EvilKey: I Needed a FIDO2 Key. Then the Maker Brain Took Over.
ESP32-S3 FIDO2 prototype: touch AMOLED, microSD apps, HID scripts, USB/BLE AirMouse and an IMU BLE Gamepad. A key that got carried away.
A search for a FIDO2 key turned into EvilKey: an ESP32-S3 prototype with touch AMOLED, on-device PIN, USB/BLE AirMouse, an IMU gamepad, HID scripts and microSD apps. Firmware 0.9.1 supports Waveshare PCB V1.0/V1.1, ABI6 apps and signed updates with separate RESCUE firmware.
EvilKey.cmd handles builds, signing keys and packages. Before irreversible Secure Boot activation, choose the repository's release signer or build with your own key, matching trust profile and bootloader. After installing release firmware and activating Secure Boot/HMAC, compatible updates must be signed with the same release key; get them from this repo's Releases. An own-key device needs that same private key for future builds. HMAC protects wrapping-key derivation; Secure Boot checks signatures. Old unsigned installations need the migration guide, not a drop-in SD update.
Firmware/GUI: AGPLv3; SDK: MIT. Manager/examples have separate licenses. Photos show the V1 case; V1.1 fit is unverified.
Real EvilKey GUI on the prototype
Watch the real device and its AMOLED touch interface in the published, silent GUI Short. The ending uses the firmware-inspired animated EvilKey logo. This footage does not show live PIN verification, cursor movement, or script execution.
A longer walk through the 0.7.4 interface
I wanted to show how the screens fit together, rather than leave each feature as a separate clip. This tour moves from the animated screensaver and PIN interaction through Ready and Settings, then into Air Mouse, BLE Gamepad, USB Tool and the Apps screen. There is actual EvilBundle gameplay, including EvilRacer, before the final app gallery.
Watch the EvilKey 0.7.4 Interface Tour on YouTube.
The film is rendered from the real firmware UI running on a desktop host. The PIN and connection/status moments are arranged demo states; they do not show a live FIDO2 sign-in, USB payload or BLE pairing. The Short above remains the physical-prototype GUI footage. EvilBundle is still a private app collection, not part of the public firmware download.
A perfectly reasonable problem, followed by a perfectly unreasonable response
My OpenAI account asked me for FIDO2 authentication while I was working with an active Daybreak Blue model. I needed a security key. The sensible plan was to buy a YubiKey, log in and get on with my life. Naturally, that is not what happened.
I found the open-source Pico FIDO project and ordered a Waveshare ESP32-S3 Touch AMOLED 1.64 board. Then came the maker's classic facepalm: I had overlooked that the community version did not give me everything I had pictured. The sensible response was still to use it as a FIDO2 key. Instead, a very old XDA Developers reflex woke up.
As a teenager I loved getting my hands dirty with firmware for early HTC phones, Windows Mobile and the first generations of Android. Back then, phones felt full of places where a curious community could improve things before manufacturers caught up. I remember how much fun it was to make an existing device do something its original menu had never imagined. That memory made me smile, then made me open the source tree. Apparently the older version of me still enjoys making hardware do extra things. Some useful. Some gloriously unnecessary.
EvilKey is the result: a FIDO2 key that acquired a dark AMOLED touch interface, on-device PIN entry, a script-driven USB tool and, because apparently a key should also steer a cursor, an air mouse. Then it learned to load apps from microSD. Apparently that meant games. The Waveshare PCB is not my hardware design. The EvilKey firmware port, LVGL interface, Windows Manager, original microSD examples and enclosure work are my additions, with the upstream licenses and notices kept visible.
How the feature creep happened
  1. Make the key usable every day. Keep the FIDO2 role and build an interface that is readable on a 280 × 456 touch AMOLED, with large controls and a restrained dark palette.
  2. Put the PIN on the key. The touch screen provides a numeric keypad for FIDO2 built-in user verification: masked entry, a visible retry count and timeout, Backspace, Verify and Cancel. On compatible FIDO2 requests, I enter the PIN on EvilKey instead of typing it into the connected computer. The familiar host-side ClientPIN path remains available for setup and compatibility.
  3. Give it a face. The mint symbol and white crystal became a shared 3D screensaver. Both parts move in the same projected plane; the crystal turns around its vertical axis. The logo stays recognizable even when the animation briefly glitches.
  4. Win back display speed. Keep the LVGL object pool in PSRAM and use two DMA-capable RGB565 draw buffers in internal RAM when memory permits. The preferred layout is two 64-row buffers, with a two 16-row fallback before other buffer layouts. Diagnostics shows what was actually allocated. Firmware 0.7.6 also provides shared SIMD routines for pixel fills, copies, transparent bitmap spans and...
Real photograph of the EvilKey PCB V1 prototype showing the on-device numeric FIDO2 PIN keypad. The photo shows the screen, not a complete live authentication test.
JPEG Image - 1008.03 kB - 09/27/2026 at 20:50
Preview
Concept visualization of the planned black SLS finish. The real working enclosure is currently home printed; this is not a production photograph.
Portable Network Graphics (PNG) - 1.90 MB - 09/26/2026 at 12:37
Preview
Code-derived READY screen preview; not camera footage.
Portable Network Graphics (PNG) - 410.20 kB - 09/26/2026 at 12:37
Preview
Code-derived on-device FIDO2 PIN keypad preview with illustrative masked digits; not a live PIN capture.
Portable Network Graphics (PNG) - 453.30 kB - 09/26/2026 at 12:37
Preview
Code-derived Diagnostics preview. A real device test previously showed 2 x 64 RGB565 draw buffers.
Portable Network Graphics (PNG) - 412.94 kB - 09/26/2026 at 12:37
Preview
View all 11 files
  • 1 × Waveshare ESP32-S3 Touch AMOLED 1.64 (V1.0 tested) ESP32-S3 board with 280 x 456 touch AMOLED and QMI8658C. Firmware 0.7.5 was installed and tested on the Waveshare PCB V1.0 prototype; V1.1 remains an unverified compatibility target.
  • 1 × Short USB-C data cable / loop The prototype uses a short Unitek C14179ABK-style loop. Any equivalent cable must support USB data.
  • 1 × Custom home-printed prototype enclosure Current working case fitted to the Waveshare PCB V1. A professionally printed black SLS finish is planned, not yet produced.
  • 1 × M5 × 10 mm flat-point grub screw One M5 threaded, 10 mm long grub screw with a flat point, used in the current prototype assembly.
  • 4 × M2 × 5 mm screws Four screws fasten the Waveshare PCB V1 from the underside of the printed enclosure.
View all 6 components
  • Firmware 0.9.1: the key gets signed updates, and the builder gets a choice
    Michal Wojciechowski • 3 days ago • 0 comments
    I originally needed a FIDO2 key. After giving it games and an air mouse, I finally came back to the security work I had been promising. Apparently even feature creep can occasionally finish a task.
    Firmware 0.9.1 is out for Waveshare PCB V1.0 and V1.1. This chapter adds signed updates, a separate RESCUE path and an explicit route to HMAC-backed key storage and Secure Boot. There is one decision to make before activating it: whose signing key should this device trust?
    Pick the signer before closing the door
    If you install the signed firmware from this repository's Releases and activate Secure Boot and HMAC, future compatible firmware must be signed with the same release key. Get those updates from this repository's Releases. Unsigned builds and builds signed with your own or another key will be rejected.
    Secure Boot activation is irreversible. Erasing Flash or restoring a backup cannot change that decision.
    You can still build your own EvilKey. Start with your own RSA3072 key, configure its custom trust profile and matching bootloader, and build normal firmware plus RESCUE before activation. That device will then need your same private key for future updates and recovery. Creating another key later does not recover the old identity.
    Secure Boot checks firmware signatures. HMAC protects device wrapping-key derivation; it does not sign firmware. Activation is an explicit device operation. An ordinary build, boot or update does not burn the protection eFuses, and removing the retained plaintext root-key copy remains a separate verified step.
    One place for the builder workflow
    EvilKey.cmd now groups Firmware, Manager, Diagnostics/tests and maintenance. Firmware → Keys and trust can generate a missing own key or import an existing one. The workflow configures the matching trust profile and bootloader, builds normal and RESCUE firmware, and prepares FIRST_INSTALL, UPDATE_SD and RESCUE_SD packages.
    Numbered choices, Y/N confirmations and file/folder dialogs handle the routine selections. Private keys stay outside the source tree. The menu can create a password-encrypted key backup; keep that backup independently of the PC.
    The little apps got attention too
    ABI6-NP1 adds resource banks, transactional saves and more native rendering/input tools while retaining ABI v4/v5 apps and existing saves. The release also brings asynchronous USB storage I/O and NVS/PIN/FIDO fixes. In the games tested, average frame rate rose from approximately 19 to 25 FPS. That is the reported result for those games, rather than a guarantee for every app. The separately licensed games are still not part of the public firmware download.
    Read the installation path before copying files
    An existing compatible signed installation uses the SD update flow: Stage, Activate, Restart and fresh confirmation with the existing PIN. Normal updates preserve credentials, PIN, settings, apps and saves. RESCUE is a separate firmware-repair package.
    The signed SD archive is not a drop-in update for an old unsigned 0.8.x layout. The guarded first-install/migration workflow accepts only supported states and refuses unknown layouts. Follow the current guide rather than the ERASE instructions in older logs.
    Manager stays at 1.1.6; its existing EXE is unchanged, while the source snapshot and native-project export are aligned. USB Tool example scripts are unchanged too. The photographed case remains the V1 prototype; V1.1 case fit remains unverified. This is still an independent prototype, without a FIDO certification claim.
    Firmware 0.9.1 and SDK · Build, trust and installation workflow · Manager · microSD examples
    If you were building one, would you use the repository's signed releases or keep your own signing identity?
  • Firmware 0.8.0: the second board arrived, and V1.1 now works
    Michal Wojciechowski • 10/13/2026 at 23:22 • 0 comments
    The V1.1 board I ordered has arrived. EvilKey now runs on it as well as my original V1.0 prototype. Apparently even “finish the firmware” can produce another menu: this time, at least, it asks which board I actually have.
    Confirmed V1.1 firmware compatibility starts with 0.8.0. The public release contains a separate image for each revision, with matching build information and checksums.
    Same device idea, different startup details
    V1.1 needed its own hardware profile. The display chip-select moved, and display and touch share a reset line. Startup now handles that shared reset before probing touch, rather than resetting the display again after touch has started. The original V1 profile keeps its existing sequence.
    EvilKey.cmd asks for the PCB revision before building or flashing, then uses the corresponding profile and image. This keeps both boards in the same source tree without making a builder edit pin definitions by hand.
    Updating a key and starting with a fresh module
    The first installation on a new module is a different job from updating an EvilKey that already holds data. A factory or unsupported partition table cannot simply be treated as an existing EvilKey layout.
    The uploader checks that situation and offers initialization. It requires typing ERASE before clearing the entire internal flash and installing the bootloader, EvilKey partition table and selected firmware. Credentials and settings in internal flash are deleted on that path. Cancelling stops the operation.
    For a supported existing EvilKey installation, the guarded update preserves protected storage and verifies it after writing. I used that path to install the final 0.8.0 images on both boards; write verification passed and the existing data remained available.
    The hardware check
    After reset, the interface, FIDO/PIN and the functions I normally use worked on both revisions. IMU steering also worked in the V1.1 Gamepad after the BLE host connection was established. A practical reminder: PAIR ON HOST means there is no connected host yet. Connect until BLE CONNECTED, keep the board still for calibration, then try tilting it.
    This confirms firmware compatibility on my two boards. The photographed case is still the fitted V1 enclosure; V1.1 case fit and V2 support remain unverified.
    The rest of the project
    ABI v4/v5 apps, shared SIMD drawing and app-owned models on microSD remain supported. Manager stays at 1.1.6, and the USB Tool examples keep their original scripts. This remains development firmware; the planned key-storage protection and Secure Boot phase is still ahead.
    Firmware 0.8.0, both board images and SDK · Manager source snapshot · microSD examples
    If you build one on V1.1, what would make the setup clearer?
  • Firmware 0.7.6: faster rendering, SIMD and models from microSD
    Michal Wojciechowski • 10/13/2026 at 15:37 • 0 comments
    Firmware 0.7.6 is an important performance update for the little key. I focused on getting more frames out of the same hardware while keeping the existing graphics.
    The measured change
    During development, the average frame rate across a complete native 3D race went from 9.226 to 18.908 FPS. That is approximately 105% more frames per second, or 2.05×. The lowest full-second window improved from 7 to 16 FPS.
    Both measurements covered five cars and three laps on the same PCB V1.0 device, with unchanged clocks and hardware limits. The earlier test used a manual Race; the later test used an automatic Demo Race with a newer application build. These are the development measurements behind the optimized renderer carried into this release.
    Shared pixel acceleration
    Firmware 0.7.6 uses the ESP32-S3 vector instructions for common pixel operations: filling regions, copying pixels, handling transparent bitmap spans and converting display data. The GUI, 2D apps and native scenes share these routines.
    The interface keeps its existing shapes, colours and detail. Hardware clocks and the renderer's work limits are unchanged. This is also why the work belongs in firmware: independent apps can use the accelerated drawing paths without carrying their own native implementation.
    A model belongs to the app
    Native 3D apps can now load indexed .ekmesh models from microSD. The MIT SDK includes an OBJ converter and package tools that put the model files alongside the app.
    The firmware checks the files against the package, validates their geometry and loads them when the app starts. Rendering then uses memory rather than reading the card every frame. An app can position, rotate and scale instances of its own models through the scene API. The same mechanism is available to any compatible app.
    Diagnostics when I need it
    Diagnostics starts off and is enabled in Settings. Turn it on before a new session to collect full-run FPS and the maximum native rendering time. Save report puts the diagnostic report in /evilkey/diagnostics/ on microSD.
    The released image is running on my PCB V1.0 prototype. ABI v4/v5 support and the storage layout are retained. Manager remains 1.1.6, with updated source labels; the USB Tool examples keep their original scripts.
    Firmware 0.7.6, source and SDK · Manager · microSD examples
    What would you make with a small touch display, motion input and your own models on the card?
  • Firmware 0.7.5 — rendering on both ESP32-S3 cores
    Michal Wojciechowski • 10/09/2026 at 21:42 • 0 comments
    With the Jet interface in place, firmware 0.7.5 brings changes to how EvilKey draws it.
    The GUI and native 3D renderer now share rendering work between both ESP32-S3 cores. The GUI splits the image into horizontal bands, while native scenes distribute alternating rows between the cores.
    There are also several changes inside the rasterizer. It calculates the part of each row covered by a triangle, skips invisible geometry earlier, and reuses transformed cube vertices across faces. Frequently used data stays in internal memory, and color and depth are packed together to reduce separate PSRAM accesses. The graphics keep their existing appearance and detail.
    Diagnostics now has a Save report button. Instead of checking each screen separately, you can save all seven diagnostic cards to one text file on the SD card. The report includes memory usage, display buffers, rendering times, and activity on both cores. Files are saved in /evilkey/diagnostics/.
    Another addition concerns switching the SD card back from the computer to EvilKey. Using Eject on the computer now turns off Manager Drive. EvilKey saves the setting and briefly restarts, reconnecting without the USB storage drive so local apps can access the card again. You can turn Manager Drive back on when you need it.
    Existing ABI v4/v5 applications remain compatible. Manager stays at version 1.1.6.
  • Firmware 0.7.4: 3D icons, fewer wasted cycles
    Michal Wojciechowski • 10/08/2026 at 09:01 • 0 comments
    After the EvilBundle detour, I went back to the firmware. The little FIDO2 key now has a native 3D interface, and making it run well on an ESP32-S3 took a fair bit of tuning.
    Jet draws the screensaver and the Apps/Settings icons. LVGL still handles text, controls and touch navigation. I kept the original icon shapes and mint-on-dark style, gave the icons more depth, and made Apps and Settings share the same orbit animation.
    Most of the work was under the hood: caching geometry, reducing repeated rasterizer work and fixing display buffering. The animations now feel noticeably quicker on the actual device, with no visible loss of quality in testing. The release uses Os optimization.
    ABI v5 also adds native 3D scene rendering for microSD apps. An .ekapp keeps its game or application logic and sends a bounded scene description to firmware, which handles the expensive drawing. This app renderer is separate from the Jet UI. Existing ABI v4 apps remain supported.
    Firmware 0.7.4 has been installed and tested on my Waveshare PCB V1.0 prototype. FIDO/PIN, touch navigation and the existing apps work correctly, and the update preserved protected storage.
    The public firmware repository now includes the accepted BIN, source package, checksums and updated ABI/SDK documentation. Manager remains at 1.1.6; its source labels and documentation have been aligned with the release.
    V1.1 hardware testing is still pending. The eFuse/HMAC and Secure Boot version is the next security stage; 0.7.4 remains development firmware.
    Firmware 0.7.4 and SDK · Manager · microSD examples
  • EvilBundle: five useful tools, five excellent distractions
    Michal Wojciechowski • 10/07/2026 at 10:29 • 0 comments
    I originally needed a FIDO2 key. It now has a scientific calculator and plays pinball. Apparently, I cannot be trusted with spare flash storage.
    EvilBundle now contains ten apps, loaded from microSD as .ekapp packages.
    The useful half
    • EvilLevel — an IMU-based bubble level, angle and slope measurement, with zeroing, hold and saved readings.
    • EvilBench — electronics calculations: Ohm’s law, LED resistors, voltage dividers, RC filters, 555 timers and component markings.
    • EvilUnis — unit conversion, including editable expressions, favourites, history and custom units.
    • EvilCounter — multiple counters, adjustable steps, targets and timed sessions.
    • EvilCalculator — a scientific calculator with powers, roots, trigonometry, logarithms, combinatorics, memory and an expression editor.
    The “yes, this was necessary” half
    EvilBlocks, EvilPinball, EvilBreaker, EvilInvaders and EvilRacer. Because debugging firmware apparently wasn’t enough of a time sink.
    The screenshot sheet below shows actual .ekapp output captured in the firmware host renderer. It covers the current interfaces; it does not replace testing each app on the physical device.
    EvilBundle remains in a private repository for now. This is a progress update, not a public bundle release.
    I’m still open to interesting ideas for extending EvilKey. What would you actually use on a tiny touchscreen key that you already carry around? A practical tool, a game, or something I haven’t thought of yet?
  • Firmware 0.6.1, a V1.1 board on order, and the next security chapter
    Michal Wojciechowski • 10/06/2026 at 10:27 • 0 comments
    EvilKey started because I needed a FIDO2 key. It now has games, a BLE gamepad and an air mouse. I’m attempting the unfamiliar discipline of finishing something before giving it another menu.
    Firmware 0.6.1 is available, with matching Apps/Settings ring animations and the existing ABI v4 app interface. The release image has been installed and checked on my Waveshare ESP32-S3-Touch-AMOLED-1.64 V1.0 prototype.
    I’ve ordered the V1.1 revision to extend compatibility. Once it arrives, I’ll check the display, touch, IMU, microSD and USB/FIDO behavior, along with the existing BLE roles. Until those checks are complete, V1.1 remains an upcoming test target.
    The development firmware is approaching feature finalization. The immediate focus is stability, compatibility and cleaning up the remaining rough edges.
    After that comes the next planned EvilKey version: eFuse/HMAC-backed protection for key storage and Secure Boot for signed firmware verification. Provisioning, migration of existing credentials and the update process will need their own implementation and hardware validation.
    The current release remains development firmware without those protections enabled. I’ll publish the implementation and test results as that work progresses.
    Interesting extension ideas are still welcome—especially practical experience with V1.1 hardware or ESP32-S3 provisioning.
    Firmware 0.6.1 and source
  • Firmware 0.6.0: an app launcher, BLE Gamepad and an air mouse without the cable
    Michal Wojciechowski • 10/03/2026 at 15:03 • 0 comments
    I needed a FIDO2 key. It acquired a screen, then an air mouse, then games. Firmware 0.6.0 is the next consequence of leaving that compiler within reach: a proper app launcher and two deliberately activated BLE controls.
    The public release now contains the exact PCB V1 BIN tested on my device, its public source and checksums. The firmware and LVGL GUI are AGPLv3; the app SDK remains MIT.
    The app experiments now have a front door
    From Home, swipe your finger left for Apps, then left again for Settings. Swipe right from Home for the screensaver. Apps opens with an animated introduction matching Settings; up/down moves through pages of 3×3 icons with names. Tap an icon to run its package. Without compatible apps, navigation goes directly to Settings. Charger-only USB power still permits these screens.
    The catalog is cached instead of doing the whole card scan on each UI transition. Packages are independent .ekapp files in /evilkey/apps/ on FAT32 microSD. Copy a file to add an app, replace it to update, remove it to remove the app. Its bounded <id>.save sits beside it, so keeping that file keeps the saved state.
    Runtime remains ABI v4. The current package format is revision 5: every app carries a readable name and 64×64 RGB565 icon and follows the shared corner-exit-v1 UI profile. Older package revisions are rejected. The public specification, MIT SDK and UI profile describe the format, raw touch, motion samples, drawing/image data and saves.
    Sliders should slide, not close the app
    A whole-screen right swipe was too easy to confuse with an app control. The firmware now owns a small upper-left exit grip, with a visible progress strip. Start there, drag right and release after completion to open the shared Yes/No confirmation. Once captured, the gesture tolerates some downward movement and stays complete if the finger continues towards the edge. App time pauses during the gesture/dialog. Touch gestures starting elsewhere remain available to the app. SDK layouts reserve the 56×56 corner, so each app does not need to implement its own exit dialog.
    A gamepad, with a useful hardware lesson
    The landscape BLE Gamepad has an A/B/X/Y cross, shoulder controls, Start/Select and an IMU center action. Direction comes from tilting the key; a touch button can be used at the same time. Settings include analog/D-pad mode, dead zone, Rotate 180 and pairing controls. Its PC/Xbox and Generic/Android profiles are BLE HID; the profile name does not establish native XInput or game-console compatibility.
    An important correction to the earlier ABI-v4 write-up: the interface has room for two touch contacts, but this tested FT3168 panel reports one. Repeated hardware tests did not establish multitouch. The final controls therefore use IMU steering plus one touch button, without button combinations. App authors should also design for a single contact on this board.
    AirMouse: cable or BLE
    AirMouse now offers USB HID or BLE. Hold MOVE to steer the cursor and release to stop. Tap DRAG to hold/release the left mouse button; with drag latched, one finger can hold MOVE to drag. Left/right click and scrolling stay on the screen. Both modules use the same dark-and-mint visual language.
    The radio has an off switch in the lifecycle
    BLE starts only when a BLE module is launched. Choosing a BLE preference without launching it does not turn the radio on. Leaving the module returns to FIDO with BLE off; Home, Apps, Settings, screensaver and USB roles keep it off. Mouse and the two gamepad profiles have separate BLE identities and bond stores, and Forget Pairing is limited to the selected profile.
    The tested image, storage and limits
    The final image was flashed through EvilKey.cmd. Application readback passed and the before/after digests of protected storage matched. Device tests covered Gamepad appearance and controls, Center/settings feedback, both orientations, AirMouse, return to USB/FIDO with existing credentials, and games with save/resume. Windows measurements established...
  • My FIDO2 key runs games now. I was left unsupervised.
    Michal Wojciechowski • 10/01/2026 at 07:25 • 0 comments
    I needed a FIDO2 key. A touchscreen seemed reasonable. An air mouse was already pushing it. Falling blocks and pinball? Apparently nobody confiscated my compiler in time.
    The new Apps Short shows EvilBlocks and EvilPinball running on my real Waveshare ESP32-S3 Touch AMOLED 1.64 PCB V1 prototype. Select an app from microSD, press RUN and play on the touchscreen. No desktop simulator standing in for the device. The clip is silent, with edited captions and the familiar 3D logo/glitch ending.
    The games are the excuse. Independent apps are the useful part.
    The previous log introduced Apps in firmware 0.4.0. Since then, firmware 0.5.0 has brought ABI v4. A compatible app is a separate .ekapp package copied to /evilkey/apps/ on a FAT microSD card. Open Settings → Apps in the normal FIDO USB role, choose the package and press RUN. Swipe right for the shared Yes/No exit dialog. Updating an app within the supported ABI means replacing its file, rather than rebuilding the security-key firmware.
    What changed after the first Apps release
    • Two simultaneous touch contacts, so an app can handle independent controls.
    • Accelerometer samples from the onboard motion sensor.
    • RGB565 image assets and cropped drawing for richer interfaces.
    • Per-app saves: a bounded <id>.save file beside the package on microSD, allowing an app to retain state between sessions.
    The Apps mailbox, Wasm3 allocations and bytecode copy use PSRAM, keeping more internal memory available for USB and card access. Save operations are handled by firmware after a guest step. Older ABI packages are rejected by 0.5.0; use packages built for ABI v4.
    A game does not get the keys to the key
    Firmware runs the bounded WebAssembly interpreter and checks the complete drawing output before displaying it. Apps receive the defined touch, motion, display and save interface; they do not get direct access to FIDO credentials, NVS, USB or networking. Package digests detect corruption, not authorship.
    The ABI v4 specification and MIT SDK are public. The AGPLv3 firmware contains the interpreter, without separately licensed game source or game packages. Apps and USB Tool .duck scripts are different formats with different jobs.
    What has actually been tested
    The exact public 0.5.0 image was flashed to the PCB V1 application partition and the write was verified without erasing NVS. After reboot, USB/FIDO, existing credentials, two independent ABI v4 apps and their save/continue flows were confirmed on hardware. That is a device smoke test; endurance, interrupted saves and sustained app load alongside CTAP still need qualification. The validation record and release contain the image hash and scope. The Short captures gameplay during development, not a benchmark of today's game builds.
    What would you make it do?
    I'm open to interesting ideas for extending EvilKey. A useful pocket utility, a strange visual experiment, another gloriously unnecessary app: tell me what it should do and how you'd use the touch display or motion sensor. I'd like to see what this hardware can become when someone else is left unsupervised too.
  • Firmware 0.4.0: apps from microSD and a wider path for new ideas
    Michal Wojciechowski • 09/29/2026 at 23:35 • 0 comments
    A few days ago I asked what else you would build into EvilKey. Firmware 0.4.0 is a direct response to that question. Instead of putting every experiment into the security-key firmware, EvilKey can now load a separate app package from microSD. Within the current app interface, changing an app no longer requires rebuilding or reflashing the firmware. That makes the earlier community question much more practical.
    WHAT RUNNING AN APP LOOKS LIKE
    Copy a .ekapp file to /evilkey/apps/ on a FAT microSD card. In the normal FIDO USB role, open Settings → Apps, select it and press RUN. There is no install database or uninstall command: replacing or removing the file on the card does the job. Swipe right while an app runs and the firmware asks Yes/No before leaving it. Apps, Settings and the screensaver also remain available when USB power comes from a charger rather than a computer.
    THE BOUNDARY BETWEEN AN APP AND FIRMWARE
    An .ekapp contains a small WebAssembly module plus a header declaring its ID, version, owner, license, ABI and SHA-256 digest. The current package format is revision 2 and the public interface is ABI v3. The app has zero imports. Firmware calls app_init and app_step; each step receives elapsed time and raw touch coordinates. The app defines its own controls and returns a list of drawing commands in its memory. Firmware checks the complete command list before displaying it and enforces memory, drawing and execution limits.
    The current ABI deliberately exposes display and touch only. It does not give an app filesystem, USB, network, NVS, FIDO credential or native pointer access. The package digest detects corruption; it does not prove who wrote the app. Each app can carry its own rights owner and license. The ABI v3 specification (https://github.com/mwr666/EvilKey-firmware/blob/v0.4.0/apps/ABI_V3.md) and minimal MIT SDK declarations (https://github.com/mwr666/EvilKey-firmware/tree/v0.4.0/apps/sdk) are public. The AGPLv3 firmware repository contains the interpreter, but does not bundle any separate application source or package.
    WHAT THIS OPENS UP, AND WHAT IT DOES NOT
    Games, visual tools and interactive utilities using the existing screen and touch interface can be developed and copied to the card independently of firmware releases. This greatly widens the palette of experiments I can try after hearing your ideas. Requests that need the IMU, USB behavior, persistent app storage or another new device capability would first need a considered ABI and firmware change. I want that boundary to stay explicit, especially on a device that also holds FIDO credentials.
    Preview: EvilBlocks running on EvilKey hardware during testing. This separate app is not included in the public firmware v0.4.0 release.
    RELEASE AND HARDWARE CHECK
    The public v0.4.0 release (https://github.com/mwr666/EvilKey-firmware/releases/tag/v0.4.0) includes the corresponding source and a PCB V1 application-partition BIN. I flashed the public-source image to my Waveshare ESP32-S3 Touch AMOLED 1.64 PCB V1 at the app partition, verified the write, ran a test app and confirmed that my existing FIDO credentials remained available. The write did not erase the NVS partitions. This is a hardware smoke test; long-duration app use and simultaneous CTAP traffic still need separate qualification. The exact image hash and test scope are in firmware validation (https://github.com/mwr666/EvilKey-firmware/blob/v0.4.0/firmware/VALIDATION.md).
    What would you build first? A screen-and-touch idea can target ABI v3 now. For an idea that needs other hardware, tell me the user behavior, why that access is needed and how you would test it. That feedback will help decide which capabilities belong in a future ABI rather than hard-coding one more feature into the key.
View all 12 project logs
  • 1
    Identify PCB V1 and gather the parts
    This build targets the Waveshare ESP32-S3 Touch AMOLED 1.64, PCB V1. Check the revision on the physical board before installing firmware. The current EvilKey image and case have not been validated for PCB V2.
    Gather one V1 board, a USB-C cable that carries data, the printed V1 enclosure, the short Unitek USB-C loop shown in the prototype, four M2 × 5 mm screws that secure the board from below, and one M5 × 10 mm flat-point grub screw that locks the loop into the case. Add one FAT32-formatted microSD card to reproduce the USB Tool script demo; FIDO2 and Air Mouse work without it. The display, touch panel and IMU are already on the board; this prototype is USB powered and has no battery.
  • 2
    Prepare the Windows firmware toolchain
    Download the complete source from the public EvilKey firmware repository. Read installation information before changing a board that holds FIDO credentials.
    On Windows install Arduino CLI, Python, Git, Arduino-ESP32 3.3.12 and the Waveshare PCB V1 board definition. The project pins its upstream revisions. Its USB stack checker may require the documented local TinyUSB hook in the shared Arduino core; follow the checker output instead of substituting a different board package.
  • 3
    Prepare and build the firmware
    From a terminal opened in the extracted public repository, run these commands in order:
    1. cd firmware
    2. python prepare_arduino.py
    3. python build_arduino.py
    The build checks the USB stack and writes the image to firmware/build-arduino/EvilKeyV1.ino.bin. If preparation reports a missing pinned USB hook, resolve it using the repository instructions and rerun the build. Keep the build output and error messages together; do not flash an image from a different board revision.
View all 8 instructions
