1WEEDINATOR Ai Camera Control Box (Box 2)
Weedinator Camera & Control Box Components
- Enclosure & Mounting
- Enclosure: Fibox PC 3025 13 G Low Base, Light Grey (300x250x130mm)
- Supplier: RS Components
- Web Address: uk.rs-online.com/2065707
- Mounting Brackets: 300-MOUNT-BRACKET (3 Units)
- Supplier: VizionCam / TechNexion
- Web Address: technexion.com/products/accessories
- Glands & Seals
- Split Glands: Icotek KEL-ULTRA flex Large Split Glands for connectorized cables
- Supplier: Icotek
- Web Address: icotek.com/kel-ultra-flex
- M12 Glands: IP68 M12 Polyamide Cable Gland (Light Grey)
- Web Address: uk.rs-online.com/2105141
- M16 Glands: IP68 M16 Polyamide Cable Gland (Light Grey)
- Web Address: uk.rs-online.com/2105142
- Cooling & Environment
- Vent Gland: IP66 Air Vent Gland, M12 x 1.5 (Prevents condensation)
- Web Address: uk.rs-online.com/1271118
- Power Distribution
- Fuse Block: 12-Way Blade Fuse Block with LED Indicator
- Supplier: Amazon
- Web Address: amazon.co.uk/B07M68Y3J8
- Main Relay: 80A 12V Heavy Duty Relay
- Supplier: Amazon
- Web Address: amazon.co.uk/B01MT77S4O
- Voltmeter: DC 5V-30V LED Digital Voltmeter
- Supplier: Amazon
- Web Address: amazon.co.uk/B01LWT77S4O
- Voltage Regulation (On-Board)
- 5V Regulator: D2-Pack 5V Voltage Regulator (LM2576 or similar)
- Web Address: uk.rs-online.com/7140733
- 3.3V Regulator: D2-Pack 3.3V Voltage Regulator
- Web Address: uk.rs-online.com/7140742
- Motor Control
- Motor Driver: Cytron 10A Dual Channel Motor Driver (MDD10A)
- Supplier: RobotShop
- Web Address: robotshop.com/mdd10a
- Computing & High-End Vision
- Jetson Nano: NVIDIA Jetson Nano Developer Kit
- Supplier: Amazon
- Web Address: amazon.co.uk/B084DSDVJJ
- Vision Interface: VL-GM2-8CAM-RPI22 (GMSL2 8-Camera Hub for RPi/Jetson)
- Web Address: technexion.com/products/vizioncam
- Camera Units: VLS-GM2-AR0234-C-S83-IR (Global Shutter GMSL2 Cameras)
- Coax Cables: Vizionlink-COAX1-Cable (0300 and 0500 lengths)
- Navigation & Logic
- GNSS Receiver: SparkFun GPS-RTK2 Board - ZED-F9P (Qwiic)
- Supplier: SparkFun
- Web Address: sparkfun.com/15136
- Level Shifter: SparkFun 4-Channel Logic Level Converter
- Web Address: sparkfun.com/12009
- Connectivity & Fabrication
- PCB Terminals: WAGO 2604 Series Lever-Actuated Blocks
- Web Address: uk.rs-online.com/1446142
- Custom PCBs: MCU and High-Side Switch PCBs
- Supplier: PCBWay
- Web Address: pcbway.com
- PCB files, including Gerbers, are here: https://github.com/paddygoat/WEEDINATOR_2026/tree/main/PCBs
Step by step video instructions on how to assemble the components onto the WEEDINATOR MCU PCB.
This guide covers the assembly process for the WEEDINATOR MCU PCB, moving from precision surface-mount work to robust through-hole connectors.
SMD Population and Stenciling
The assembly begins with the surface-mount device (SMD) components. Precision at this stage prevents logic errors later.
- Voltage Regulators: Install the 5V and 3.3V D2-pack regulators in the top-left corner.
Note: Ensure the 3.3V component is the correct variant; several D2-pack components look identical but have different pinouts.
- Stenciling: Use a microscope to align the stencil perfectly.
- Maintenance: Clean the stencil immediately after use with isopropyl alcohol. If solder paste hardens in the fine apertures, it is nearly impossible to remove.
- PCB Quality: High-quality fabrication (like PCBWay) is recommended. Lower-tier boards may have defects, such as pins pre-filled with solder, which complicate assembly.
Component Identification & Reflow
Before heating the board in the reflow oven, double-check component values and polarities.
- Resistors (0603): Distinguish between 10k and 1k resistors. The 1k resistors typically have a "0" marking, while 10k resistors require a microscope to read the code.
- LEDs & Buzzer: * LED Cathode: Look for the tiny green mark on the LED to identify the cathode.
- Buzzer: Match the orientation of the writing on the buzzer to the silk-screen on the PCB.
- Capacitors: Install the black crescent capacitors to stabilize the voltage supply.
- Regulator Pins: On D2-pack regulators, the middle pin may not touch the PCB pad. This is acceptable as the large ground tab at the back provides the primary electrical and thermal connection.
Through-Hole Components & Headers
Once the SMD work is reflowed, move to through-hole soldering.
- SBUS Inverter: Solder the ZX450 NPN transistor. The PCB graphics clearly indicate the flat-side orientation.
- MCU Headers: 1. Tack-solder only the end pins first. 2. Slide the MCU onto the headers to check alignment. 3. Warning: Never force the MCU onto wonky headers; this can crack the silicon chip. If the headers are out of alignment, reheat the end pins and adjust until the MCU "clicks" into place easily.
MCU Fitting & WAGO Connectors
- Installation Hack: Use a small amount of WD-40 on the header pins. It significantly reduces the friction required to seat or remove the MCU.
- Safe Removal: When prying the MCU off, use a screwdriver gingerly to avoid "banana-shaping" (bending) the PCB.
- Terminal Blocks: This board uses orange WAGO-style spring connectors rather than traditional screw terminals.
- They are more reliable under vibration.
- Like the headers, solder only the ends first to ensure they are seated flush against the PCB before finishing the remaining pins.
Final Setup and Commissioning
- Grounding: Solder all available ground connectors—the more ground paths, the better the signal integrity.
- GPS Support: Install headers for the daughterboard, which supports dual Ublox Series 9 units for precise heading data.
- Hardware Jumpers: You must remove jumpers SB57 and SB31. This disables the Ethernet pins to free up PA1 and PA7 for system use.
- The "Smoke Test":
- Check the 5V and 3.3V rails with a multimeter.
- Power the board with preloaded test code. A successful build will trigger an audible beep from the buzzer and a flash from the LEDs.
Populating the 20 Channel High-side Switch PCB
PCB Design and Enclosure Logistics
- PCB Color Choice: For this project, white PCBs were specifically chosen over black. In a closed enclosure, white surfaces reflect ambient light, making it much easier to see the wiring and components during maintenance.
- High-Side Switches vs. Relays: * High-Side Switches: These are used for components like flashing beacons and hydraulic solenoid valves.
- Automotive Relays: Used for higher-current loads (up to 40A) such as engine glow plugs and starter motors.
Solder Paste Application & Stenciling
Using a stainless steel stencil is the most efficient way to populate this board, especially given the "massive" footprint of the high-side switch components compared to standard surface-mount parts.
- Solder Paste Freshness: Ideally, solder paste should be less than six months old. While these large components are more forgiving, fresh paste is essential if your board includes smaller 0603 components.
- Stencil Technique: 1. Secure the PCB and align the stencil. 2. Apply the paste with a squeegee, ensuring every aperture is filled to the top. 3. Critical Step: Lift the stencil vertically and carefully. Sliding it will smear the paste and cause solder bridges (shorts).
- Maintenance: Always clean the stencil with isopropyl alcohol immediately after use to prevent paste from hardening in the apertures.
Reflow Soldering and Manual Rework
The size of this PCB was maximized to fit the reflow oven, which presents some thermal challenges at the board's perimeter.
- Edge Component Inspection: Reflow ovens often have "cold spots" near the edges. Components in the center of the board usually come out shiny and well-soldered, while those near the edges may not reach full liquidus temperature.
- Heavy-Duty Rework: To fix incomplete solder joints on the large component tabs, a high-wattage soldering iron (e.g., 450W) is used.
- The massive tip stores enough thermal mass to heat the large copper tabs quickly.
- Heat the tab until the solder becomes "runny" and flows through the joint for a solid mechanical and electrical connection.
Final Finishing and Connectivity
- Post-Solder Cleaning: Scrub the board with isopropyl alcohol and a wire brush. This removes flux residue and dislodges any "solder balls" or tiny blobs that could cause a short circuit.
- Quality Control: Every joint is tested with a continuity meter to ensure there are no errors before the board is powered.
- Connectors: The final step involves installing WAGO spring connectors. These are preferred over screw terminals for their reliability in high-vibration environments (like a robot or tractor).
uses on the physical layout and enclosure preparation, ensuring that all sub-assemblies fit within the footprint while maintaining signal integrity and accessibility.
Enclosure Layout and Component Placement
The current prototype assembly (Box Two) includes the 20-channel high-side switch PCB, the MCU board, a fuse box with LED fuses, the Jetson Nano, and the camera de-serializer board.
Key Layout Considerations:
- Space Constraints: Because this unit (Box Two) is designed to sit flush against "Box One" on the robot, one end of the enclosure must remain completely blank. No components or connectors can protrude from that side.
- Thermal Management: Cooling fans are positioned in opposite corners to create cross-flow.
- EMI Interference: It is crucial to keep the cooling fan away from the MCU. Fans can cause signal degradation and electromagnetic interference (EMI) if they are too close to sensitive logic circuits.
Cable Entry and Gland Strategy
I am using a modular panel system to organize external connections. This allows for a clean, organized entry point for various wire gauges.
- Gland Sizes: I’m primarily using 12 mm glands for standard wiring (supporting up to 12 holes in a tight but functional cluster) and 16 mm glands for larger cables.
- Split Gland System: For USB and camera cables, I’m using "tech glands" (split glands). These are essential for FAKRA connectors found on the cameras; since these connectors are permanent, they cannot be threaded through standard holes. The split gland allows the cable to be slotted in and then sealed.
- XLR Fittings: I’m using XLR-style housings for the Jetson's DisplayPort and USB ports. While handy for temporary monitoring, they are more prone to shaking loose than fixed glands, so they are reserved for non-critical or temporary connections.
User Interface and Monitoring
The exterior of the box features several "quality of life" components for field operations:
- Voltmeter: Provides an immediate visual check that the alternator is charging and the battery is at the correct voltage.
- Momentary Switches: Useful for triggering specific software routines or safely shutting down the Jetson/single-board computer.
- DisplayPort: Externally accessible for monitoring the Jetson's output during debugging without opening the weather-sealed box.
Next Steps: Enclosure Fabrication
Now that the internal mapping is complete and the clearances are verified, the next step is to disassemble the boards and begin the drilling process.
- Tools: I’ll be using hole saws to create the entries for the glands and XLR fittings based on the marked-out patterns.
- Orientation: Most cables will be routed toward the end of the enclosure that faces the hydraulic solenoid valves on the robot.
Project Progress: Wiring and Housing Preparation
Drilling and Enclosure Strategy
I have finished drilling all the necessary holes in the enclosure. I’ve intentionally drilled about 50% more holes than currently required. In my experience, trying to go back inside the system to rewire or add features later is an absolute nightmare, so having those spares ready is critical.
I’ve included a large slot for icote split glands. These are great for Ethernet and USB cables because they allow you to pass cables through without having to remove the connectors or couplings. Speaking of connectors, I’ve learned the hard way never to mount the connectors directly into the enclosure holes; it's much better to use a system where the couplings stay outside the box.
Critical Technical Note: Brass Inserts
If you are using brass inserts (specifically the type from RS Online), the drill size is absolutely critical.
- Required Drill Bit: 5.7 mm
- Warning: If you use a smaller bit, such as 5.5 mm, the screw will lock into the insert during installation, and you will never get it out again.
Component Assembly and Labeling
I am now ready to assemble the internal components. The fuse box can stay on, and I’ll be using standoffs for the rest of the parts.
I’m currently installing a 20-channel high-side switchboard. I have already wired the eight channels on the lower PCB. Proper labeling is essential here; every logic cable and board position is labeled (e.g., "Relay 1," "Relay 2"). Without these labels, it would be impossible to keep track of the system.
Current Status and Next Steps
The total channel count is now at 28. The system is expandable; I could stack another PCB to add another 20 channels if needed, though I haven't reached that requirement yet.
The logic cables are tucked in and routed to one side to keep the layout tidy. I am going to finish connecting the remaining wires and fasten the board down before moving on to the next phase.
PCB Layer Cake: Assembly and Cable Management
Layer 1: Switchboard and Power Supply
The board is currently partially wired with eight channels completed and twelve remaining. I have meticulously labeled everything to ensure clarity during assembly.
Cable Routing Strategy:
- Rear Routing: All wires are tucked neatly behind the board rather than across the top.
- Hinge Accessibility: By keeping the top clear, the board can "hinge" upward if you ever need to access components underneath (like replacing relays) without disconnecting the entire system.
- Power: The 12V supply comes from the fuse box through a general-purpose connector. While some pins are currently unused, they are ready for future expansion.
Layer 2: Logic and MCU Integration
We are now moving into the "layer cake" phase of the build. The logic cables are wired up on one side—I’ve given them a "tug test" to ensure they are secure.
Cable Sizing and Loads: The wire gauge is strictly chosen based on the current load:
- 0.75 mm²: Used for the remote connector (low current for hydraulic solenoids and warning beacons).
- 1.5 mm²: Used where cables double up.
- 2.5 mm²: Used for groups of four connectors and the main common lines routing back to the base.
Enclosure Constraints and Flexibility
Space is becoming tight on two sides of the enclosure because this unit butts up directly against "Control Box 1." Consequently, I’ve had to leave eight channels unwired for now, though they remain available for immediate use if needed.
Split Gland System: I am using a flexible rubber grommet/split gland system for the network and camera cables.
- No Cutting Required: This system allows you to pass fat camera cables through the enclosure without cutting the connectors off.
- Scalability: Each grommet can potentially hold two wires, doubling the capacity of a standard 10-way entry.
- Dedicated Ports: I’ve reserved four glands specifically for the encoder wires and motor controllers coming off the main MCU board.
Next Steps
The MCU board is ready to be bolted down onto the standoffs. Once secured, I will begin routing the long logic cables to their respective terminals on the far side of the enclosure.
Power and Motor Control
We’ve made significant progress on the motor wiring and power monitoring:
- Wiring Gauges: The motors are wired with 1.5 mm cables, supported by a 2.5 mm main feed to the master switch.
- Voltage Monitoring: I’ve installed a handy voltage meter. This is vital for monitoring the health of the battery and confirming the alternator is outputting its expected 14.8V.
- Motor Control: The PWM and direction connections use pink color-coded cables routed under the board. These control a dual-channel motor controller, which currently operates a prototype pan-tilt mechanism for our safety cameras.
- Motor Polarity: The motor cables are twin-core; if the direction is reversed, simply swapping the connections will fix it.
Jetson Nano & Vision System
This box serves as the hub for our vision and processing via the Jetson Nano.
- FAKRA Vision System: We are using TechNexion FAKRA cameras rather than standard Raspberry Pi cameras.
- Durability: They are waterproof and support long cable runs (up to 15m).
- Configuration: We have three connections—one for the front safety camera, one for the rear, and one dedicated to crop detection on the cultivating machine.
- Performance: Currently achieving approximately 15 FPS per camera.
- Connectivity: * A DisplayPort cable is routed to the exterior for screen communication.
- Spare USB ports are available for a wireless keyboard/mouse.
- An icote split gland system is used for all USB, Ethernet, and camera cables to avoid cutting connectors and maintain waterproof integrity.
MCU Communications and Logic
The Jetson Nano acts as the "Master," communicating via USB (the blue cable) to the local MCU and the MCU in Box One.
- Logic Level Shifting: Since the encoders operate at 5V and our system runs at 3.3V, I’ve integrated logic level shifters.
- Timer-Based Pins: The MCU is very specific about which pins it uses for encoders and PWM because they are timer-based. We have identified three encoder-compatible pins and are auditing the manual to find more.
Final Weatherproofing
To wrap up the hardware side:
- The de-serializer board is confirmed to be 14.8V tolerant, making it safe for direct alternator power.
- I am installing blanking grommets in all unused holes. This is a small but critical step to keep insects and debris out of the enclosure, which could otherwise cause shorts as they grow or nest.
MCU Configuration and Pin Mapping
Encoder and PWM Trade-offs
I’ve integrated four-core cables for the encoder channels. While an initial LLM analysis of the datasheet suggested a theoretical maximum of 10 encoders and 4 PWM outputs, there is a clear trade-off between these functions. Through experimental verification, I’m aiming for a balanced configuration—likely 8 encoders and 6 PWM outputs.
The system currently uses logic level converters to handle 5V encoders. Note that 12V encoders would require custom wiring in the provided "hackable space" on the board.
Current Pin Assignments: | Function | Component | Pins | | :--- | :--- | :--- | | Encoder 1 | Input | PA0, PA1 | | Encoder 2 | Input | PE9, PE11 | | Encoder 3 | Input | PD12, PD13 | | Encoder 4 | Input | Testing in progress | | PWM | Speed Control | PE4, PA5, PC7 |
Modular Hardware Adaptations
The beauty of this system is its modularity. Although this is "Box Two" (the Camera Box), it can be adapted depending on the rig requirements:
- Motor Controllers: Currently, I only have one dual-channel controller for the pan-tilt cameras. However, there is room to bolt on 3 to 4 single-channel controllers if needed.
- GPS Integration: While this box doesn't use it, the board is designed to support a bolt-on GPS system.
- Stacking: There is potential to raise the PCBs using standoffs to insert additional layers, such as extra motor controller boards, above or below the current stack.
Physical Clearances and Enclosure Fit
With the lid on, the FAKRA camera cables present a height restriction. They exit the de-serializer board vertically, meaning the Jetson/Nano PCB stack cannot be raised much higher without putting stress on the connectors or requiring a sharp bend in the cables.
I estimate there’s about 30mm of vertical play available, which might just be enough for one extra layer of motor control if I’m careful with the routing.
The Full Rig Setup
In the final configuration, this Camera Box (Box Two) will sit alongside Box One. Box One is identical in size but omits the Jetson and de-serializer board to provide maximum real estate for heavy-duty motor controllers and the primary GPS system.
2Assembling Box 1, the Engine and Vehicle control Box
Box 1 Baseboard Assembly
I am soldering the Box 1 baseboard, which handles engine starting, glow plugs, steering, and throttles. To keep boxes less cluttered, hydraulic actuator controls and cameras were moved to Box 2
High-Current Power Hack
- Standard PCB relay holders and traces can't handle high current—40A for the starter and 20A for glow plugs.
- The Solution: I manually solder heavy copper bus bar wires across the back of the PCB to reinforce connections.
- Soldering: A 450W iron is used for these heavy connections.
Key Components
Switches: Eight L293D motor controllers are DIP mounted for easy hand-soldering.
- Control: Relays are controlled via these switches because MCU pins cannot provide enough current for the coils.
- Power: A 5V regulator with capacitors provides stable logic power.
- Sensors: An optional current sensing system helps prevent motor burnout during stalls.
- Expansion: Supports stacking Cytron motor controllers and an add-on board for 16 extra relays.
Standoffs and Mechanicals
- Precision: I use a stencil for correct solder amounts on small components.
- Clearance: Standoff lengths (30mm–50mm) are critical as the MCU is underslung.
- Mounting: Four-pronged 4mm captive nuts secure the board using pre-drilled holes.
Assembly Tips
- Wiring: I reversed terminal blocks to face inward for better cable access.
- Fragility: Be gentle; thin PCB traces rip easily if you pull on terminals.
- Testing: If damaged, bridge a connection from the resistor to the screw terminal
Populating a 20-channel high-side switch PCB from PCBWay. Using white PCBs for this project is helpful because they reflect light inside the enclosure, making it much easier to see what you are doing compared to dark or black boards.
Component Overview
- High-Side Switches: These are ideal for components like flashing beacons and hydraulic solenoid valves.
- Automotive Relays: While not populated today, these typically go together with this build to control high-current engine functions like glow plugs and starter motors (up to 40A).
- Stencil Usage: Using a stainless steel stencil makes application much easier and more precise than doing it by hand.
- Alignment: The parts on this board are relatively large, making it simple to line up the stencil.
- Solder Paste: It is important to use fresh solder paste; if it has been sitting for more than six months, it can "go off" and lose effectiveness, especially for fine components.
- Technique: Apply the paste with a squeegee, ensuring all holes are filled to the top. The stencil must be removed vertically to avoid smearing.
Soldering and Reflow
- Reflow Oven: The PCBs were designed to be the maximum size that fits into the reflow oven.
- Edge Issues: Sometimes the oven fails to properly solder components near the edges of the board.
- Manual Touch-ups: Any incomplete joints at the edges can be finished by hand.
- Heavy-Duty Iron: A 450W soldering iron is used to heat the large tabs on the high-side switches to ensure the solder flows through correctly.
Finishing and Testing
- Cleaning: After soldering, the board is scrubbed with isopropyl alcohol and a wire brush to remove any stray solder blobs.
- Verification: The board will undergo a final test with a continuity meter before attaching the WAGO connectors.
instructions for assembling the components onto the WEEDINATOR MCU PCB.
Initial SMD Population and Stenciling
- Voltage Regulators: Start at the top left with the 5V and 3.3V surface mount regulators. Ensure you use the correct D2 pack components for the 3.3V line, as wiring configurations vary.
- Optional Circuits: The board includes options for a CAN bus and an SBUS circuit, alongside standard 0603 LEDs.
- Debugging Tools: Voltage dividers (using 0603 resistors) and a buzzer are included to assist with commissioning and system debugging.
- Stencil Preparation: Use a microscope to align the stencil for precise solder paste application.
- Cleaning: Clean the stencil with isopropyl alcohol immediately after use to prevent the paste from hardening.
Component Identification and Reflow Preparation
- Resistor Identification: Carefully distinguish between 10k and 1k resistors. The 1k resistors are marked with a "0," while the 10k resistors may require a microscope to read.
- LED Orientation: Tiny green marks on the LEDs indicate the cathode (negative) side.
- Buzzer and Capacitors: Align the buzzer according to the positive mark or PCB graphics. Install the 5V and 3.3V regulators; the ground tab provides the primary connection. Include black crescent capacitors to stabilize the voltage supply.
- Inspection: Use a magnifying glass to verify all placements before placing the board in the reflow oven.
Through-Hole Soldering and MCU Headers
- Transistor: Install the ZX450 NPN transistor used for the SBUS signal inverter, following the graphics on the PCB for correct orientation.
- Header Alignment: When installing male/female headers, solder only the ends first.
- Fit Testing: Slide the MCU board onto the pins to ensure they are perfectly vertical before soldering the remaining pins. This prevents physical stress or cracking of the MCU chips.
Fitting the MCU and Terminal Blocks
- Installation Hack: Use a practice MCU and a small amount of lubricant (like WD-40) to help the board slide onto the headers without stress.
- Removal: If you need to remove the MCU, use a screwdriver to prize it off gingerly to avoid bending the board into a "banana shape."
- WAGO Connectors: Use high-quality orange WAGO connectors instead of screw terminals. Solder only the ends first to ensure they are seated flat against the PCB before finishing the row.
Final Connections and Testing
- Grounding and GPS: Solder all ground connectors and the headers for the GPS daughterboard, which supports two Ublox Series 9 units for heading data.
- Jumper Modification: Remove jumpers SB57 and SB31 to reconfigure the pins for PA1 and PA7 usage instead of Ethernet.
- Power Test: Verify the voltage regulators with a multimeter to confirm stable 5V and 3.3V rails.
- Functional Test: Preload test code to confirm the system beeps and flashes the LEDs upon startup.
GOAT INDUSTRIES
