Gesture and Voice-Controlled Home Automation System
Introduction
Welcome to a project that redefines the way the defines the way we interact with home automation Using the power of DFRobot Gravity GR10-30 Gesture Sensor and DFRobot Gravity Offline Language Learning Voice Recognition Sensor, this system offers an intuitive and futuristic way to control appliances. This project combines two cutting-edge technologies from DFRobot a trusted name in the open source hardware community.
What Makes This Project Unique?
This isn't your regular home automation project. it's powered by advanced DFRobot Gravity GR10-30 Gesture Sensor with 12 distinct gestures and DFRobot Gravity Offline Language Learning Voice Recognition Sensor all offline, it's privacy-focused, fast, and reliable-perfect for smart homes of the future.
Story Behind the Project
The idea for this project was born from a desire to create something truly futuristic-a system that feels like it's straight out of a sci-fi movie. Imagine walking into the a room, swiping your hands to control lights, or saying a command to turn on appliances, all without touching a switch!
Challenges and Learning
Building this wasn't easy. Integrating multiple sensors, ensuring the real-time responsiveness, and achieving seamless operations, prototyping, and countless hours of coding. However, the journey was worth it, resulting in a project that's not only functional but also truly innovative. The DFRobot sensors played a significant role in simplifying this process. Their ability to switch seamlessly between I2C and UART communication made with integration much easier and more efficient.
DFRobot: Providing This Innovation
DFRobot is a leading innovator in open source hardware, offering a wide range of high quality sensors, controllers, and modules. Their products are known for their user friendliness, reliability and comprehensive documentation, making them a favorite among the developers and hobbyists alike
The Gravity series is DFRobot's flagship line of of plug-and-play modules, designed for ease of use. These modules come with Product Wiki, Extensive Compatibility and Robust Design
The Boson Series by DFRobot is a modular, plug and play system of over 50 electronic building blocks designed for creators, educators, and hobbyists. It simplifies prototyping with color-coded, solder free modules like sensors, actuators, and logic controls. It is Ideal for STEAM education and DIY Projects. its user friendly design, robust safety features, and detailed wikis make it perfect for beginners and professional alike, enabling quick and hassle free project development.
Components Used in This Project
1. Gravity: GR10-30 Gesture Sensor
- Recognizes up to 12 gestures.
- Supports both UART and I2C communications.
- Adjustable recognition distance up to 30cm.
- Ideal for gesture-based control in smart devices.
- ProductWiki for more information
2. Gravity: Voice Recognition Module
- Offline voice recognition with 121 pre-programmed commands.
- Supports 17 custom command words and custom wake words.
- Compatible with Arduino, micro:bit, and ESP32.
- Provides instant voice feedback and operates without a network.
3. Arduino Mega 2560
- High-performance microcontroller with multiple I/O pins.
- Ensures seamless integration of multiple sensors.
- Reliable for real-time data processing and control.
4. 4-Channel Relay Module
- Enables the control of high-power devices like lights and fans.
- Compatible with lower-power microcontroller outputs.
- Provides isolation for safe operation.
5. Connecting Cables & Power Supply
- Used to connect sensor and modules.
- Provides stable and efficient power to the entire system.
Features of the Project
Gesture Control:
- Swipe right: Change the position of the relay from 1 to 2 to 3 to 4.
- Swipe left: Change the position of the relay...
Rohan Barnwal
Pedro Minatel
SirClover
ehughes
