The microcontroller is upgraded to ESP32-S3 with 8MB of PSRAM, allowing better memory-exhaustive applications like audio processing, machine learning, and real-time applications. Especially, using the built-in coding interface via WiFi will not cause Memory Allocation Error problem again. Upgrading to ESP32-S3 also means more GPIOs to spare, and connecting external peripherals like a camera module is now possible.
We also took inspiration from ESP32-S3-Korvo-2 V3.0 to design the PCB's audio module, with dedicated audio CODEC for I2S speaker and stereo microphone, allowing users to interact with robots using voice commands, and even connect to ChatGPT for prompt responses.
The 3D printing parts are improved and extended to different robotic designs: wheels (Ackermann and leg-wheel hybrid), quadruped, humanoid, and game console. To seamlessly switch between designs, we decouple the electronics, such that design-dependent electronics are grouped into a separate PCB and placed within the mechanical frame of each design, called mechanical board.
Nguyễn Phương Duy
Josh
therobotstudio
