R909-tester PCB is ready, but found a bug during assembly!
07/25/2026 at 10:11 • 0 commentsTo speed up my experiments and add more features, I decided to design and build a custom PCB. However, during PCB layout, I accidentally flipped the orientation of the I2C pin header for the OLED display and routed it on the wrong side! Fortunately, it doesn't affect debugging at all—I just mounted the display turned around, and it works fine for now.
https://nobcha23.hatenablog.com/entry/2026/07/20/191050
The tester includes a continuity tester, capacitance meter, diode checker, and a frequency counter. Surprisingly, the frequency counter responds up to 50 MHz!
---50MHz displayingI've uploaded the Gerber files for this PCB to GitHub.
--Link address Gerber sketch:
https://github.com/Nobcha/R909-tester/blob/main/R909-tester_Rev1.0_ERRATA.zip -
Firmware Architecture: Taming Complexity with a State Machine
07/11/2026 at 08:19 • 0 commentsThis is a project log for R909-Tester: A Modular RP2040 zero Instrument
In the previous log, I walked through the hardware design. Now that the prototype is taking shape on a breadboard, it's time to dive into the firmware—specifically, how I'm managing the growing complexity of this multi-function instrument.
The Problem with Simple Sketches
When this project started as just a continuity tester, the firmware was trivial. A single loop() function ran the test and that was that. But as I added a capacitance meter, a frequency counter, and a diode identifier, things got messy fast.The naive approach would be something like this:
cpp void loop() { if(mode == 0) continuityTest(); else if(mode == 1) capacitorMeter(); else if(mode == 2) frequencyCounter(); // ... and so on }This works for a handful of functions, but it quickly becomes a maintenance nightmare. What happens when you want to add long-press vs. short-press button handling? What about sub-states within a measurement mode, like charging, waiting, and calculating for the capacitance test?
The answer, as many experienced embedded developers will tell you, is a state machine. I adopted this approach for the R909-Tester, and it's made all the difference.
Two-Level State Management
Level 1: Application Modes (Top-Level States)First, I defined the main operating modes of the instrument:
cpp enum Mode { CONTINUITY, CAPACITOR, COUNTER, DIODE };Switching between these modes is triggered by the rotary encoder. The logic is clean and contained:
cpp switch(currentMode) { case CONTINUITY: continuityTest(); break; case CAPACITOR: capacitorMeter(); break; case COUNTER: frequencyCounter(); break; case DIODE: diodeChecker(); break; }
Adding a new function is as simple as adding a new enum value and a case statement. This modularity is a huge win for code organization and maintainability.Level 2: Internal States (Sub-States)
But the story doesn't end there. Some measurement modes have their own internal sequences. The capacitance meter, for example, needs to:Discharge the capacitor
Wait for the discharge to complete
Start charging through a known resistor
Wait for the voltage to reach 63.2% of VCC
Calculate capacitance from the time constant (τ = RC)
Display the result
Using delay() to manage this sequence would block the entire processor, making the rotary encoder unresponsive and the user interface feel sluggish. That's a non-starter.
Instead, each mode manages its own internal state. Here's the state enum for the capacitance meter:
cpp enum CapState { CAP_IDLE, CAP_DISCHARGE, CAP_DISCHARGE_WAIT, CAP_CHARGE, CAP_CHARGE_WAIT, CAP_CALC, CAP_RESULT };
The main loop doesn't block. It runs continuously, checking the current sub-state, performing a small step of the measurement, and then updating the state as needed. This keeps the user interface responsive at all times. https://nobcha23.hatenablog.com/entry/2026/06/25/160209Why This Approach Works
Responsiveness: By avoiding blocking delay() calls, the rotary encoder remains responsive during measurements.Modularity: Adding a new mode or changing the behavior of an existing one is localized. I don't have to rewrite the entire firmware.
Future-Proofing: This architecture provides a solid foundation for future features like a settings menu, EEPROM storage for calibration data, or even a simple data logging capability.
Easier Debugging: With well-defined states, tracing the flow of the program is much simpler. You can log state transitions and instantly see where things are going wrong.
https://chitose6thplant.fc2.page/r909-tester/
The RP2040 Advantage: PIO State Machines
It's worth noting that the RP2040's PIO (Programmable I/O) blocks are also state machines, but at the hardware level. While the software state machine I've described here manages the overall application flow, the PIO state machines run independently on the RP2040 to handle real-time I/O tasks, like the high-speed pulse counting for the frequency counter. This is a powerful combination: software state machines for application logic, and hardware PIO state machines for performance-critical tasks.In the next log, I'll show how this architecture made it almost trivial to integrate the frequency counter and add a diode identifier.
Hardware Design: From Breadboard to Prototype
07/04/2026 at 15:31 • 0 commentsIn the previous log, I talked about why this project exists. Now, let's get into the what – the hardware.
The core of this instrument is the Raspberry Pi Pico Zero (RP2040) of Waveshare. It's cheap, powerful, and has enough I/O to handle all the functions I wanted to pack into this tester.
Here’s a quick tour of the main hardware blocks.
The Brain: Waveshare RP2040 Zero
I chose the Pico Zero because it gives me a complete, ready-to-use RP2040 board in a compact form factor. It already has the large flash memory, and the USB port, so I can focus on the application circuitry. The dual-core Cortex-M0+ and the PIO (Programmable I/O) are also big pluses – especially for the frequency counter, which I'll talk about in a later log. Comparing with ATmega328P it's attractive for USB-IF and large memory.User Interface: OLED + Rotary Encoder
For display, I'm using a small SSD1306 OLED (I2C interface). It's simple, low-cost, and perfect for showing measurements and menus. The rotary encoder (with a built-in push switch) handles all user input: turn to select functions, press to confirm. No touchscreen, no complex keypad – just a clean, minimal interface.![]()
Continuity Tester:
This uses a simple voltage divider on an ADC pin (GPIO26). The firmware reads the voltage and decides if the circuit is open or shorted. V-open and I-short is enough small to avoid bad influence for the circuit on testing. I
There's also a buzzer (on GPIO6) that gives audible feedback – because sometimes you just want to listen for the beep.
Capacitance Meter:
This is based on the classic RC charge time method. A known resistor (100kΩ) charges the capacitor through a test terminal, and the firmware measures the time for the voltage to reach 63.2% of the supply voltage (VCC) on an ADC pin (GPIO26). From that time (τ = RC), it calculates the capacitance. There’s a small trick to discharge the capacitor quickly between measurements using a GPIO pin as a switch. At first I let GPIO26 change as a digital port, but in vail GPIO26 will not work so.
Frequency Counter:
This one uses the RP2040's PIO feature. The PIO can count pulses very fast and accurately without bogging down the CPU cores.
Diode Identifier:
This function measures the forward voltage drop (Vf) of a diode using a constant current source.
Power and PCB
The whole circuit is currently running on a breadboard. That's how I test and iterate quickly. I'm currently working on a custom PCB to make it more robust and portable, and I'm in talks with a PCB manufacturer to get the board made. -
R909-tester: What It Is, What It Does, and Why You Should Care
07/03/2026 at 10:04 • 0 commentsSo, I tried to turn the leftover RP2040 boards into a useful prototype.
What It Is
R909-tester is a modular, low-cost instrument platform built around the Raspberry Pi RP2040 Zero. It's designed to be a handy companion on your workbench, combining several useful measurement functions into a single, compact device.
What It Does (The Functions)
Currently, it packs four main tools:
Continuity Tester: Quick and audible checks for your circuits.
Capacitance Meter: Measures capacitors in a practical range.
Frequency Counter: Counts signals – with some limitations I'll discuss in a later log.
Diode Identifier: Identifies and tests diodes.
All of this is controlled through a simple OLED display and a rotary encoder. No complex menus – just select the function and go.
Why I Built It (The Design Intent)
This project was born from a simple question: "How far can I take a practical instrument using just an RP2040 and minimal external parts?"
It's not about replacing a $500 multimeter. It's about exploring the boundaries of what's possible with this cheap and powerful microcontroller, and creating something genuinely useful for everyday electronics work.
The Modular Concept
I also designed it with modularity in mind. The core hardware and software are structured so that adding new features – or even replacing existing ones – should be straightforward. This is why I'm planning to explore adding an external ADC for a SINAD measurement add-on in the future.
What's Next (The Roadmap)
Short-term: Refining the existing features and improving the frequency counter (more on that in its own log!).
Long-term: Designing a custom PCB, building a proper enclosure, and exploring the SINAD add-on.
So, that's the plan. If you're interested in seeing how far a cheap RP2040 zero can go as a test instrument, stick around. It's going to be a fun ride.
The Real Reason I Built R909-tester (It Wasn't Planned)
07/02/2026 at 14:44 • 0 commentsThis project didn't start with a grand plan to build a multi-function tester. It started with a disappointment.
I was working on the ESP32-C3 version of my SINAD indicator. The ADC performance was… not great. So I thought: "What if I try the RP2040? Maybe its ADC is better suited for this kind of measurement." https://nobcha23.hatenablog.com/entry/2025/06/10/211826
The RP2040's ADC turned out to be slightly better – but still not enough for serious measurement work. I realized that for real accuracy, I would need an external ADC. And that meant dealing with I2S, which turned out to be its own can of worms.
So there I was: a handful of RP2040 boards sitting on my desk, no clear use for them, and a bit of frustration. https://nobcha23.hatenablog.com/entry/2026/04/01/194146
That's when I thought: "Why not turn them into something useful? A simple tester, maybe? Just to put these boards to work."
And that's how R909-tester began – not as a brilliant idea, but as a way to salvage some boards and learn something along the way. It turned out to be a fun project after all.
nobcha
