DiffProbeCase.zip
Contains the FreeCAD project, STEP and the STL files for the lid and housing. If you have a 3D printer you can print a case for the probe. You can modify them if you have FreeCAD installed on your computer. (Previous ZIP file was corrupt. This one should be good.)
x-zip-compressed - 5.37 MB - 11/14/2025 at 16:38
Download
VREG-DiscreteDB.zip
Gerber Files and BOMs to make a discrete voltage regulator daughter board.
x-zip-compressed - 243.59 kB - 11/13/2025 at 16:22
Download
10MHzDiffProbe.zip
Gerber Files and BOMs to make a 10MHz Diff Probe.
x-zip-compressed - 1.02 MB - 10/22/2025 at 21:08
Download
VREG-SOIC8_DB.zip
Gerber Files and BOMs to make a SOIC8 voltage regulator daughter board. Changes to schematic to add snubber. Changes to layout to move SOIC away from SMA housing.
x-zip-compressed - 232.58 kB - 10/22/2025 at 01:09
Download
100MHzDiffProbe.zip
Gerber Files and BOMs to make a 100MHz Diff Probe.
x-zip-compressed - 1.10 MB - 09/06/2025 at 15:22
Download
1MHzDiffProbe.zip
Gerber Files and BOMs to make a 1MHz Diff Probe.
x-zip-compressed - 913.58 kB - 09/02/2025 at 04:18
Download
BuckConverterDB.zip
Gerber Files and BOMs to make a buck converter voltage regulator daughter board.
x-zip-compressed - 205.76 kB - 08/28/2025 at 22:43
Download
VREG-SOT89DB.zip
Gerber Files and BOMs to make a SOT89 voltage regulator daughter board.
x-zip-compressed - 149.37 kB - 08/28/2025 at 22:40
Download
USB-B_GenericDB.zip
Gerber Files and BOMs to make a generic USB-B micro daughter board.
x-zip-compressed - 489.40 kB - 08/28/2025 at 22:39
Download
