SateLight - A customizable, modular desktop light
A desktop lamp that is hackable, customizable and looks good. Add small magnetic modules for infinite functionality.
Inspired by how the real space stations attach and add more parts to fit their need, I am experimenting with a programmable desk object. SateLight is not meant to be just another desktop lamp though, it has magnetic connectors all around so you can expand it with sensors, lights, mechanical parts, decorative parts and and create different, unique or crazy assemblies of a miniature space station.
The expandability is endless. Temperature readings, LCD Modules to show metrics, touch control, all sorts of contraptions can use this system to make this project yours too! The magnetic connectors can pass through all the nessesities (5v, Ground, I2C_SDA, I2C_SCL).
The future holds much potential for this tiny gadget. With an ESP32 at its core, there could be a self hosted web GUI to setup light paterns, see sensor data, make graphs, create automations, and much more. The sky is the limit.
Challenge: Think of the wildest modules to add to this project!
I've always enjoyed building electronics that are more interesting to look at and interact with than they are strictly necessary.
Instead of designing one fixed-purpose smart lamp, I want to experiment with a customizable desktop version that can evovle through software and hardware.
This project has an ESP32 at its core. Additional complementary I2C modules can be used for environmental and user input sensing. The long-term goal is to create a modular physical platform where many kinds of different hardware can be attached to expand the device's capabilities.
The basic device should be useful on its own as a small ambiend lamp, but additional modules could give it completely different capabilities.
V1 Snap and Light Showcase Short.mp4
Here is a consept of proof to see if the Neopixel protocol would work well with the magnetic system. Here I'm using an ESP8622 with WLED.
MPEG-4 Video - 43.47 MB - 08/13/2026 at 18:07
Download
  • 1 × ESP32-WROOM Main Brain
  • 1 × ATMEGA328PB-AU I2C Neopixel driver
  • 1 × VEML6030 Ambient Light Sensor
  • 1 × SK6812 RGBW (warm/neutral) The Lights
  • A step back
    Chris08/14/2026 at 17:45 0 comments
    Greetings Space-neers.
    After completing a janky prototype cobbled together by plastic, off the self modules and some soldering. I had in my hands the proof needed to continue on with creating the first designs for the enclosure and the PCBs.
    However there was something at the back of my mind that was bugging me. You see, initially I searched for 5 pin connectors to pass through my power, I2C and Neopixel data. But unfortunately this product seems to not exist. At that point I decided to carry on with Power, 1-Wire and Neo-pixel instead.
    The following days I had the first schematic and design ready for a self made 1-Wire light sensor. An Arduino Nano with a LDR (photoresistor) to talk to the ESP. Nonetheless, I was on a path of locking my project away from the community by having complex self made sensor libraries and scarce hardware that people sometimes are not aqcainted with.
    So a major change had to be done.
    After some thinking, the decision was made to complicate the LED modules, rather than challenging everyone who would like to take a spin at this project. Diched all PCB designs and created a small air circuit with an arduino nano I had on hand and a strip of neopixel led strip.
    After some coding, the ESP could fade in and out the led strip. Though the colors were random because the I2C to SK6812 RGBW bridge would control plain Neo-pixels that are only RGB. The fact that the leds had always the same colors, and they were fading properly, locked in this small prototype.
    After also integrating a Temperature Humidity I2C sensor, the time of re-design had come.
  • The Consept of Proof
    Chris08/13/2026 at 18:43 0 comments
    Greetings Ladies and Gentlemen of space.
    The first days of this project started by remembering a comment on my "SateLight - The Ceiling Light" project, asking to add interlocking modules to create different configurations of the space station. Well, not many people want a whole satellite hanging from the ceiling, and adding the modules would be a one time job only, not to mention balance issues.
    Parallel to that I was working on interfacing some 1-Wire sensors at the office, and in the firmware I had created this convoluted way of adding and removing sensors from some system by hotplugingg, the system could periodically discover the sensors and add them or remove them from the logs as needed.
    Sensors that come and go, interlocking modules. Then it hit me! Why not make a modular system to create your own SateLight assemblies? But smaller and nice to play with.
    But how could I make it satisfying? Well, remember these magnetic charging cables for smartphones, yes they are cool, repeatable and have nice snap to them.
    I knew my mission.
    I bough some round magnetic connectors with 4 pins to test how much weight they could handle. I was worried that shear forces would send this project to an early grave. But to my surprise the manufacturer had already sold this problem by using special geometry on the magnetic connector pair. After using the 3D printer to create some holders/testers for the magnets and playing with them a while. I knew that they could easily hold light electronic modules.
    In my excitement I sat and designed the first body iteration of this project, a simple cylindrical enclosure to hold the connectors in place and start testing if I could pass data through them.
    After painstakingly connecting wires from the magnets to the ESP (and burning some leds and an ESP at that).
    I was able to successfully control a Neo-pixel strip.
    Day two was to try and get some light data from a custom 1-Wire sensor that I made using an Arduino Nano and a PhotoResitor. This was also successful.
    Finally I could go into this project seriously.
View all 2 project logs
