USB PD and Magic Smoke released
07/18/2026 at 23:15 • 0 commentsTook a bit of a break on this project to catch up on some other neglected tasks. I'm back to making some changes because I managed to release the magic smoke on one of the prototypes when I borrowed a friends USB PD3.0 power supply to charge it. A few seconds later and there was the familiar smell and eventual smoke coming from the components.
I managed to burn the MicroChip MCP73831T-2ATI/OT charge controller, a tantalum capacitor and a schottky diode. I had made the assumption that the power supply would safely do its thing and limit itself to 5v. Not entirely sure the exact cause, but I did add 5.1kΩ to the CC pins on the USB type C port, but clearly more power than the passive charge controller could handle was delivered. I'll have to verify the resistors on the working board match what I specified.
My board is clearly not ready to handle being plugged into the newer power delivery chargers. So I'll have to do some research on what to update for the next revision.
First Test on Asphalt
05/17/2026 at 07:08 • 1 comment![]()
Managed to test them for the first time 🎉. They held up to a few falls, as I was busy looking down trying to see the effect and lost my balance 😅.
My test code doesn't seem to handle the noisy input well, even though I limited to a single axis for forward and backwards acceleration. I would sometimes see the backwards animation flash as I moved forwards.
Also, @Phil Weasel called it with the JST-XH connector. After some rough asphalt and light jumps, the frames would occasionally reset, since I would see the startup test sequence appear. I have some JST-RCY connectors in my parts bin, so will try that next.
Plenty of notes for the list of improvements. I'm looking forward to implementing them.
Mounting Faceplate
05/13/2026 at 21:03 • 0 comments![]()
I was intending to use double sided tape to adhere the faceplate, since I thought that would be the quickest path to a working prototype I could test. But after rummaging through my skate parts bin, I found some skate axles that were internally threaded (M4). These were originally intended for holding the heel brake onto the skate frame, but its just as useful to hold the faceplate onto it. I bought some M4 screws at home depot and was able to mount it securely enough.
I also ordered some silicone plugs for the usb C port, to protect it from road dust during testing. I just need to model a cap for the power switch to call it complete enough for the first revision.
I'll try to demonstrate it to other skaters this coming weekend at a local roller / inline skate camp to see what others think. I'll see if I can recruit a better skater than I to try some fancy moves and record it in action.
3D Printing at the Library
05/11/2026 at 23:24 • 0 comments![]()
I made an appointment at my local library to print the left and right faceplates on their Bambu Labs X1C printer. It came out with a great surface finish from the PEI build plate. The natural PLA diffuses the light nicely. I'm so incredibly glad resources like this are available to the public. Since these parts are printed as a single piece, they should be robust enough for field testing.
Test fit and code
05/06/2026 at 21:53 • 2 comments![]()
( Animated GIF (5MB) incoming... loading... wait... almost there... )
I've printed a split version of the faceplate in natural PLA on my small printer, then glued it together to get a rough idea of the look and fit. I also tested how the code worked with the lights. Despite how rough it looks, I'm pleased with the result. I just need to figure out a simple reliable way to attach the faceplate. I may just use double sided tape for a first try. I also need to tune the parameters in my code so the lights seem more responsive.
coding reactive LED patterns
05/05/2026 at 01:21 • 0 comments![]()
I'm at the point where I want to test what kind of patterns could look good on the skates. I have two basic patterns in mind that I've seen used in other projects, that just need to be adapted for a smaller LED array and to favor the Y axis to detect forward and reverse acceleration.
I was initially going to hunt around for existing code in github repos to understand how they accomplished it, but decided to try to describe what I had in mind to a coding agent (OpenCode + GTP5.1 Codex). I first described the array and how the LEDs were numbered. I then described how to use thresholds of acceleration for the patterns. Then I did my best to described the patterns I had seen in the past. Surprisingly the agent was able to update my arduino test code which had all the pin assignments already defined. The output passed the build process. I loaded the code onto the first prototype with anticipation...
It worked first try! I rolled the frame forward and backwards across my desk and the first pattern looked like what i expected. I then pressed one of the button to change to the second patter. Repeated the movement and while not exactly what wanted, it was pretty close.
I know putting this code together would have taken me days, if not weeks with my meager embedded coding skills. Getting this project to a functional state just got a lot easier. I'm looking forward to exploring new possibilities with the help of an LLM.
Finding a battery for field testing
05/04/2026 at 23:44 • 0 comments![]()
For initial testing, I've been using an unlabeled battery from a conference badge I had lying around. It just happened to have the 2 pin JST PH 2mm female connector. I checked the polarity and voltage with my multimeter. Voltage was correct, but black was positive and red was negative. So I traced the wire to the battery protection circuit and it had the correct plus and minus symbols to back my findings. I charged it up and plugged it in... then it powered right up. Ran my test code without issue. I was a bit surprised, not sure why I was expecting something to fail.
Since I don't want to rely on that old battery, I started to search for one online. I wanted something that would last a few hours, I decided to look for a 1500 mah, since I've seen plenty of lit up badges run off one for the day, so long as they aren't at max brightness. I started looking for a battery pack on Aliexpress. I have some size constraints for the little gap between the frame and boot. The frame is 34mm wide, the height of the gap is 10mm and length about 100mm. After looking for a reasonable priced 2 pack, I found a 3.7V 703450 Lithium Polymer Battery that had the appropriate JST PH connector. It had a protection circuit, so I decided to buy it and paid $13.73 with shipping. I should get the part in a little over a week.
Modeling a Faceplate
05/02/2026 at 06:41 • 0 comments![]()
I took a shot at quickly modeling a faceplate using TinkerCAD using the 3D scan as a reference. I hadn't used it for some time, so I was pleasantly surprised to find that they incorporated a new sketch tool. This allowed me to roughly outline the side of the frame and extrude it. I added some holes and gaps to account for the switch and usb port. I now had a basic face plate to print.
The library didn't have any slots, so I'll probably split this model in two parts so I can print it on my 3D printer. I'll post some pictures of the first face plate mounted to the frame. I just plan to use some double sided tape. Eventually I'll make someting that attaches more firmly with clips or something.
Frame Scan
04/30/2026 at 20:27 • 0 comments![]()
I am planning to add an external face plate to the skate frames. It would attach to the outside of the frame and be removable. Its primary purpose is be a light diffuser for the RGB LEDs, but also protect the electronics from dirt and debris. My tolerances on the initial working prototype will be kind of loose, as I really just want to get out and skate with them to see how they'll hold up to some mild abuse.
I was initially going to take some photos from above, adjust for lens skew, and outline the shape in Inkscape. So I could then extrude it in CAD and print a first iteration.
Fortunately for me, I attended a local 3D print meetup and met someone who was showing off his 3D printed scanning table that he was using with his Creality RaptorX scanner. I hadn't considered 3D scanning, since my past experiences with scan quality were poor. I thought the reflective metal surface and anodization on the aluminum skate frames would be too much of challenge. But apparently these newer scanners are much better, as the scan quality was quite good and dimensionally accurate. It took a little effort to line up the point clouds from two separate scans and remove the noise, but the STL the software output was very good.
I decimated the model a bit further in MeshLab so I could import it into TinkerCAD that has a file size limit.
Since the dimensions of the frame are a bit larger than my 3D printers bed, I'm planning to go to my local library to print it. Most of the libraries in my area now have a Bambu Carbon X1 printers, so the print will fit on the large build plate diagonally, allowing me to print it as a single solid piece.
Right Frame Assembled for Testing
04/25/2026 at 05:25 • 0 comments![]()
Here is the board assembled and adhered to the skate frame.The battery pack lives in the gap between most boots mount points. I forgot to add thermal reliefs to the ground pads for the LED strips when I changed the layout of the board. I was also impatient and adhered the PCB to the frame with some thermal tape. So I had a hard time soldering the ground pads... hopefully there aren't any major cold solder joints that will break when I subject this to vibrations on the asphalt.
Fortunately everything else is still working. It remains low profile. So now I just need to 3D print a translucent cover to act as a light diffuser and dust/debris protection. I'll eventually add a conformal coating, but I expect to need to make changes as I test this.
