Final Testing
an hour ago • 0 commentsWith everything installed in the cover box, we tested the complete system the way it would be used: standing on its own, listening to the room, with no laptop needed to trigger alerts
Designing the shelf-top cover box
4 hours ago • 0 commentsThe loose jumper wires didn't look like something you would put in a relative's home. We designed a small cover box that hides the wiring, looks like a real product, and stands on a top shelf, where the microphone can hear the room and the LED matrix is easy to see.
Upgrading the size of the A.I Model and bugs
4 hours ago • 0 comments![]()
Title: More falling data helped; glass breaking still struggles
We added about 25 minutes of falling sounds to the dataset. Falling detection improved a lot, but glass breaking is still frequently misclassified. We think this is a data problem more than an architecture problem.
The current model is very small: 2 2D CNN layers with kernel sizes of 16 and 8. Ideas to try next:
- Add more layers, or use larger kernels.
- Increase the batch size to train faster.
- Offload training to an external server.
- Look at outside architectures or pre-trained models.
After we deployed our from-scratch model, the device labeled every sound as a fire alarm, including glass breaking, falling, and background noise.
What we found: the fire alarm detection was tied to the 44 kHz audio frequency setting.
Fix: we lowered the frequency setting from 44 kHz to 18 kHz and retrained the model.
More data v2
4 hours ago • 0 commentsWe are on version 2 of the model (.eim file). In testing, it produces many false positives: it flags sounds as emergencies when they aren't, and it rarely gives correct "nothing happening" results. Our next step is to collect more data and more accurate data.
How we came up with the idea
4 hours ago • 0 commentsTitle: 1 – How we came up with the idea Photos: system_architecture.png
At Zotduino @ embedded world North America, we chose the Sensing Challenge (sponsored by Arduino, Qualcomm, Quilter, ASUS). The challenge described an elderly relative who lives alone and a family that wants peace of mind, without a camera in the room and without their audio being sent anywhere.
That framing shaped our goal: a device that listens for emergencies instead of watching for them. We brainstormed sounds that would signal a real emergency for an elderly person living alone, including falling, glass breaking, fire alarms, and cries for help or pain.
We then made three design decisions:
- Keep it private. Classification runs on the Arduino Uno Q, so no audio leaves the room and no camera is needed.
- Make the alert visible. The LED matrix shows an icon for each sound, so the person doesn't need to hear the alert.
- Keep the build simple. Given the limited tools and time at the hackathon, we narrowed the list to three critical sounds (falling, glass breaking, and fire alarm), plus a background-noise class so that everyday sounds are ignored.
We sketched the full flow before building anything: home audio goes to the microphone, then the classifier, then a critical-sound check, then a 10-second countdown, and finally a notification to family (see system_architecture.png). We then split into a hardware group and a software group.
update: size matters
13 hours ago • 0 commentstested on new dataset (added ~25m of falling sounds) classifies much better on falling sounds but a lot of misclassifications for glass breaking. seems to be a data issue more than architecture. current model is very small, plan to either change or increase size. kernel size is currentl 16 and 8 for the 2 2dcnn layers, maybe potential for increase layers/kernel size. Batch size also can be increased to improve training speed. Might offload training and optimization to external server. Potentially look for outside model architectures/pre-trained, might split up work later today.
more data
15 hours ago • 0 commentscurrently on v2 of the eim, looking for more data/accurate data. Many false positives, minimal true negatives
johnh20
