Assembling
08/10/2025 at 02:50 • 0 commentsThe circuit was assembled on the plywood case and tested. The bottom will receive a felt sheet to protect the circuit and soften the contact with the surface of the table where I will leave the pomodoro timer. I will do it later because my glue gun broke.
Plywood Case
08/10/2025 at 02:43 • 0 commentsI have built a plywood case for the project. The cuts were manually routed. The case was sanded and covered with carnauba wax.
Save to EEprom, Case
07/25/2025 at 11:45 • 0 commentsBrightness level is now saved to EPROM. Also cleaned up the logic.
Planning to make a case using plywood and the dome of a LED lignt bulb
Brightness setup
07/25/2025 at 04:45 • 0 commentsAdded a brightness setup mode. When in OFF state, a long press will enter the brightness setup mode, then every short press will increase the brightness levels up to overflow back to the minimum.
After some tests the increment was set so there are 5 different levels of brightness.
Short video of the prototype
07/24/2025 at 00:21 • 0 comments
