I was always somewhat disappointed with the commercial inline skate wheels, with built in LEDs that light up dimly as you roll around, due to practical constraints. So I figured I this was a fun personal problem to tackle as a project. Which then turned into a fun excuse to learn EasyEDA, then test JLCPCBs board assembly services for a prototype.
I thought about the project, then came away with a list of initial requirements I wanted to incorporate into the design. First, I wanted to integrate the lights to the skate frames and keep the profile low. I also wanted to add a built in rechargeable battery. I purchased some frames that had a flat profile so I could mount the the prototype board and LED strips. I then measured the width of the skate frames and put some thought into the layout to make the prototype mountable to either side with thermal adhesive tape. I also planned to add a 3D printed translucent outer shell to act as a light diffuser and environmental protection (dust, debris, water, etc.). I added an On/Off switch to save power. I added some push buttons so I could make changes to the patterns without needing to take out my phone.
I later decided that the light patterns should react to my movements using an accelerometer. Each stride should trigger a pattern. I hope to trigger different patterns for skating styles (dancing, wizard, slalom). Using the various changes in directional acceleration as input will take some fine tuning.
testudor | Jakob
blinkingthing
charliex
Oh my god, this is awesome. Im so looking forward to see this in action. Please please please make a video 🙏
Also: i have some bad experience on using those connectors (if i see correctl from the footprint) in such a vibration-heavy environments. Maybe have a look to the JST-JWPF series. They are sealed and thus have a bit more protection when a wire breaks off the crimp. Last thing you want is a shorted battery attached to your leg.
