Black Magic Probe remixed to replace the silly fingerprint reader on my X220. Might work on other Thinkpads too. ARM debugging for all!
Drilled a few holes in my palm rest and press-fit a few ~4mm lengths of thick plastic fiber optic strand I had lying around:
[above: crappy light pipes installed, BMP messed with until all four LEDs light up. Left to right: power (green), error (red), activity (orange), usb-serial (yellow).
I may update this in the future if I end up trying it out with other Thinkpads, but for now this project is getting switched to 'complete'.
As the title says, soldering the tiny XSON8-packaged level shifters was a real pain in the ass. I didn't make a stencil for TP-BMP but I did stretch the footprint out a bit, so I tried hand-soldering them but to no avail. You can probably see why:
[above: image of the bottom of the level shifter in XSON8 form, sitting on a standard 0.1" spaced board for scale.. Note that this is really an LGA, so unlike a QFN the pads don't actually extend to the side of the package. Not hand-soldering friendly.]
I probably should have gotten a stencil and started over with a fresh board, since I have a few extra. Instead, I bodged on a bit of solder paste and hit the components with a hot air gun. This didn't work at first, so I touched 'em up with an iron, tested the board, desoldered two of them, cleaned up the joints, etc .. repeat for a lot longer than I should have spent on this project. But finally...
This project is a layout-only exercise, so it starts with the Black Magic Probe Mini v2.1 schematics published in the FAQ section of the project's wiki. After reproducing the schematic in KiCad, the X220's palm rest was measured and test-fitted with a cardboard mockup:
(above: getting rid of the thumbprint reader/metal shield and replacing them with a cardboard template. Yes it kind of looks like a backwards Utah.)
Putting everything in KiCad suggested that the shape and size above would work given the connector location constraint and the component footprints. This design is quite a bit larger than the original Mini and has components on both sides; this made PCB layout quite a bit easier than the Black Sphere design:
[above: a KiCad screenshot of the 4-layer board (sig-gnd-vcc-sig) with one middle layer track, which probably isn't ideal.]
After reflowing the QFN STM32 and soldering the rest of the board together (other than the level shifters which are backordered, ugh), a fit check suggested that the hole spacing needs a tiny bit of adjustment but works well enough for v0.1:
[above: TP-BMP installed in the X220's palm rest. Note missing level shifters. Also the cutout for the fingerprint sensor had to be widened a bit to clear the 10-pin JST header.]
I forgot to take pictures of the firmware loading process; in the image above, one can see the test pads below the STM32 that were used for this process. A Discovery Board was used (well, its ST-LINK, at least) along with st-link to load the stock BMP firmware and bootloader binaries. After re-installation, the board enumerated (!!!), so now it's time to drill LED holes, finish the wiring harness, and solder on the level shifters (when they arrive).
When I started this project, I had an inkling that the fingerprint reader spoke USB. To verify this, I popped the board out of my computer and tacked on a few test wires:
I labelled the wires according to position on the FFC header, snaked them through the fingerprint reader cutout, and reassembled the computer so I could 'scope 'em:
[above: testing potential USB traces, prior to getting over my fear of disassembling my laptop without disconnecting power/battery]
This didn't tell me much, beyond suggesting that the fingerprint reader didn't require +5VDC. Most of the wires seemed to be +3.3VDC or ground, but a few appeared to have some interesting signals on them. I decided to butcher the fingerprint board and make an FFC header breakout so I could convince myself everything worked:
[above: another 10x loupe shot confirming that breakout boards are for suckers]
[above: always looking for an excuse to carve FR4...]
Eventually, I bodged together a breakout and located the two USB data pins. I tested everything using a hacked-apart ST-LINK from an STM32F0 Discovery Board to program a #NeuroBytes Interneuron:
That's a great idea. I haven't used that fingerprint scanner in ages (after the novelty wore off). I haven't used a debugger/programmer, on the other hand, in five hours.
Heck, even an embedded TTL serial port would be rad.
Now you've got me thinking about how much free space there is in there...
Once you verify that this is working fully, I might just use your copy of the schematic as a base for a Black Magic Probe with a USB Type-C connector. 'Cause I'm a USB Type-C nerd, and I don't want to copy a schematic if I don't have to.
I like that idea a lot. Should know within a few days if everything is sorted, the level shifters shipped!
Works! Well, at least TPWR and the SWD stuff. Haven't checked the UART or other JTAG connections but I have no reason to suspect they're wrong on the schematic.
I love this! Brilliant idea and flawless execution.
