Desassembly session of a Z8001 binary with Ghidra!
Portable Network Graphics (PNG) - 166.39 kB - 06/17/2026 at 05:14
Preview
BBTC_EV.bin
Double byte patch of BOOTEVEN. See log.
octet-stream - 600.00 bytes - 05/31/2026 at 12:30
Download
BBTC_OD.bin
Double byte patch of BOOTODD. See log.
Download
TrumpCPLD2.pdf
Flip-flop modifications: replaced inverter with a nand gate (inst 12, 19, 25)
When the /RES input is low, it disables the /PRE input so the FF is reset.
Correction: added inverter inst 40
Adobe Portable Document Format - 596.15 kB - 05/31/2026 at 11:31
Preview
Setup to check the bucket logic with 2 alien probes: 1 for the Z8001 and the other on the PC-XT bus
JPEG Image - 1016.69 kB - 05/25/2026 at 10:25
Preview
JPEG Image - 991.37 kB - 05/25/2026 at 10:25
Preview
Test setup with the Z8001 Alien Probe installed on the BBTC.
JPEG Image - 1.11 MB - 05/22/2026 at 07:15
Preview
TrumpCard.pdf
The schematic of the bucket and glue logic in a pdf file.
Adobe Portable Document Format - 594.02 kB - 01/06/2026 at 09:23
Preview
TrumpCard-20260106.zip
The latest version of the CPLD files. Not the ... ok, you get it!
For use in Quartus II. This is a untested version. It matches the circuit in the original TC, but something just doesn't work for now.
x-zip-compressed - 4.43 MB - 01/06/2026 at 09:20
Download
BOOT.bin
The combination of BOOTEVEN and BOOTODD into a single binary file
octet-stream - 600.00 bytes - 01/04/2026 at 10:49
Download
BOOT.asm
The disassembled code of BOOT.bin. I used this disassembler: https://github.com/OlliL/Z8000-Disassembler.
asm - 10.27 kB - 01/04/2026 at 10:49
Download
TrumpBucket.circ
Circuit for simulating the bit bucket with Logisim Evolution.
circ - 36.58 kB - 12/22/2025 at 01:37
Download
Gerbers-v1.1-TrumCard.zip
These are the Gerber/NC Drill files for a slight modification of the Trump Card. This adds the holes at the right position to mount a 9202 bracket from Keystone. No mess with hardware! Note: KiCAD v9.0.6 has a little bug. The paste mask allows paste over the edge connector pads, which we dont want on gold fingers.
Zip Archive - 357.29 kB - 11/17/2025 at 06:17
Download
setrmdsk.asm
Com file disassembled with ndisasm on linux
asm - 4.66 kB - 10/17/2025 at 01:46
Download
TRUMPLO.bin
Low bytes for the 2716 EPROMs
octet-stream - 32.00 bytes - 10/13/2025 at 08:31
Download
TRUMPHI.bin
High bytes for the 2716 EPROMs
octet-stream - 32.00 bytes - 10/13/2025 at 08:30
Download
Components location and value on bottom
Portable Network Graphics (PNG) - 50.80 kB - 09/30/2025 at 09:29
Preview
Components location and value on top
Portable Network Graphics (PNG) - 93.62 kB - 09/30/2025 at 09:29
Preview
Trump Card-schematic.pdf
Schematic
Adobe Portable Document Format - 291.96 kB - 09/30/2025 at 08:53
Preview
BOM-Trump Card.pdf
Bill of materials
Adobe Portable Document Format - 104.08 kB - 09/30/2025 at 08:53
Preview
BOM-Trump Card.xlsx
Bill of materials
sheet - 10.92 kB - 09/30/2025 at 08:53
Download
BOM-Trump Card.ods
Bill of materials
spreadsheet - 16.33 kB - 09/29/2025 at 02:39
Download
BOM-Trump Card.csv
Bill of materials
Comma-Separated Values - 1.49 kB - 09/29/2025 at 02:39
Download
EPROM-EEPROM-FLASH.ods
Support for different EPROMs and EEPROMs for the SBTC or other projects.
spreadsheet - 25.84 kB - 09/27/2025 at 07:01
Download
SBTC-routing incomplete.tar.bz2
This is the PC104 version of the Trump Card, called the Small Beautiful Trump Card. The schematic is complete, with a configuration header to select many EPROMs or EEPROMs. The PCB routing is done partly. I'm putting this project on hold. I hope somebody will take up this project eventually.
x-bzip - 622.63 kB - 09/27/2025 at 06:55
Download
3D render from KiCAD
Portable Network Graphics (PNG) - 123.88 kB - 08/22/2025 at 17:01
Preview
