Hackery of MELPS-740-based devices...
1/29/26 I wrote (and forgot to publish) the following:
This list is Likely to be revised as my brain starts to recall things long-forgotten; since I'd went down a rabbithole of a side-project that sent me down several other rabbitholes (including a mostly-dead computer, and a mostly-dead chip programmer), some of which are still to be resolved.
1) Option-Jumpers/Keymap/Umlats/Japanese?
(See Dave's post, previous to this)
2) Logic Analyze the interchip communications
(Thought plausibly to be little more than a keymatrix-to-character lookup-table... But I'm pretty certain I recall having a reason or two to think it must do more than just that... what were they?)
3) Dave notes (THANK YOU) "and I think you were going to trial hack something else (a vcr?) before risking it with your baby, the plotter/typewriter." regarding:
Plausible ROM-dump by changing CNVSS to boot from *external* ROM...
Side-project was NOT for interchip comms, as I'd been remembering it, lately, but for determining whether (e.g.) the external ROM (Aaaah, yes, then the idea "who needs ROM, it might be simulated via AVR") would have the drive-strength to overcome whatever other peripheral(s) are attached to the GPIOs that will be turned into the Data port
(side-thought... if we're using a uC *as* the MELPS740 firmware "server", rather than a ROM, we mightn't need to watch the address-bus at all)
3/8/26 (now)
The rabbithole project. Briefly:
"logicInstrument" is a logic-probe 2.0 suited for determining the *cause* of the logic-values it detects... It tries to inject a different logic-value in various ways to see whether the original signal is e.g. driven from a uC/TTL output, tied to a power-rail, or pulled via a resistor. It can help determine if a signal is e.g. open-collector, etc.
Why'd I build this?
Well, in order to inject signals, later... e.g. via my own microcontroller.
Can it be done without causing contention?
E.G. the unit we're reverse-engineering has two microcontrollers which intercommunicate via an 8bit port along with four other signals. It seems plausible that one might be the unit's "brain" (the user-interface), while the other might e.g. control the peripherals.
So, let's say we want to disable one of their uC's and use our own in its place... Say we want a new UI, from our own uC, but still want to use the peripherals via the original peripheral-uC.
Can it be done *without* cutting the traces from the original "brain" by putting it in reset? This brings up several more questions such as: Can the original "brain"-uC be put in reset without cutting traces to its reset circuitry?
Well, once I started tallying up the number of such questions--and considered that traces go under the chips and vias and that the other side of the board is relatively-inaccessible (because it has to be covered with the keyboard-membrane if I want to try anything), and considering I wanted to try out these ideas on a *different* system, first, before risking "my baby"--I started to realize I didn't really want to try to figure out where *every* pin goes; what kind of circuitry is attached, where *every* resistor is tied, etc... Maybe you'll see why in the following picture.
This is the *other* system... the system I'm willing to risk damaging, in order to plan/practice on before performing surgery on "my baby". They're both based on the MELPS-740. This comes from an old VCR, which is long-gone. It will never get reassembled. Most of the other boards are missing, too. So I have no idea where most of these signals go. But one thing I do know is that's a LOT of resistors, of various values. And there's a LOT of analog circuitry, as well, and I'm not so great at analog. And, from looking at datasheets, I see it's *also* capable of high-voltage logic-I/O. But, I'm not messing with that, I'm only connecting the *known* 5V (from the uC's pinout). So, then, e.g. are higher-voltage circuits, unpowered,...
Read more »The board has some unknown 'options jumpers' labeled S, P1-5 which are selected by a solder short and go into IC4. We don't know definitively what these are, but speculate that they might be keyboard/symbol set options. There are a few reasons for this:
By pausing and scrutinizing the YouTube video in various places, I can make out the alternative key layout with some confidence. (E.g. Shift-1 is hard to discern, but reason suggests it is an asterisk.) The key matrix for this device seems to be:
P3 option (Europe; probably UK) Column Row p5.0 p5.1 p5.2 p5.3 p5.4 p5.5 p5.6 p5.7 -------------------------------------------------------------------- p0.0 MargRel Line TabSet Marg CrsR CrsL Bksp p0.1 Up Dn Right Left RET TAB Space Mode p0.2 CE Size <A> GRAPH Color = + - p0.3 × ÷ ???! CODE ShL/ShR CAPS REPEAT p0.4 0) 1* 2" 3/ 4@ 5£ 6_ 7& p0.5 8' 9( ;: ¢$ ,, -? .. ½% p0.6 =+ A B C D E F G p0.7 H I J K L M N O p1.0 P Q R S T U V W p1.1 X Y Z !¼
And since I've gone to the trouble, I might as well make one for the 'neutral' mapping that uses the nomenclature shown in Sears Parts Direct:
Neutral (Sears Parts Direct nomenclature) Column Row p5.0 p5.1 p5.2 p5.3 p5.4 p5.5 p5.6 p5.7 -------------------------------------------------------------------- p0.0 F5 A10 F9 F7 F19 F18 F6 p0.1 F3 F4 F2 F1 F11 F8 F17 A12 p0.2 A6 A9 A7 F15 A8 A5 A1 A2 p0.3 A3 A4 A11 F12 F13/F14 F10 F16 p0.4 K10 K1 K2 K3 K4 K5 K6 K7 p0.5 K8 K9 K33 K23 K42 K11 K43 K44 p0.6 K34 K24 K39 K37 K26 K15 K27 K28 p0.7 K29 K20 K30 K31 K32 K41 K40 K21 p1.0 K22 K13 K16 K25 K17 K19 K38 K14 p1.1 K36 K18 K35 K12
I'm not sure how useful that is, but the nomenclature is interesting to me because the 'A' and 'F' groups seem to be likely to not change by market, whereas the 'K' group has printable symbols, and likely does.
Also, as previously noted, the sequencing of the keys for the alphabetic and numeric characters seemed oriented towards simplifying ASCII translation. So I suspect the bulk of those keys to remain constant across models (else that benefit would be lost), and that the model customization would be mostly confined to the non-alphanumeric keys (which included the shift of the numerics).
So the current hypothesis is that the P-jumpers select some alternative symbols for that subset of the 'K' designated keys.
It would be interesting to assess this by trying out the various P jumpers and seeing what comes out. The unit has a 'correction print' mode which shows stuff on the LCD before printing. That could be used as a way to quickly explore the various key mappings.
In the case of the known European unit, the jumper was set at P3 and the only new symbol was pound Stirling shift-5 £. So shorting P3 should cause that to show that new symbol on the LCD when in 'CP' mode. And the other symbols show in their new locations.
Since the only new symbol on the YouTube keyboard is £, this suggests...
Read more »I've too many tabs open!
The blog that started this addiction...
https://biosrhythm.com/?p=2143
Plausibly-compatible pinion-gear and very similar mechanism that may be the same brand/parts:
https://www.ebay.com/itm/133559488667
Mitsubishi Single Chip Microcomputers 1989 guide with datasheets for our two chips:
Here's the same databook from 1984.
The 1989 databook talks of devices it does not contain data for that refers back to the 1984 edition (specifically: I/O Expander chips made for the 740, which I thought *might* help us understand the LCD wiring weirdness, but no more... as the I/O expander port is definitely unused on our 740). But, apparently they removed *some* info, so who knows what/how-much by then?
(Thank you, Dave, for sending this *much less* scary link so I could delete the other I had!)
https://archive.org/details/bitsavers_mitsubishiishiSingleChipMicrocontroller_11129380
Another plausibly-compatible mechanism, source for pens, gears, etc... "The german guy" is linked here:
M54539P : 6-UNIT 700mA TRANSISTOR ARRAY WITH CLAMP DIODE --Stepper-Drivers, yeah?
https://www.alldatasheet.com/datasheet-pdf/download/99078/MITSUBISHI/M54539P.html
Renesas (Mitsubishi) 740 disassembler
https://github.com/mnaberez/m740dasm
Brother Type-O-Graph BP-30 Manual
https://archive.org/details/brother-type-o-graph-bp-30-manual
LOTS of useful info:
1984 Brother Type-O-Graph #H41530729
Status: Sightings
Hunter: Ted Munk (munk)
Created: 11-18-2016 at 06:49PM
Last Edit: 06-19-2025 at 08:49PM
https://typewriterdatabase.com/1984-brother-typeograph.7064.typewriter
Also from Ted Munk:
The Handwriting, Drawing Typewriter: Brother Type-O-Graph BP-30, with User Manual!
Refilling old plotter pens — the Brother BP-30 (Type-o-graph)
Here's the instruction-set/programming manual for MELPS740...
1989_Series_740_Software_Users_Manual
This might be the same, the name sounds even more appropriate, but...
This keeps crashing Chrome before it finishes loading... but looks to be promising.
FOREWORD This software manual is for users of the MELPS 740 series. Register structure, addressing mode and instructions are introduced in each section. The enhanced instruction set with enhanced data
MELPS740 vs 6502
09.24.98 Mitsubishi MELPS740/WDC W65CO2S: EDN’s 25th Annual Microprocessor/Microcontroller Director
My previous/first brief encounter with MELPS740... how to potentially replace the firmware with an external ROM (and maybe even leading to how to dump the internal rom for e.g. fonts, etc? Thoughts on that to come later...)
Random image dump within random URL dump:
This is what we've traced so-far along with potential for Eva-mode hackery
This might be up Dave's alley, it's a bit beyond me... Someone's trying to add MELPS740 to ghidra...
Something about an unusual jump instruction?
https://github.com/NationalSecurityAgency/ghidra/issues/5002
I'm sure I lost several in the copy-paste-close-shuffle :/
Feel free to add any of your own!
Could it really be so simple?
This is the motor-winding-phases as sent to the driver-board when "arrowing-right".
When the button is first pressed, it seems to go exactly one character-width, then if it's held for longer than half a second, or so, it starts moving continuously.
My logic-analyzer isn't set up to capture the continuous motion, but looking at this, it looks rather clear to me that there is no acceleration/deceleration used.
Seems crazy, considering all the massively-varying loads.
It also looks like it times-out after several miliseconds of non-motion, cutting power to the windings.
This, I think, explains why the initial step *almost* looks like it's accelerating. But, really, it's because the first step turns on only one winding. If you look at the hex-value represented by the four wires at the start it goes 000000111333222
that same 1-3-2 pattern repeats, later, at sample 26.
But, it doesn't start with 0, instead it continues from 9. The "last" winding (D3) is still on when the pattern begins again.
This is [all] intriguing to me because I've done quite a bit of stepper-control over the years, and, frankly, I still don't really "get" it.
Most the steppers I've worked with are of the "NEMA" sort, whereas these are "pancake". I don't really think that, specifically, should make a difference in how they're driven except that, in a case like this, the motors are geared-down quite a bit. The pancake motors usually have a much lower resolution, e.g. 32 steps per revolution vs 200... Which, frankly, I'd've expected would make them *weaker*, since the electromagnets have to rotate the rotor that much further, across a greater air-gap.
But, maybe I'm mistaken... because this system has "wowed" me from the start at its speed and its ability to switch-direction so often without, apparently, losing steps.
So, then, we have another weird-to-me observation with these phases' powering-down when unused... In my experience doing similar, the motors often snap into a new position.
So, then, it comes down to "full-stepping" vs. "half-stepping", which I've gathered are actually not-well-defined. (whereas, maybe, "half-stepS" and "full-stepS" might be, confusingly, well-ish defined).
So, I'll take a moment to re-explain as I see it:
One way unipolar steppers can be driven is to only power one phase at a time, in sequence. Another way is to power two at a time. The photo shows both cases. Alternating between powering a single winding and powering two.
That very first step is only *one* winding powered.
Why is this important?
Well, most of the info I've seen is rather vague about what "half-stepping" vs. "full-stepping" really means, and-yet, talk about it like it's fundamental.
So, if you imagine the rotor as being made of a ring of four electromagnets, you might wonder what the difference would be if powering *one* vs. powering *two*...
It really depends on *how* the rotor and stator are designed to work together. It may well be that there's a de-facto standard, or it may be that there are numerous designs out there and yet the vast-majority of documents out there about controlling steppers just happen to make no mention of these differing designs!
OK, so imagine ONE simplified design:
The rotor is like a compass, with a bar-magnet attached to the shaft, and the stator has four electromagnets at the N, W, S, and E markings.
Imagine only one winding is ever powered, and it's "unipolar" in the sense that: when the electromagnets are powered they *attract* the North pole of the bar magnet/compass-needle... When they are *unpowered* they do not attract. And, being "unipolar," they are never reverse-powered to repel.
THEN: the needle will [what *I* would call] "full-step" between the NWSE positions.
OTOH, you could also power it with *two* adjacent windings: N&E, S&E, S&W, N&W... and the needle should point at those, what I'd call "half-steps," NE, SE, ... Yet even though it's...
Read more »Dave tells story of a similar plotting-unit he had long ago that succumbed to a broken nylon gear, and, well, it'd be a shame if that happened with this...
So, I had a weird moment-of-insight remembering that as-of just a few years ago (after the closure of the Sears nearby) I discovered that Sears Parts Direct still existed, and I thought it'd be worth a try to see if this machine was even in their database...
YEP!
https://www.searspartsdirect.com/model/mxnaod3pgi-000934/sears-26853700-office-parts
Unfortunately, but not surprisingly, none of the parts are available...
But there is some useful info, there, including maybe part-numbers that might be searchable elsewhere... but also, some diagrams!
I don't know if I'da started clicking-around more, then maybe I'd've found higher-res shots... but here's what I mined:
I transcribed the traces into a kind of netlist of the suspected row and column elements. For every wire there is a list of keys on that line. And for every key there is exactly two wires. Well, there should be. I made a couple booboos with a couple keys seemingly having 3 wires but that was easy enough to correct against the board layout since I have all the wires on different photoshop layers that I can flick on and off to hone in on a specific set.
I mostly used macros made of muscle memory to pivot and merge data, and just used Excel for sorting in various ways. Turns out my prior thinking of rows/columns was not what I intended, but also my 50/50 guess of which group are which failed, so this was a happy case of fate negating my ignorance and it turned out that I labeled the networks correctly. So I avoided a re-label effort.
Short story is that Port 5 is the 'column' port, meaning that it reads a row of bits from each column. Port 0 and the first two bits of Port 1 are the 'row' ports, meaning that they drive the row lines in a 'one-hot' manner to scan the keyboard. An interesting thing is that column p5.4 is also wired to IC4's (the second MCU) /INT pin. This column contains keys such as 'return' and 'shift', so maybe something to do with that (especially 'shift'). And since the /INT is active low, that suggest that P5 is probably configured to have internal pullups.
The keyboard matrix is: (hopefully ascii art will come through, and unicode chars)
Read more »Unoptioned (US)
Column
p0.4 0) 1! 2@ 3# 4$ 5% 6¢ 7&
p0.5 8* 9( ;: ½¼ ,, -_ .. /?
p0.6 '" A B C D E F G
p1.1 X Y Z =+ ...
After a couple days of tracing (and correcting booboos), I finally mapped out the keyboard. As mentioned before, there are 18 gpio lines, and in this case they map to IC1 Ports 5 (all), 1 (two bits), and 0 (all).
Now I need to collate these results into an actual keyboard matrix. I'm planning to transcribe this net data into Excel and do a little data massaging there to get the rows/columns worked out. I hypothesized that there are 8 bit columns which are read at once, and 10 row lines that are sequentially activated during scanning. There's no basis for this hypothesis other than it would be sane and likely simplify code in this constrained device. I semi-arbitrarily named P0 as the column port, but this could be wrong. (At least I know it's not port 1, haha.) The shape of the resulting matrix should make things apparent.
My mapping was fraught by 3 nets that are hidden under IC2. I have a guess that I feel is pretty good because of 2-D topology of the component side of the PCB (if there were more vias then this would be more ambiguous). So Eric will need to buzz it out to verify. This should be a quicky because two of those nets have easily accessibly test points, so it would just be testing continuity between a testpoint and a chip pin. I'll request that separately with an indication of the test points involved and my guess where they go.
There's 36 trace layers for the keyboard (18 lines, two sides), so I'm not going to post those. Instead I'll just post this one that is a merging of all of keyboard-side nets against a solid background (it's too noisy against the board shot). I also made a keyboard legend to help identify what button is what.
Oh, and there's a 'secret' key I labelled "???!" that exists on the board but does not exist on the physical unit case. What's even more trippy is that the elastomeric sheet does have a key for that button. And it has keys for buttons that are not on the board! This board has 5 buttons on each side, but the elastomeric sheet has 7! Another curiousity is that the board has two buttons for 'Return' (which are wired in parallel, so not really two buttons), but the elastomeric sheet only has a key for one of those buttons. Hmm! Mysteries of manufacturing.
So, now a lot of net transcribing into the warm fuzzy world of machine readable text and on to Excel collation....
LOL, OK, so it would seem that simply cropping the photos on my phone causes them to be saved in a higher compression, as well... Sorry... No longer cropping.
Oh the irony that of the 13 photos I uploaded, this, the blurriest, was the only one that appeared. "for clarity".
Let's try again!
Holy Moly, that took *minutes*... I guess that's what one gets for hiding out from the rain in a faraday-cage.
Uhm... 11 more...?!
gotta stop there... many were duplicates anyhow. hope these help! (see Two photos with C5 lifted)
The coup de grace will be mapping out the keyboard matrix. So boring! And 76 buttons! That implies a
⌈76/⌊√76⌋⌉ + ⌊√76⌋ = 18
lines for a minimal rectangular array.
It's going to be a lot of wires, and I don't know what are rows and what are columns, and I probably need to formulate a game plan before rushing into it. So to procrastinate creatively, I decided to map out the wires connecting the two MCUs. As mentioned before, the LCD data lines go to a smaller M50740 (3 Kib ROM, 96 by RAM), but the control lines are on the larger M50745 (6 Kib ROM, 192 by RAM -- how did we get anything done in those days?) So there's wiring between the two devices to coordinate.
Tracing:
So there's 5 lines between the two. The thing that is striking about the M50740 is that pretty much everything except for the 8 LCD data lines and these 5 'coordination' lines is tied high or low. So surely it must be doing something more that providing another 8 bit port because we used more than 8 bits to get that! EDIT: Eric clarified via buzzing out that all the LCD lines are brought to IC1, so 6 of these 11 are those.
Oh, there is a little more -- there are 5 'option' solder bridge pads that tie directly to the M50740. I have no idea what they are. None are bridged in this unit.
OK, having done that, I couldn't resist doing at least one wire of keyboard just to see what it looks like. So I picked an arbitrary one to kick the tires with the process:
The thing that is striking to me is that this has 8 buttons in it. Coincidence? And it runs to a gpio on IC1. So I think IC1 does the keyboard scanning, too.
As said before, I think the keyboard is going to be some work, so I'll try to get a game plan. I might wind up doing one layer for each line, row and column, but that's going to be 18 * 2 layers, hahahaha! I wonder if my ancient Photoshop can handle it? Yeah, I probably should have done this tracing in a vector graphics tool. Hindsight!
Anyway, one bit of reasoning is that since I have traced out a row (or is it a column?), then all the other lines on those buttons must then be columns (or rows -- I guess it just depends on the orientation of the matrix). So I'll next proceed doing columns of those buttons.
Because it is likely a 8x10 matrix, it seems sane that the side with 8 lines would go to the same port. That would simplify code, and this things only got 6 KiB rom and 192 bytes ram. So that can be an intuition that might help in puzzling things out at some point.
Eric's addition, since photos can't go in comments:
How 'bout that groovy key-layout... there's a cents symbol!
Here's the total pinout of IC4... Dave was spot-on about everything he could see in the photos, and even the guesses he had made where it couldn't be seen.
I turns out the LCD's data lines are actually all connected to both chips. My guess is that IC2 actually drives the LCD, and that IC2 is also using that same data-bus to communicate with IC4... But there's still some weirdness about it all... because what, then, does IC4 do?!
Its INT pin does seem to go all over the place, and I was able (I think) to track it down to a keyboard key in the board photos (I'd really rather *not* take that board off its mounts, since I feel I was lucky getting that LCD back into the case without having to remove it from the zebra strips and risk total misalignment).
In the past couple years (was it the AlphaSmart?) I finally learned that there *is* a way to use a key-matrix without *constantly* scanning. I can't recall the details, something about setting all rows low, and ORing all the columns? I suppose that could be done with a resistor network... (seeing as how few diodes and gates are on the board). So, then, when a Low is detected, only *then* run a scan for which row/col... So obvious, once I saw it... So, here, maybe that's what IC4's INT pin is doing...? Just check if *any* column goes low, then trigger IC2 to scan which one...? Dunno.
(I just realized there's no diodes in the matrix!).
Again, Dave's results were spot-on... Here I've also figured out the NOR logic used for the Solenoid and the left-side-detect switch.
Interestingly, I wiggled the solenoid's shaft by-hand, and I think Dave's theory of its latching is correct, it seems to hold in either position. It turns out the solenoid shaft is also magnetic! So, then, one polarity would suck it in, and the reverse polarity would spit it out! Never seen the likes. I've seen similar where *two* windings were used, but this solenoid has only two pins! Cool! And, kinda surprising that its holding-force is enough to overcome the spring in the pen, and movement along the pen-pusher thinggy.
So, I think Dave's right, the weird blue chip is an H-Bridge, and the NOR logic assures that it doesn't try to go both forward and backward at the same time...? Maybe converting a "pulse/direction" uC output to actual polarities for the H-Bridge... or vice-versa.
The Low-Batt signal does go to two pins on IC2... one is an interrupt, the other I think is just a GPIO for reading its value...(?)
The "jumpers" (S, P1-P5, all unpopulated) all go through a pull-up resistor-network... (poorly-drawn).
I think that's it.
Yep, *most* of IC4's GPIO pins are either grounded or tied high. Crazy. What's that thing *do*?
svofski
Kevin Santo Cappuccio
SukkoPera
noughtnaut
