PCBs on hand!
02/22/2025 at 13:19 • 0 commentsHey all!
P R O G R E S S ~ The dev boards have entered the building!![]()
As you can see, I may have made a few small mistakes in the routing, but in my defence, I'm new at this, so I only smashed one of my shins with a hammer as penance.
Since I had 5 boards assembled, there are a couple more in the wild right now.![]()
I'm back to working with software again for now, and I'll provide some updates when that's nearing completion.
Stay tuned!
Debug PCBs on the way!
02/09/2025 at 23:35 • 2 commentsHey everyone!
Sorry for the lack of updates—I’ve been busy working on things behind the scenes.
The first board order had some issues, so I switched to a cheaper, slightly larger board for debugging. Once everything is sorted, I’ll port the changes back to the smaller board.
Here’s a sneak peek:
I’ll post more updates as soon as these arrive!
Updated CAD Model!
12/13/2024 at 01:24 • 1 commentHey all! Been beavering away with Fusion360 trying to make all the components fit nicely - see some cheeky pics.
The neat-ish side:
The dirty side:
I'm not 100% sold on the speaker hole. It uses a smartphone speaker and seems compact enough to give me a little free space on the board, but I might swap it out for a slightly larger model if we don't need that extra space next to the screen for anything.
Here's the speaker currently in use:![]()
Seems pretty decent for the size!
And here's the latest version with the screen and speaker in place (excuse the quality of the 3D print, I'm on the dregs of the roll now).![]()
That's it for now! I have some sample PCBs on order to test some power rail designs for efficiency and such. If all goes well, we should have some initial versions of the board early January.
Thanks for having a look!
Catch you soon! -
Thermal Sensor up and running!
12/08/2024 at 22:20 • 0 commentsHey all!
Managed to find time this weekend to have a play with the thermal camera and have popped together a sample application to check everything works as expected.
After much tinkering, I've managed to get a screengrab off the board to share with you all!![]()
A little thermal selfie there!
There's probably a little more performance to be squeezed out of the system, but hey - something is better than nothing!
I have some more final case designs to share soon and some sample PCBs to test the various systems.
Updates will be intermittent as always!
Stay safe! -
3D Printed cases in!
11/21/2024 at 11:42 • 0 commentsJust received the prints from JLCPCB, and honestly, it's a mixed bag. I know I was probably expecting too much given the price of the service, but if my cheap Bambu A1 Mini can do better… well, that's a yikes from me.
I had high hopes for the SLS 3201PA-F Nylon (black) and MJF PA12-HP Nylon (grey) prints, but these were definitely the most disappointing.
First impressions were promising: the parts feel tough and flexible, with a nice surface finish and a robust overall feel.
On the downside, both sets of nylon parts came out at different sizes. The front and back halves are undersized by varying amounts, so none of the screw holes line up. Comparing them to my home printer's FDM parts, they’re around 1mm smaller in both the X and Y dimensions.
The SLA resin parts (bottom-left white part in 9600 Resin and back-right off-white mystery resin), however, were mostly a win. I’m amazed you can get prints of this quality for as little as $0.66. The resin parts are tough, just flexible enough to allow the keyboard to actuate nicely, and have a good surface finish with fine text details coming through well.
That said, the walls on the resin prints aren’t perfectly square, which makes aligning the two case halves a challenge. It’s probably worth ordering another round of all the different resins to compare dimensional stability and find the right level of flexibility for the keycaps.
Since then, I’ve made some progress on the 3D model to better fit the screen and speakers. The next update will feature a more finalized version of the casing.
Excuse the poor quality images, I'm terrible at documenting stuff! -
Casing samples on the way!
11/14/2024 at 08:26 • 0 commentsI had no idea SLS 3D printing had become so cheap!
To me this is crazy good value, got a bunch of different material/ 3D printing methods arriving in the next few days, this will mean the small batch I intend to produce wont have to be printed on my poor lil bambu a1 mini.
As the keycaps are a built into the shell via some pretty thin plastic ordering these parts meant agreeing that the prints would likely fail, I guess I'll find out soon.
