Introducing Floe - A browser-based IDE
11/12/2024 at 12:45 • 0 commentsWe will be creating some text based accompaniments to this tutorial shortly, but wanted to share our progress.
The best ways to get all the source files and stay up to date is to subscribe on Crowd Supply or to follow us here. Thank you!
Drawing with Makelangelo
11/08/2024 at 09:49 • 0 commentsDrawing with Makelangelo
Drawing with Inkscape: part 2
10/30/2024 at 18:17 • 0 commentsDrawing with Inkscape: part 2
Drawing Text ObjectsWe will be creating some text based accompaniments to this tutorial shortly, but wanted to share our progress.
The best ways to stay up to date is to subscribe on Crowd Supply or to follow us here. Thank you! -
Drawing with Inkscape: part 1 video
10/27/2024 at 17:02 • 0 commentsDrawing with Inkscape: Part 1
Thank you! -
Releasing Initial Version of Tobor Mainboard
10/14/2024 at 21:42 • 0 commentsget more source files as we release them here
It comes standard with:
- ESP32 microcontroller with 4 MB SPIRAM
- Runs Micropython
- 3 DRV8825 stepper motor drivers
- 2 AS5048B 14-bit absolute encoders
- Allows for low/no motion homing
- Collaborative programming
- 8 position addressable LED ring
- Can be used to display states of motors or the machine
- External stepper driver and peripheral port
- CNC controller powered by Fluid NC with dedicated FTDI and reset switch
- Micro-SD card slot
- WiFi enabled
- CANbus Edge Board Interface
- Servo header
- 24 VDC power input
- 1 user programmable tactile button
- Reset button
- FTDI port
- Edgeboard standards
- Heartbeat LED
- Function button
- Status addressable LED
In this github repo there are the initial versions of Tobor's mainboard
https://github.com/evezor/tobor_v00
get more source files as we release them here - ESP32 microcontroller with 4 MB SPIRAM
Introducing Tobor: the robot arm
10/07/2024 at 08:00 • 0 commentsIntroducing Tobor: the robot arm
Tobor is a fully featured robotic system that can fit on your desktop and is capable of helping you automate your workflow. Tobor (robot spelled backwards), was built to be the most versatile open-source robotics system, which can be customized endlessly to meet your automation needs. Easily combine robotic arms, motion platforms, sensors, actuators, and more to create your unique machine.
Draw with Tobor
Draw pictures and more with the pen toolheadTutorial coming soon...Pick and Place
Use the suction cup toolhead to play a game of checkers.Tutorial coming soon...Program Collaboratively
Use a remote control to program collaboratively.Tutorial coming soon...Assemble Circuit Boards
Use the PNP toolhead to assemble circuit boardsTutorial coming soon...Programmed with and program with Python
Tobor Robot Arm Features
- Runs Micropython
- WiFi enabled
- Servo header
- Reset button
- FTDI port
- Heartbeat LED
- Function button
There's way more than we've posted in this update. Find out more at Crowd Supply
See more details at Crowd Supply - ESP32 microcontroller with 4 MB SPIRAM
Day 30: evezor_edgeboard_ftdi_breakout
10/15/2023 at 12:33 • 0 commentsThis board uses the standard 6-pin JST-SH connector and breaks out the rx and tx pins and adds 2 bottons for reset and boot pins.
Source files can be found here: https://github.com/evezor/evezor_edgeboard_ftdi_breakout
Day 29: evezor_arm_v1_idc_regiggerer
10/13/2023 at 12:39 • 0 commentsThis boards incorporates two gadgeteer ports intended to work with the other devices in this ecosystem. I originally created this board as a way to remap pins. And using this thing I decided that I hated everything about systems like the gadgeteer standard, pmod, shields, hats, and many of the other systems that intend to create a reusable set of standards among controllers and devices. But inevitably you run into issues like, this pin does not have pwm and I want it to. Or this pin does not have pullups or can only be used as an input and on and on. Secondly, when you end up going through these mappings your code and schematics begin to look just as ugly and trying to trace down issues when you want to change or diagnose things you must again untangle all these mappings. No more! I threw all these boards in the trash and have no intention of looking back. It's a noble goal to try and create some kind of standards for breaking out pins and I will continue to create and use them, but attempting to have a paradigm like this as the foundation is untenable and was part of the inspiration for the larger Evezor edge board concept.
Source files for this board can be found here: https://github.com/evezor/evezor_arm_v1_idc_regiggerer
Day 28: evezor_arm_v1_mosfet_thing
10/12/2023 at 06:58 • 0 commentsThis board has a few mosfets intended to be used for relays, small fans, lights and other small loads.
It incorporates a gadgeteer port to work with the mainboard who's source can be found here: https://github.com/evezor/evezor_arm_v1_mainboard_V2
The source files for this board can be found here: https://github.com/evezor/evezor_arm_v1_mosfet_thing
Day 27: evezor_arm_v1_mainboard_V2
10/11/2023 at 10:07 • 0 commentsThis is the second iteration of the mainboard. The first version can be found here: https://github.com/evezor/evezor_arm_v1_mainboard_V1
This board retains the Molex KK connectors for the stepper motors and the gadgeteer ports for expansion.
This version also incorportates a stepdown voltage converter, a power relay and a pair of USB-A ports inteded for powering a raspberry pi and a screen.
Source files can be found here: https://github.com/evezor/evezor_arm_v1_mainboard_V2
anfroholic
