Nectar Nest - The First True 3D Hive for Honey Pro
A fully modular beehive, designed for FDM 3D printing with thermal-insulating sandwich walls and IoT monitoring
Nectar Nest is a modular beehive system fully designed for large-format FDM 3D printing.
The goal is to provide beekeepers, makers, and researchers with a flexible, affordable, and replicable hive that combines the tradition of Langstroth-style beekeeping with the possibilities of digital fabrication.
Key features:
  • 🧱 Sandwich walls: 20 mm thick, with two 1.6 mm outer skins and a 5% gyroid infill for insulation.
  • 🔄 Modular design: Brood box, super, cover, roof — all stackable and combinable.
  • 🐝 Anti-varroa bottom with removable tray and metal mesh slot.
  • 🌡️ Weather-resistant PETG: food-safe, UV stable, and printable on consumer-grade machines.
  • 📡 IoT expansion: ESP32 LoRa sensors for temperature, humidity, and hive health monitoring.
  • 🌍 Maker-friendly: Designed for printers with 420×420 mm beds (e.g., Neptune 4 Max, Anycubic Kobra 3 Max, etc.).
Details
The complete assembled hive measures 41 × 41 × 70 cm and accommodates standard Langstroth-compatible frames (10 per brood/super box).
Main Components
  • Bottom board: Varroa-counting tray + mesh insert.
  • Brood chamber: Made of base adapter + honey super.
  • Honey super: Can be used standalone or stacked.
  • Escape board: Optional bee escape separator.
  • Inner cover: Space for feeder insert.
  • Roof: Insulating with chimney-effect air vents.
  • It’s almost here: Our 3D-printed modular beehive goes live on Kickstarter November 4th!
    Diego • 11/03/2025 at 13:43 • 0 comments
    Hi everyone!
    After months of design, prototyping, field testing and feedback, we’re excited to officially announce the launch date of our project:
    👉 Nectar Nest — the first modular beehive fully designed for 3D printing
    📅 LIVE on Kickstarter: November 4th
    In this video, you'll get a full preview of how the hive works, how it’s built, and what makes it special — from snap-fit assembly to gyroid-insulated walls and stackable modules.
    We’ll be offering: 🔹 STL packs for makers
    🔹 Fully printed hives (EU/UK shipping only for now)
    🔹 Exclusive early bird rewards
    Would love your feedback, thoughts or questions — and of course, feel free to hit the “Notify me” button if you want to follow the campaign!
    🔗 https://www.kickstarter.com/projects/nectarnest/nectar-nest-the-first-true-3d-hive-for-honey-production
    Thanks for all the support so far — this community helped shape the project more than you know 🧡
  • Log 5 — Towards Crowdfunding
    Diego • 09/17/2025 at 19:34 • 0 comments
    We’re preparing a Kickstarter launch (Nov 2025) with multiple reward tiers:
    • 🖥️ Digital Maker Pack (STL files)
    • 🐝 Hive Ready Pack (fully printed hive)
    • 🔧 Innovator Pack (printed hive + STL files)
    • 🌍 Future “Merchant License” tiers for resellers
  • Log 4 — IoT Sensor Integration
    Diego • 09/17/2025 at 19:33 • 0 comments
    An optional ESP32 LoRa module with BME680 sensors monitors temperature, humidity, and air quality. The idea is to connect hives into a global open-data network for research and beekeeping optimization.
  • Log 3 — Large-Format Printing Challenges
    The hive was intentionally designed to fit monolithic printing on 420×420 mm plates to avoid seams and assembly joints. We’re testing slicing strategies (Cura profiles, adaptive layers) to optimize print times.
  • Log 2 — Testing PETG for Outdoor Use
    PETG was chosen over PLA/ABS for its UV stability, impact resistance, and food-safety. Initial prototypes were left outdoors to verify durability through seasonal changes.
  • Log 1 — Design of Sandwich Walls
    Diego • 09/17/2025 at 19:32 • 0 comments
    We designed 20 mm thick walls with a gyroid infill core. This keeps the hive lightweight yet insulated, combining thermal protection for the bees with reduced plastic consumption.
View all 6 project logs
  • 1
    Printing setup (tested):
    • Material: PETG (black/white, 1.75 mm)
    • Nozzle: 0.8 mm CHT
    • Layer height: 0.48 mm
    • Infill: gyroid 5-10%
    • Bed size: ≥ 420×420 mm
View all instructions
