While developing my rover, I had to consider the problem of control. Even though it’s autonomous, manual control is still an important feature for testing and development. There were 2 options:
- Buy a controller + receiver combo for $60
- Spend $40 + 50 hours of work building my own
Naturally, I chose the second option. Designing a controller might sound trivial, especially compared to robots, but it actually poses a few major challenges:
- You have to fit a display, microcontroller, battery, charging module, switches, speaker, audio module, radio, and last but not least, 2 joysticks into a compact enclosure that is also comfortable to hold.
- A controller needs to be portable, which means integrating a battery, charging module, and in this case, wireless charging.
- This controller needs to work with current and future projects, which means creating a protocol that is flexible enough to control a high-speed drone and a slow high-torque rover.
I chose the Raspberry Pi Pico because I was tired of it sitting on my desk, and it conveniently has the processing power this project needs.
I didn't want this to look like a toy.
I wanted it to be sleek, ergonomic, and have a bit more of a rugged aesthetic.
Everything was modeled inside of Fusion 360 and 3D printed out of PETG-CF and TPU. I specifically chose TPU with low infill settings for the grips of the controller to give it a more comfortable feel.
The front of the controller has a mount for a 3in FPV monitor so the user can see both the live video feed and the data on the controller’s display without having to look away.
The biggest challenge was the software protocol. I developed a custom packet structure that allows the controller to handshake with the receiver and identify what it’s talking to.
Rover Mode uses high-resolution throttle curves for precise movement.
Drone Mode uses low-latency, high-frequency updates for stable flight.
Building this taught me that ergonomics is an underrated engineering skill.
I went through several iterations of joystick placement and grip angles before it felt right.
There’s a reason commercial controllers look the way they do, but there’s also a lot of satisfaction in knowing every line of code and every solder joint in the device that’s keeping your expensive rover or drone from crashing into a lake.
The nRF24l01+PA+LNA radio transceiver module has a hypothetical max range of 1km, although real world conditions vary. I haven’t tested it yet, but I expect a realistic range of around 400m.
The FPV feed is independent of the control link, and its range is determined by the VTX power. I’ve upgraded to a Lollipop 4 antenna on the controller mount to improve signal quality and consistency.
VTX Power | Estimated Range |
25mW | 100-300m |
200mW | 500-800m |
600mW | 1.5-3km |
Once the rover and drone are complete, I will finalize the user interface and control settings so that they smoothly integrate with the different requirements of those projects.
I am considering adding data logging; however, this will most likely be done on the robots and drones themselves.
Alex
PointyOintment
alireza safdari
ken.do
