I was always somewhat disappointed with the commercial inline skate wheels, with built in LEDs that light up dimly as you roll around, due to the limits of the small built in dynamo. So I figured I could make something a bit more fun. Then it turned into a fun excuse to learn EasyEDA, then test JLCPCBs board assembly services for a prototype.
I thought about the project, then came away with a list of initial requirements I wanted to incorporate into the design. First, I wanted to integrate the lights to the skate frames and keep the profile low. I also wanted to add a built in rechargeable battery. I purchased some frames that had a flat profile so I could mount the the prototype board and LED strips. I then measured the width of the skate frames and put some thought into the layout to make the prototype mountable to either side with thermal adhesive tape. I also planned to add a 3D printed translucent outer shell to act as a light diffuser and environmental protection (dust, debris, water, etc.). I added an On/Off switch to save power. I added some push buttons so I could make changes to the patterns without needing to take out my phone.
I later decided that the light patterns should react to my movements using an accelerometer. Each stride should trigger a pattern. I hope to trigger different patterns for skating styles (dancing, wizard, slalom). Using the various changes in directional acceleration as input will take some fine tuning.
zakqwy
testudor | Jakob
Robert Kirberich
turbinenreiter
Oh my god, this is awesome. Im so looking forward to see this in action. Please please please make a video 🙏
Also: i have some bad experience on using those connectors (if i see correctl from the footprint) in such a vibration-heavy environments. Maybe have a look to the JST-JWPF series. They are sealed and thus have a bit more protection when a wire breaks off the crimp. Last thing you want is a shorted battery attached to your leg.
