICs arrived, and PCBs arrived. Soldered SMD components on using microscope and fine soldering tip.
Next Steps:
Write Arduino code to control shift register and send input signals to H-Bridge ICs.
BRUNO RAFAEL DE OLIVEIRA MARTINS wrote a day ago point
Man, this is magnificent work! Congrats! How did you came up with the specs for the pcb coils? Was it trial and error, or you calculated it?
