v4 Parts + PCB Assembly
A project log for Refreshable Braille Display
Refreshable Braille Display powered by PCB electromagnets
basim-cheema-sabirBasim Cheema-Sabir a day ago1 Comment
Update 3/11/2025:
Shift Register and H-Bridge ICs arrived, and PCBs arrived. Soldered SMD components on using microscope and fine soldering tip.
Next Steps:
Write Arduino code to control shift register and send input signals to H-Bridge ICs.
BRUNO RAFAEL DE OLIVEIRA MARTINS wrote 21 hours ago point
Man, this is magnificent work! Congrats! How did you came up with the specs for the pcb coils? Was it trial and error, or you calculated it?
