generating firmware
07/22/2025 at 15:03 • 0 commentsdownload and setup qmk.
create a new keyboard:
![creating a new keyboard using qmk creating a new keyboard using qmk]()
create a new keymap:
![generating a keymap for your keyboard generating a keymap for your keyboard]()
customize the keymap to fit your keyboard and its wiring. my files are attached below.
keyboard.json
{ "manufacturer": "Manbir Singh", "keyboard_name": "stenokeyboard", "maintainer": "0-manbir", "development_board": "promicro", "diode_direction": "COL2ROW", "features": { "bootmagic": true, "extrakey": false, "mousekey": false, "nkro": false }, "matrix_pins": { "cols": ["F7", "B1", "B3", "B2", "B6", "B5", "B4", "E6", "D7", "C6"], "rows": ["D1", "D0", "D4"] }, "url": "", "usb": { "device_version": "1.0.0", "pid": "0x0000", "vid": "0xFEED" }, "layouts": { "LAYOUT": { "layout": [ { "matrix": [0, 0], "x": 0, "y": 0 }, { "matrix": [0, 1], "x": 1, "y": 0 }, { "matrix": [0, 2], "x": 2, "y": 0 }, { "matrix": [0, 3], "x": 3, "y": 0 }, { "matrix": [0, 4], "x": 4, "y": 0 }, { "matrix": [0, 5], "x": 5, "y": 0 }, { "matrix": [0, 6], "x": 6, "y": 0 }, { "matrix": [0, 7], "x": 7, "y": 0 }, { "matrix": [0, 8], "x": 8, "y": 0 }, { "matrix": [0, 9], "x": 9, "y": 0 }, { "matrix": [1, 0], "x": 0, "y": 1 }, { "matrix": [1, 1], "x": 1, "y": 1 }, { "matrix": [1, 2], "x": 2, "y": 1 }, { "matrix": [1, 3], "x": 3, "y": 1 }, { "matrix": [1, 4], "x": 4, "y": 1 }, { "matrix": [1, 5], "x": 5, "y": 1 }, { "matrix": [1, 6], "x": 6, "y": 1 }, { "matrix": [1, 7], "x": 7, "y": 1 }, { "matrix": [1, 8], "x": 8, "y": 1 }, { "matrix": [1, 9], "x": 9, "y": 1 }, { "matrix": [2, 3], "x": 3, "y": 2 }, { "matrix": [2, 4], "x": 4, "y": 2 }, { "matrix": [2, 5], "x": 5, "y": 2 }, { "matrix": [2, 6], "x": 6, "y": 2 } ] } } }rules.mk
# Base MCU = atmega32u4 BOOTLOADER = caterina # Enable Steno STENO_ENABLE = yes STENO_PROTOCOL = geminipr EXTRAKEY_ENABLE = no MOUSEKEY_ENABLE = no CONSOLE_ENABLE = no COMMAND_ENABLE = no NKRO_ENABLE = no UNICODE_ENABLE = no BACKLIGHT_ENABLE = no AUDIO_ENABLE = nokeymap.c
// Copyright 2023 QMK // SPDX-License-Identifier: GPL-2.0-or-later #include QMK_KEYBOARD_H #include "process_steno.h" const uint16_t PROGMEM keymaps[][MATRIX_ROWS][MATRIX_COLS] = { [0] = LAYOUT( STN_S1, STN_TL, STN_PL, STN_HL, STN_ST1, STN_FR, STN_PR, STN_LR, STN_TR, STN_DR, STN_S2, STN_KL, STN_WL, STN_RL, STN_ST2, STN_RR, STN_BR, STN_GR, STN_SR, STN_ZR, STN_A, STN_O, STN_E, STN_U ) };compile the firmware
flash the firmware using AVRdude or QMK Toolbox
download and install Plover. set the machine to Gemini PR.
go to configure, and select the right port.
wiring the switches
07/22/2025 at 14:50 • 0 commentsputting in the switches
soldering diodes to one leg of each switch
wiring rows using a 16-gauge copper wire
wiring columns
connecting each column (10) and row (3) to the dev board
building a case
07/22/2025 at 14:37 • 0 commentssoftware needed
- autodesk fusion 360
building the plate
open any 3d modeling/cad/cam software. i used fusion 360. load the .dfx file (find sample in the files section). extrude to form a plate.
building a case
build a case to hold the plate.
planning the layout
07/22/2025 at 14:26 • 0 commentssoftware needed:
designing the layout
i designed the layout for my steno keyboard using Keyboard Layout Editor.
![steno keyboard layout steno keyboard layout]()
raw data (or click here):
["S","T","P","H","*","F","P","L","T","D"], ["S","K","W","R","*","R","B","G","S","Z"], [{y:0.25,x:2.5},"A","O","E","U"]
generating the plate
copy the raw JSON data from KLE and paste it into 'plate layout' in swillkb. export as a .dxf file.
![swillkb keyboard plate properties swillkb keyboard plate properties]()
manbir
