• v4 Parts + PCB Assembly
    Basim Cheema-Sabira day ago 1 comment
    Update 3/11/2025:
    Shift Register and H-Bridge ICs arrived, and PCBs arrived. Soldered SMD components on using microscope and fine soldering tip.
    Next Steps:
    Write Arduino code to control shift register and send input signals to H-Bridge ICs.
  • PCB v4 Schematic & Design
    Basim Cheema-Sabir12/18/2024 at 03:27 0 comments
    Update 12/17/2024:
    Researched different ICs for controlling a full 6-dot braille cell.
    TLC6C5912-Q1 12-bit shift register, to control all 12 outputs associated with the full cell. Two outputs are required for each dot to drive current in both directions.
    DRV8212DRLR H-bridge motor driver IC, to take digital signal from shift register and enable current flow in a specified direction.
    Completed PCB v4 design:
    3D render:
    KiCad design:
    Completed PCB v4 Schematic:
    (coils not shown)
  • PCB Arrival, Completed First Prototype + Successful Initial Testing
    Basim Cheema-Sabir11/14/2024 at 06:17 0 comments
    Update 11/13/2024:
    PCB Arrival
    PCBs arrived from JLCPCB (pictured below)
    Completion of First Prototype
    Soldered pin headers, bolted 3D-printed assembly to PCB
    Successful Testing
    See video
  • Printed first prototype parts, Designed first prototype PCB
    Basim Cheema-Sabir11/04/2024 at 21:18 0 comments
    Update 11/04/2024
    First prototype PCB design consists of two coil setups, one of which is a single layer, the other being a two layer version, connected in series. Each coil is 6mm in diameter with a 0.15mm trace width/clearance, and approximately 9 turns per layer.
    PCB design:
    CAD model:
    M2 bolts will be used to align and fasten the outer 'chamber' part over the center of the coil.
    The two parts were printed on the Creality Halot Lite SLA 3D-printer using clear ABS-like resin.
    Printed parts (microSD for scale):
