Introduction
Looking for a simple yet impressive Arduino project that is both beginner-friendly and practical? This Arduino-based Smart Distance Scale uses an HCSR-04 ultrasonic sensor, an OLED 0.96 inch display, and the compact Arduino Nano to measure and visually represent distances with accuracy and style.
But wait - what if you want to turn your hobby project into a market ready prototype or even a polished product? Stick around! We're also featuring JUSTWAY, your go-to partner for rapid prototyping and on-demand manufacturing. Learn how to transform your DIY builds into production-grade hardware.
Let's dive in!
What This Project Does
This project lets you:
  • Measure distances in real-time using an HC-SR04 ultrasonic sensor.
  • Display the distance in both centimeters and inches on a crisp OLED 0.96" screen.
  • Visualize readings with a dynamic horizontal bar graph.
Components Required
  • Arduino Nano: A compact, breadboard-friendly microcontroller based on the ATmega328P. It's ideal for small projects, has USB connectivity, and offers 14 digital I/O pins, 8 analog inputs, and built-in serial communication.
  • HC-SR04 Ultrasonic Sensor: A popular distance sensor that uses ultrasonic waves to measure the distance between the sensor and an object. It has TRIG and ECHO pins and can detect distances from 2cm to 400cm with good accuracy.
  • 0.96" OLED Display (SH110, I2C): A 128x64 pixel monochrome display that communicates over I2C (2 wires only: SDA & SCL). It's perfect for showing text, numbers and simple graphics like bar graphs. Based on the SH1106 driver chip.
  • Jumper Wires: Flexible wires with male to female or male to male ends to make quick and easy connections between components on a breadboard or directly to headers.
  • USB Cable (for Arduino Nano): Used to upload code from the Arduino IDE and provide power to the Arduino Nano during development or debugging.
Taking You Project Further - with JUSTWAY
So you've built a working prototype. It's functional and cool. But what if you want to:
  • Pitch this at a tech fair?
  • Start you own product line?
  • Or just want an enclosure that doesn't look like a spaghetti mess of wires?
This is where JUSTWAY steps in - your ultimate rapid prototype and on-demand manufacturing partner.
What is JUSTWAY?
JUSTWAY empowers innovators by transforming 3D models and designs into marker-ready prototypes and end-use parts, offering:
Rapid Prototyping Services
Turn you concept into reality - fast!
  • 24-hour prototypes
  • instant DFM (Design for manufacturability) Feedback
  • Production and Shipping Tracking
  • Instant Quoting platform
Mass Production Support
When you're ready to scale up!
  • Dedicated Sales Reps (24/7)
  • DFM Engineers Review Every Order
  • Detailed Test Reports
JUSTWAY's Manufacturing Capabilities
  • 3D Printing: SLA(Resin), Nylon HP-PA-12 - Transparent, Detailed, and Durable
  • CNC Machining: Aluminum 6061, Stainless Steel 304 - Strength, precision & corrosion resistance
  • Injection Molding: PC/ABS - ideal for strong, flexible, polished enclosures
  • Sheet Metal: Aluminum 5052 - Great for bent, strong components
How To Order from JUSTWAY in 4 Easy Steps
Step1: Upload Your Design
Step2: Select Material & Finish
  • Choose strong plastic or metal, or use transparent/colored resin for added flair.
Step3: Preview Live Model
  • Check your logo placement, part fit, and dimensions using the live preview.
Step 4: Confirm & Place Your Order
  • Know exactly what you're getting - no surprises.
Pro Tip: Want to show off your electronics inside? Choose transparent resin. Want a market ready black matte enclosure? They have that too !
Circuit Diagram & Connections
Ultrasonic Sensor - Arduino Nano
  • VCC - 5v
  • GND - GND
  • TRIG - D9
  • ECHO - D10
OLED Display (SH1106) - Arduino Nano
  • VCC - 5v
  • GND - GND
  • SCL - A5
  • SDA - A4
Arduino Code Explanation
