Schematic_Joule_Thief_updated_2025-02-01.pdf
Adobe Portable Document Format - 35.84 kB - 02/01/2025 at 17:41
Preview
Research_Extension_base.3mf
This is an optional part, It is a prototyping board extension, under the base of the Lumin Lamp so you can fit a 12 way terminal block and swap wires easily around
3mf - 22.50 kB - 01/30/2025 at 19:28
Download
base_for_USA.3mf
Lumin Lamp Base Modified to fit a ceramic E27 Base fitting compatible with US E26 light blubs
3mf - 30.66 kB - 01/30/2025 at 13:39
Download
base_for_Europe.3mf
Lumin Lamp Base for fitting Byonnet light blubs.
3mf - 34.25 kB - 01/30/2025 at 13:39
Download
Lumin_Lamp v23.f3d
Master File Fusion 360 Containing the whole lamp and frame
f3d - 7.27 MB - 01/30/2025 at 13:39
Download
Gerber_Lumin_lamp_2025-01-22.zip
This is the PCB used with the Lumin Lamp, it is the Original Joule Thief Circuit.
Zip Archive - 22.00 kB - 01/26/2025 at 20:33
Download
Coil_frame.3mf
This frame is swappable so you can build different style coils on it. An example on how to wind the Caduceus coil: https://youtu.be/SRXiW_vOyWk?si=xvpXtZkyhXbagQMt
3mf - 20.06 kB - 01/26/2025 at 20:28
Download
board_feet.3mf
Those fits will require M3 pan head bolts and nuts. I will add a list to purchase parts.
3mf - 13.36 kB - 01/26/2025 at 20:27
Download
coverv3.3mf
This is optional, just to protect the components and for safety.
- 14.54 kB - 01/27/2025 at 21:33
Download
lamp_caps.3mf
This is used to hold the Ceramic Base holder down using M3 pan head bolts and nuts.
3mf - 9.27 kB - 01/26/2025 at 20:27
Download
bracket_v2.3mf
This is optional to support the cover which protects the PCB
3mf - 6.39 kB - 01/26/2025 at 20:27
Download
