• 11/03/24 : Progress log
    louis.dupreya day ago 0 comments
    Speed regulation of the system will be done using a governor.
    Found what kind of governor to use (Watt governor, fully gravity driven)
    Started to look at requirements for manufacturing
    Fine tuning will be done once prototype is assembled
    started model of worm gear and handle.
  • 04/03/2025
    luis.ramirez-ramirez03/04/2025 at 09:47 0 comments
    • Recived the kalimba. We worked with fusion 360°to upload the kalimba into the program then we measured the, angles, and size of the cylinder to fit the kalimba and the tines(notes).
  • 25/02 Progress log
    louis.duprey03/04/2025 at 09:35 0 comments
    Decision upon the actual project : making a music box
    Research of requirements for said project
    Identification of 4 main requirements for it : resonance chamber, metal prongs, cylinder, rotation mechanism
    The first two requirements are solved by using a kalimba as a base.
    Working on the other two
