SAOfinityHingePart1.stl
Hinge Part 1
Standard Tesselated Geometry - 670.69 kB - 05/30/2026 at 18:26
Download
SAOFinityClip.stl
Clip to reinforce sections together
Standard Tesselated Geometry - 670.39 kB - 05/30/2026 at 18:26
Download
SAOfinityHingePin.stl
Pin for the 2 part hinge
Standard Tesselated Geometry - 314.14 kB - 05/30/2026 at 18:26
Download
SAOfinityHingePart2.stl
Hinge Part 2
Standard Tesselated Geometry - 298.62 kB - 05/30/2026 at 18:26
Download
SAOfinityGridBlank_v2.stl
Grid spacer with no connector
Standard Tesselated Geometry - 1.12 MB - 11/12/2025 at 00:44
Download
SAOfinityGrid_pcb_v2.stl
Grid intended for use with custom PCB
Standard Tesselated Geometry - 1.27 MB - 11/09/2025 at 23:05
Download
SAOfinityGrid_v2.stl
Grid for use with just an SAO connector.
Standard Tesselated Geometry - 1.12 MB - 11/09/2025 at 23:05
Download
SAOfinityBowTie_pcb_v2.stl
Bow Tie for use with custom PCB version of grid
Standard Tesselated Geometry - 458.48 kB - 11/09/2025 at 23:05
Download
SAOfinityClip_v2.stl
Universal clip for both versions.
Standard Tesselated Geometry - 666.88 kB - 11/09/2025 at 23:05
Download
SAOfinityBowTie_v2.stl
Bow Tie for use with regular version (no PCB)
Standard Tesselated Geometry - 457.31 kB - 11/09/2025 at 23:05
Download
SAOfinityEdge_v2.stl
Edge plug for use with regular version (no PCB)
Standard Tesselated Geometry - 229.77 kB - 11/09/2025 at 23:05
Download
SAOfinityEdge_pcb_v2.stl
Edge plug for use with custom PCB version
Standard Tesselated Geometry - 230.55 kB - 11/09/2025 at 23:05
Download
