The Parts.
07/06/2017 at 19:41 • 0 comments1 5 X Soil Hygrometer Humidity Detection Module Moisture Water Sensor for Arduino $8.89 1 Adafruit (PID 393) AM2302 (wired DHT22) temperature-humidity sensor $16.00 1 JBtek 8 Channel DC 5V Relay Module for Arduino Raspberry Pi DSP AVR PIC ARM $8.98 2 2PCS Two Position Three Way Miniature Solenoid Valve DC 5V 6V $9.95 1 LEDMO Switching Converter, AC/DC Power Supply, AC 100V/240V to DC 12V 10A $9.95 1 Yeeco DC 3.5-12V 6V 9V 12V Water Pump Electric Brushless $13.46 1 Elegoo MEGA 2560 R3 Board ATmega2560 ATMEGA16U2 $11.99 1 OCR 20PCS 2.54mm Breakaway PCB Board 40Pin Male and Female Header $6.49 1 Lasko 106 My Heat Personal Ceramic Heater, Purple $19.23 1 URBEST Inlet Module Plug 5A Fuse Switch Male Power Socket 10A 250V 3 Pin $5.99 1 Sandisk Ultra - Flash memory card - 16 GB $9.95 1 Arducam 15 Pin 1.0mm Pitch to 22 Pin 0.5mm Camera Cable for Raspberry Pi Zero $7.99 1 Remington Industries 22 AWG Gauge Stranded Hook-Up Wire $10.35 1 Heat Shrink Tubing 532pcs innhom Ratio 2:1 $7.49 1 Mini Mist Maker Fogger Water Fountain Pond Fog Machine Atomizer $10.99 1 JSER Left Angled 90 Degree Micro USB OTG to Standard B Type $6.00 1 18 in. x 24 in. x 0.093 in. Clear Acrylic Sheet Glass Replacement $10.27 1 GE All Purpose Silicone I 10.1 oz. Clear Window and Door Caulk $5.21 1 Abbott Rubber Company 1 in. O.D. x 3/4 in. I.D. x 10 ft. Vinyl Tube $21.32 1 Unique Bargains 13.1Ft Clear White Flexible Air Pump Bubble Oxygen Pipe Tube $9.38 1 Aqueon® Glass Aquarium 10gal $14.99 1 Arducam 1602 16x2 LCD Display Module White on Blue with Backlight $5.99 1 10Pcs 5 x 7 cm DIY Prototype Paper PCB Universal Board New $6.99 1 PryEU 4-Pack White 12V Super Bright LED Strip Lights Waterproof 12'' 30cm $12.48 1 RoadPro RPCBH-25 Hardwire Replacement CB Power Cord-2 wire , 25-Feet $5.23 1 ClearMax Universal 18AWG Power Cord (UL Approved), 12-Feet $7.99 1 50CT Peat Strip $6.00 1 Aqua Culture Small Pebbles Aquarium Gravel, 5 lb $3.98 1 Small Enclosed Piezo w/Wires $4.94 1 Pixma USB 2.0 Printer Cable Cord A-B 10' 10 FT $4.99 3 USB Car Charger $0.75 1 Cooler Master Sleeve Bearing 92mm Silent Fan $5.97 2 Cooler Master Rifle Bearing 80mm Silent Cooling Fan $4.99 1 TOOGOO(R) 30mm x 30mm x 10mm 3010S 12V 0.06A Brushless DC Cooling Fan $2.17 1 1 Gallon Plastic Jar, Wide Mouth, Clear $10.69 1 Crystal Clear Plastic Jars with Screw on Lids 16 oz Set 6 Wide Mouth $16.95 1 Blue Sea Systems 8 Circuit 20A Terminal Block $5.24 1 PCB Mount Screw Terminal Block Connector, 100 Pack (2 Pole 5 mm Pitch, 10A 300V) $9.95 1 Hisurprise 1000 Pcs Black Plastic Cable Zip Tie Fasten Wrap 80mm x 2mm $3.40 1 6 Gauge Clear Vinyl Fabric By The Yard $1.95 1 Sonline 50x Through Hole Carbon Film Resistors 220 Ohm 1/4W 5% $1.78 Total (Your price tag may vary based on what you buy.) $280.07 Notes:
- I've been told capacitive moisture sensors are better and last a lot longer than resistive moisture sensors that tend to corrode.
- Looking to use LED Grow Lights.
- Might switch out the heater with hairdryer with a mini P.C cooling fan instead to get rid of noise and for a less aggressive airflow.
- Make sure the mini fountain fogger is 12v.
Daniyal Ansari
