An image of the user manual presented as a cheat sheet.
JPEG Image -
2.09 MB -
06/12/2026 at 03:43
Preview
pucks_top.stl
caps the bottom half of the puck.
Standard Tesselated Geometry -
56.33 kB -
06/12/2026 at 03:39
Download
pucks_bottom .stl
The bottom half of the puck to transfer the local pressure to the transducer.
3.11 MB -
06/12/2026 at 03:36
Download
Pressure Sensor Kit User Manual v1.01 by Nelson Phillips.pdf
User Manual latest
Adobe Portable Document Format -
2.12 MB -
05/04/2026 at 09:24
Preview
savedata.pde
Uses the Processing4 software to retrieve the advanced kits memory and save it to the computer. It displays a UI which will walk you through the process.
pde -
26.67 kB -
03/10/2026 at 07:52
Download
display_sd_card_data_1.ino
reads the stored data from the advanced kit for UI use. Required to flash to the kit if the data needs to be retrieved from the kits memory chip.
ino -
4.14 kB -
03/10/2026 at 07:49
Download
data_logger_v2.ino
data logging code for the advanced kit. This uses the memory chip and communicates to the expansion boards sensors.
ino -
6.71 kB -
03/10/2026 at 07:47
Download
Basic_Kit_averaging.ino
The latest version of the program to run the basic kit. Its updated to use a button to trigger the data recording, rather than a switch.
ino -
4.62 kB -
03/10/2026 at 07:31
Download
pressureSensorUI_1.pde
uses the Processing4 software to create a UI to retrieve data from EEPROM and write it to a file that a spreadsheet can open.
pde -
3.34 kB -
08/09/2025 at 14:03
Download
